Question about Texas Instruments TI-30X-IISTK Scientific Calculator
Prime factorization - Texas Instruments TI-30X-IISTK Scientific Calculator
What is a prime factor
A factor that is a prime number. Any of the prime numbers that, when multiplied, give the original number. Example: Theprime factors of 15 are 3 and 5 (3×5=15, and 3 and 5 areprime numbers).
Jun 15, 2017 | Prime Computers & Internet
Number 2 is chosen to begin a ladder diagram to find the prime factorization of 66. What other numbers could have been used to start the ladder diagram of 66?
By changing the number for your prime factorization, you also have a different diagram.
Prime factorization for 66
66
2*33
3*11
Even if we change the prime factorization order, we still have the same numbers.
66 = 2 * 3 * 11
Feb 23, 2017 | Cars & Trucks
How do I express 5765 in exponential form?
Hello there,
First you need to find the P'rime factors' of 5765 which are 5 * 1153
Therefore the Exponential form of 5765 is 51 x 11531
You MUST find the PRIME FACTORS
(That means the two Prime numbers that when multiplied together gives the answer.
. Go here to see how. to 'manually calculate like we used to do it,
http://www.calculatorsoup.com/calculators/math/prime-factors.php
Nowadays just search for 'Prime Factors Calculator' on your search engine.
Sep 10, 2014 | Office Equipment & Supplies
What are all of the prime factors in 847847
There are three prime factors: 7, 11, and 13.
Mar 29, 2014 | Computers & Internet
My casio fx-83GT Plus calculator wont do HCF for me
There is nothing you can do to make the calculator find the HCF for you. No point complaining about that. But if you are interested in doing it by hand (using the calculator to do the divisions for you) here how it is done.
  1. Decompose the first number in prime factors. If a prime factor is repeated use the exponent notation: That helps.
  2. Decompose the second number in prime factors too, using the exponent notation.
  3. Now look at the two decompositions. If a prime factor is present in both decompositions it must be in the HCD /HCF, with the smallest of its two exponents.
  4. Do that for all prime factors
Example: Here are the decompositions of two numbers
(2^5)*3*(5^4)(7^3)*11 and (2^3)*(5^6)*(11^2)*7
The prime factors that are present in both decompositions are
2, 5, 7, and 11
From the two decompositions select the smallest power of each common prime factor. They are represented in bold fonts.
2^3, 5^4, 7, 11
The highest common divisor/Highest common factor is
(2^3)*(5^4)*7*11
Mar 27, 2014 | Casio Office Equipment & Supplies
Can you do the highest common factor on an fx-83GT PLUS casio calculator
The calculator has no application that will find the highest common divisor (or HCF) but that should not be difficult to do by hand.
Now look at the two decompositions. If a prime factor is present in both decomposition it must be in the HCD /HCF, with the smallest of the two exponents. Do that for all prime factors
Example;
2, 5, 7, and 11
2^3, 5^4, 7, 11
(2^3)*(5^4)*7*11
What is prime factorization?
"Prime Factorization" is finding which prime numbers multiply together to make the original number.
Example : What are the prime factors of 12 ? It is best to start working from the smallest prime number, which is 2, so let's check:
12 ÷ 2 = 6
Yes, it divided evenly by 2. We have taken the first step!
But 6 is not a prime number, so we need to go further. Let's try 2 again:
6 ÷ 2 = 3
Yes, that worked also. And 3 is a prime number, so we have the answer:
12 = 2 × 2 × 3
As you can see, every factor is a prime number, so the answer must be right.
Note: 12 = 2 × 2 × 3 can also be written using exponents as 12 = 22 × 3
Jun 22, 2011 | Computers & Internet
Find the prime number between 1 to 50
using System;
class MainClass {
public static void Main() {
int num;
int i;
int factor;
bool isprime;
for(num = 1; num < 50; num++) {
isprime = true;
factor = 0;
// see if num is evenly divisible
for(i=2; i <= num/2; i++) {
if((num % i) == 0) {
// num is evenly divisible -- not prime
isprime = false;
factor = i;
if(isprime)
Console.WriteLine(num + " is prime.");
else
Console.WriteLine("Largest factor of " + num +
" is " + factor);
Feb 01, 2011 | Computers & Internet
Which number under 100 has the most primed factors
Hi johnhboland
Prime numbers are 2,3,5,7,11,13,17,23 .........
Take different combinations from the above list and multiply making sure you don't exceed 100
2x3x5 =30
2x3x7 =42
2x3=11 =66
2x3x13 =78
2x5x7 =70
I would say the answers are 30, 42, 66, 78, and 100 all have 3 prime factors
If repetition of the same factor is allowed:
answers would be 64 and 96 both having 6 prime factors
Have a good day
luciana44
Nov 17, 2009 | Mathsoft StudyWorks! Middle School Deluxe...
Write a c program to find the largest prime factor of a number
#include<stdio.h>
#include<conio.h>
void main()
int num,i=1,j,k;
clrscr();
printf("\nEnter a number:");
scanf("%d",&num);
while(i<=num)
k=0;
if(num%i==0)
j=1;
while(j<=i)
if(i%j==0)
k++; j++;
if(k==2)
printf("\n%d is a prime factor",i);
i++;
getch();
May 16, 2009 | Computers & Internet
Texas Instruments TI-30X-IISTK Scientific Calculator Logo
18 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
