Question about Health & Beauty
List of side effects
Sore foot only when sleeping
Altosec side effects
Common side effects: headaches and diarrhea.
Serious side effects: chest pain, dark-colored liquid body waste , fast heartbeat, chills, fever, sore throat, swollen or blistered skin, swelling of hands and feet, unusual bleeding or bruising, excessive sleepiness and vision changes. If you experience any of these, stop taking and contact your doctor.
Dec 12, 2017 | Health & Beauty
Tip
A Guide About the Costs and Effectiveness of Common Snoring Solutions
There's a lot of important things to consider when seeking out an effective solution for your snoring woes.
By Withoutsnoring.com
If you're like millions of people around the world, you probably snore, and you're most likely in need of a solution like yesterday. Not just any solution either, but one that's affordable, simple, and effective. This guide is going to show you what snoring solutions are available, how they work, as well as their associated costs.
Available Anti-Snoring Solutions: Costs and Possible Side-effects
1.Somnoplasty: Although this sounds like surgery, thankfully it's not. At $1700 - $2200 per session (at least 3 sessions or more are required to get results), it should be surgery. A small electrode is inserted into your soft palate emitting very low levels of radio frequency heat to remove tissues from your soft palate and uvula. This procedure has about an 80% success rate. Possible side-effects? People have experienced bleeding, swollen and sore throats, impaired healing, and infection.
2.Uvolopalato-pharyngoplasty: This snoring solution is about as complicated as its name. It's generally an outpatient procedure, but with the list of possible complications and low success rate, it's most likely not worth it. The price for this procedure is about $2,000.00 (including consultation) plus follow-up visits. A laser is used to trim some of the extra tissue and even the uvula if necessary. About 41% - 66% have seen improvements in obstructed sleep apnea. Patients have reported complications such as difficulty swallowing for days, severe pain, and change in voice tone. If you choose this procedure, expect to take at least 3 weeks off of work to heal from the severe pain and discomfort.
3.The Pillar Procedure: The average cost for this solution is about $1500.00. Since this is considered to be a cosmetic procedure, it isn't covered. It takes about 20 minutes to perform and may require some over-the-counter pain killers. Small woven implants are inserted in the soft tissue using a sterile delivery tool. It helps to tighten up the loose tissue. There's about an 80% patient satisfaction rate after an 18-month follow-up period. The only risks involved are the implants coming out, and they can be easily removed.
4.The CPAP Machine: This is mask that is worn while you sleep. A continuous stream of hair is provided through a 6-foot tube that runs from a water pump. It can cost anywhere from $160 - $800 just to get started, and then there are other costs and maintenance on top of that. It is known to be quite effective.
5.Prescription Mouthpieces: With a 74% effectiveness rate, and zero side-effects, this might be the way to go! The only draw-back with prescription mouthpieces is that they are custom-made and therefore expensive. Expect to pay anywhere from $1100 up to $2500 for a custom snoring mouthpiece. While you sleep, these devices work by either holding your tongue slightly forward, freeing up your airways, or moving your jaw slightly forward for the same results. You may have to visit a physician for necessary adjustments. The great news is, there are over-the-counter anti-snoring mouthpieces that are a fraction of the cost and don't require any special visits to a clinic or physician. These over-the-counter solutions are definitely worth checking into.
We hope this guide provided you with a lot of useful information when considering the right snoring solution for you.
Original source of the article: http://www.withoutsnoring.com/5-expensive-snoring-solutions/ .
on Jul 29, 2015 | Health & Beauty
What is the incubation period for Hand, foot mouth disease
  1. Hand foot mouth disease incubation period The usual period from initial infection to the onset of signs and symptoms (incubation period) is three to six days. A fever is often the first sign of hand-foot-and-mouth disease, followed by a sore throat and sometimes a poor appetite and malaise. One or two days after the fever begins, painful sores may develop in the mouth or throat.
