Question about Air Intake Hose Fiat Stilo 1 4l Hump Bellow 2 5-2 75 Inch Od Universal
Key fob flashes but wont unlock central locking
Replaced battery and will not work
  • 336 Answers
Take to a auto parts store and they can check your fob it my be bad!
Posted on Mar 05, 2014
Mervia. Why is central locking not locking any door?
It's only an educated guess. If all other locks switches are working it' either the switch panel itself or an electrical short. Switches are popular, get it checked first
Nov 22, 2015 | Vauxhall Cars & Trucks
Central locking wiring clio
I had a problem where my key fob did not lock or unlock the car, Renault Clio Dynamique, but the central locking button in the car did still work and engine turned over fine. Changed the key fob battery still nothing. Read online about disconnecting and reconnecting the car battery, (negative only) and hey presto it worked! All working fine now!
May 13, 2012 | 2002 Renault Clio
2003 330XI keyless entry. wont open or close.
The transponder is not effective any longer sometimes the battery of the remote is very low which needs to be replaced
Jan 17, 2018 | BMW 330xi Cars & Trucks
Bmw 325 on a y reg will turn over but will not fire fault code pointing immobilizer fault anti tamper fault any ideas easy cheap fix thanks
Hi Mark you could try to see if re-programming the key might do it, you could also disconnect the battery for 10 minutes and see if it resets that way...to re-program the key this is what you do, please follow by the book or it wont work, this however is just a trial to see if it will do the job, if reprogramming the key does not do it, then disconnect the battery for ten minutes and then try re-programming of the key...
1, unlock the car with the key ( not fob) get in and shut the door 2, switch ignition on and then off ( do not try to run it just on then off) 3, remove ignition key 4, press and hold unlock button 5, press lock button 3 times quickly all within ten seconds keeping the unlock button pressed 6, release unlock button 7 ( if you have this type of key fob) the led will flash slowly for 10 seconds 8,( if you have this type of key fob) the central locking system will lock and unlock rapidly to indicate correct programming 9 ( if you have this type of key fob) repeat procedure if the led flashes constantly, or the locking system does not unlock and lock rapidly please follow as directed..if you have any problems understanding what to do, please contact me on email address s.e.morris@live.co.uk hope this helps
Jan 13, 2011 | 2001 BMW 325
My bmw 320d remote wont lock car however does lock the car with the key its a 55 reg
Programming
When
Key batteries completely discharged. Key batteries not replaced within 60 seconds. Key added or replaced. DO NOT press remote control buttons during battery replacement.
How
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button Fig. 1 [1]. Press lock button Fig. 1 [2] briefly 3 times within 10 seconds keeping unlock button [1] depressed. Release unlock button Fig. 1 [1]. Some models: LED Fig. 1 [3] flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Some models: Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously
Later keys with bmw badge on key. Battery can not be replaced
Battery in key charges while driving
Dec 22, 2010 | BMW 3 Series Cars & Trucks
Have replaced battery in keystill the central locking wont work??
reset the fob,,,turn key on,leave it for 10 minutes,then turn it off,and right back on,,do this two more times,a total of thirty minutes,this should reset the fob.
Apr 12, 2010 | 2000 Ford Focus
Hi, I have an imported 2004 Subaru Impreza WRX. How do I reprogram the key fob after changing the battery.
first unlock car manually with key remove driver side kick panel/lower A pillar trim connect locking registration wires together(two white connectors,black wire and black and blue wire)press and hold central locking switch on drivers door in the unlock position .interior lamp will flash and an acoustic sound will be heard. now get your key and press unlock and then lock the door should lock then unlock, job done ,i persume it was to program the fob to work the central locking u wanted
Jan 17, 2010 | 2001 Subaru Impreza
Central locking doesnt work on mk2 clio t reg
try putting the key in the ignition and turning it to on then holding the unlock button for 30 seconds and then remove the key and try the remote if still no good go to your dealer and get them to reinishalise the system
Sep 29, 2009 | Renault Sportwagon Cars & Trucks
My renault laguna 1999 rt remote key fob wont work?
IF YOU TYPE 1999 RENAULT LAGUNA REPROGRAMME KEY INTO A GOOGLE SEARCH, YOU WILL BE ABLE TO PRINTOFF INSTRUCTIONS TO REPROGRAMME THE KEY TO THE KEY READER.THE IGNITION NEEDS TO BE OFF TO DO THIS
Jul 09, 2009 | 2004 Renault 181
Mercedes S320 central lock
if you hav a remote control key &yr car wont respond . change key batrrey &contact dealer if still dont work for software
Jul 13, 2008 | 1994 Mercedes-Benz S-Class
Air Intake Hose Fiat Stilo 1 4l Hump Bellow 2 5-2 75 Inch Od Universal Logo
115 people viewed this question
Top Magnum Tuning Vehicle Parts & Accessories Experts
baire
jim
Level 1 Expert
mekanik84
Are you a Magnum Tuning Vehicle Part and Accessory Expert? Answer questions, earn points and help others
