Question about Nokia 3510i Cellular Phone
My nokia 3510i will not charge it just flashes on then goes off
My phone was dead so I got a new battery and charged it all night now it onlywill flash on and go off
4 Suggested Answers
270rexton
  • 782 Answers
SOURCE: nokia 5800 wont charge?
Use different charger. When charging leave the phone off. Fully charged after 4 hours.
Posted on Jun 10, 2009
  • 105 Answers
SOURCE: my nokia 6500 slide does not charge i have bought
it is the charging port that has a problem, so you have to change it.
rate this
Posted on Nov 23, 2009
SOURCE: problem with charging nokia 5800
buy new mobile .........
Posted on Feb 28, 2010
My NOKIA 3110c phone got switched off by itself and has not come alive. If I try to switch it on, the screen blinks white thrice and then goes dead again!
Firstly, Remove Sim Card , Memory Card and try to reboot 3-6 times,sometimes this trick is working.Even if the problem still persist better to contact mobile repairing shop or follow the procedure below.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 23, 2011 | Nokia 3110 Cellular Phone
3510i manual Phone will not charge
Hi
My database does not show a Model 3510 by Nokia. However there is a Model 3520 that might be a worthy substitute and it's FREE. Click on the following link: 3520 User Manual.
All the best
Ben
Jun 06, 2011 | Nokia 3510i Cellular Phone
My nokia 5610 have no power at all but when i start to charge it has the indication of charging
This is because the only power the phone is receiving is from the power cord from the wall. When this problem occurs, it is because the battery in your phone is completely dead and not capable of receiving a charge (in other words the battery is fried). the solution would be a new battery. A tip on avoiding this problem in the future would be to only charge the phone to a "full charge" and then remove the charger. Avoid leaving it on charge all night while you sleep as this is the main cause of battery death. Also car chargers are another culprit, which is an un-known fact. a car charger uses a different kind of electricity which is stronger. If you have ever noticed that if it takes an hour to fully charge your phone when it is plugged into the wall, it may only take approximately 20 minutes to fully charge the phone in your car. So you if you must charge your phone in your car, charge it for no longer that 10 to 15 minutes at any one-time. good luck
Jan 20, 2011 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
I get a problem with my nokia 3510i abnormal power please help me
HEY HI BUDDY...
ABNORMAL POWER OCCURS WHEN YOU OVER CHARGE THE BATTERY OR KEEP CHARGING THE BATERY SEVERAL TIMES A DAY......
THE BEST SOLUTION IS TO REPLACE THE BATTERY...
THANK YOU...GOOD DAY
Sep 22, 2010 | Nokia 3510i Cellular Phone
My phone is dead. I charged it last night and it
Could be a loose connection by the battery terminals give it a clean, if nothing works you should try and get a new charger or battery or both. Hopefully this helps.
Sep 15, 2009 | Samsung Cell Phones
Phone shows full battery then goes dead in an hour.
If you turn your phone on the very first time you use it you are suppoesed to charge it for ten hours. or not quite ten but what I do is i charge it all night and turn it off. this way you get sleep and in the morning your phone should be fine. if not reset the settings this should do it.
Jul 21, 2009 | RIM BlackBerry Curve 8310 Smartphone
Nokia N73 Music Edition Charges Forever
try factory reset ...... if that does not work get it checked with the nokia service center
Mar 07, 2009 | Nokia N73 Music Edition Smartphone
Nokia 3510i
maybe your phone is grounded if you a tecnician you can try to use hot air heat all board dont heat the C,P,U because C,P,U is im fortant and flash i,c dont heat maybe your phone is dead you can heat board just count seven and remove hot air and ready to next heat of board thats all
Aug 06, 2008 | Nokia 3510i Cellular Phone
Charging
Component problem on your phone so you'll have to take it to a repair agent.
Jan 08, 2007 | Motorola Mobility RAZR V3
Nokia 3510i Cellular Phone Logo
44 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