Jun 03, 2017 | The Health & Beauty
I take 5mg of endone with 2 panadol at night to sleep.does endone cuse side effects
Endone (oxycodone) is a strong sedative analgesic. Listed side effects may include (but not necessarily)
dizziness
drowsiness (don't drive or operate machinery)
low blood pressure
constipation
nausea
vomiting
You should only take other pain relievers with Endone under medical supervision. A special no-no with oxycodone is alcohol, so avoid that.
Mar 16, 2015 | Health & Beauty
What are the side effects adco-mirteron?
  • fever, chills, body aches, flu symptoms;
  • white patches or sores inside your mouth or on your lips; or
  • feeling like you might pass out.
Less serious side effects include:
  • drowsiness, dizziness, weakness;
  • nausea, stomach pain;
  • constipation;
  • increased appetite, weight gain;
  • dry mouth; or
  • thirst.
Sep 06, 2014 | Health & Beauty
What is side effect of Amoxicillin 875 MG and Isoniazid
searching for amoxicillin(anti-bacterial infection antibiotic) on the internet gives plenty of results, including many for side-effects. Here\'s one
http://www.everydayhealth.com/drugs/amoxicillin#side-effects
side effects include but are not limited to
Common side effects of amoxicillin include:
  • Upset stomach
  • Diarrhea
  • Vomiting
  • Yeast infection
Serious side effects can occur. If you have any of these side effects, stop taking amoxicillin and call your doctor right away:
  • Severe rash
  • Yellowing of the skin or eyes
  • Unusual bleeding or bruising
  • Hives
  • Seizure
  • Excessive tiredness
  • Swelling of the face, lips, or tongue
  • Chest pain
  • Difficulty breathing
  • A peeling or blistering rash
  • Severe or bloody diarrhea
Isoniazid is the primary drug for treating tuberculosis. Wikipedia has a comprehensive article about it including side-effects. From http://www.drugs.com/sfx/isoniazid-side-effects.html, these side-effects are listed::
More common
  • Clumsiness or unsteadiness
  • dark urine
  • loss of appetite
  • nausea or vomiting
  • numbness, tingling, burning, or pain in hands and feet
  • unusual tiredness or weakness
  • yellow eyes or skin
Rare
  • Blurred vision or loss of vision, with or without eye pain
  • convulsions (seizures)
  • fever and sore throat
  • joint pain
  • mental depression
  • mood or other mental changes
  • skin rash
  • unusual bleeding or bruising
This information should be listed on the leaflet that is supplied with the drugs. The leaflet explains what is meant by \'common\' and \'rare\', eg 1 in a 100, 1 in a 1000, 1 in 10000.
Persistent
Intense or persistent pain in the kidney area might require treatment by other methods than drug therapy, or it may require drugs different drugs to those you mention. This may be a serious condition, please consult a qualified doctor if you have not already done so.
I am not a qualifiedI
14.August.2014
Aug 14, 2014 | Health & Beauty
I have red sores on my tummy and i take an oil of primrose capsule every day is this a side effect
Internal bleeding! Stop using it.
see side effects tab here...
http://www.webmd.com/vitamins-supplements/ingredientmono-1006-evening%20primrose%20oil.aspx?activeingredientid=1006&activeingredientname=evening%20primrose%20oil
May 24, 2014 | Health & Beauty
Do sleeping tablets have side effects?
Each sleeping tablet can cause different side effects but below is a general list of some of them:
Burning/ tingling in the arms and feet
Appetite loss
Constipation
Diarrhea
Dizziness
Drowsiness
Headache
Heartburn
Dry mouth
Feb 20, 2013 | Health & Beauty
What are some of the side effects of the flu vaccine?
You may feel some light flu-like symptoms after getting the flu shot. You might feel some aches and pains and cold like symptoms such as a runny nose, cough or sore throat.
But you should bear in mind that the benefits of the vaccine far outweigh the side effects
Feb 18, 2013 | Health & Beauty
Sore gas pedal foot
The only thing I can suggest is to buy an aftermarket cruise system.
Aug 09, 2009 | 2004 Toyota Corolla
Health & Beauty Logo
54 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
