Question about Logitech M-RBB93 Mouse
Rbb93 pairing code - Logitech M-RBB93 Mouse
Bury car kit for 9320 pairing code
the pairing code is written in ur car guide. if there is no code there then when pairing u can put any number and write it on ur device to complete the pairing.
(some cars have their pairing codes in their guides so check it)
good luck
Feb 17, 2013 | Research In Motion BlackBerry Curve 9320 -...
How to solve when usb mouse driver is corrupted in windows 7
Morning to you
I would uninstall the mouse and see what happens else it is the manual.
good luck
kolbrun
Feb 24, 2012 | Logitech M-RBB93 Mouse
I need a pairing code for a Logitech Bluetooth mouse M-RBB93
If the mouse refuse to connect, you should delete it from your Devices, then re-add. (for exact directions, Weldon Dube below has awesome step by step directions)
When it comes to paring, it uses the basic paring code of 0000 (4 zeros)
Jan 10, 2012 | Logitech M-RBB93 Mouse
Describe your pairing code for nokia ck 7w Problem i just need the pairing code
There is no default pairing code for the phone. You have to enter any pairing code and then enter the same pairing code in other device.
However, if you are trying to pair Bluetooth headset, check the headset manual to find its default pairing code.
May 24, 2011 | Cell Phones
My M-RBB93 logitech mouse is recognized but before I can complete the process I need to give a pairing code number for it. It tells me it's either on the mouse somewhere or in the documentation. It's an...
This is such ****. What a waste of time. Logitech sucks. Spent hours trying to research this. Logitech manuals and FAQs provide no help.
Want to pair your crappy Logitech Bluetooth mouse with your laptop/PC? Going crazy trying to find your "pairing code"?
Try this: "0000" (four zeroes)!
Sep 15, 2010 | Logitech M-RBB93 Mouse
My nokia 2330 classic doesnt pair with my parrot 3200 ls color. after synchrinsing them unable to get authorisation code
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 16, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
What is the bluetooth passkey code for lg gt505 mobile phone to pair with other devices
HOW TOCONNECT BLUETOOTH
Take care.
Jul 02, 2010 | LG GT505 Cell Phone
Logitech Bluetooth mouse short lifespan
Call logitech and they will replace it for free if it is still in the warranty period.
Feb 02, 2010 | Logitech Cordless Mouse
Battery in M-RBB93
For some cordless mice or trackballs, there is a slot for the battery door on the bottom of the mouse. Between the slot and the outside edge of the door is a thin strip of plastic. If you compress this thin strip of plastic towards the slot, the catch on the door will release and the door should open.
On other mice, the battery door is on the top of the mouse. Simply slide the top of the mouse cover down and lift the door up. There should be an etched diagram on the door indicating which direction to slide the door.
Once you have opened the battery door, remove the old batteries and dispose of them according to your local waste disposal regulations. Then insert the new batteries into the battery compartment using the diagram in the compartment as a guide. When you have finished inserting the batteries, close the battery door.
regards
Feb 21, 2008 | Logitech Cordless Mouse
Logitech M-RBB93 Mouse Logo
18 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
