Question about Zanussi TD4112W Electric Dryer
Noisy dryer My dryer when switched on and the drum is turning is very noisy and not quiet like it used to be. Checked to see if any loose objects stuck within the dryer but nothing. Can you please tell me what the problem is?
    New Friend:
I have had the same problem in the past, one thing you can check is the drum. See if it has any play by opening the door and see if you can push it up. it could be the felt strip is worn down or the rollers if it has any or the main bearing in the back. It is posible that is is one of the three things I said because they all cause noise. check it out i hope it helps you.
Posted on Feb 09, 2014
Servis 1200 very noisy in spin modes. Inner drum seems to be very loose and wobbly. Noise sounds like a roller with flat spots running on the drum, or a very bad (failed) bearing. Machine is 12 years old,...
the bearings have gone, if the drum can be split, remove complete drum and replace bearings, if you dont think its something you can do, dont attempt it, but to be honest, its realitivly easy
Sep 09, 2013 | Washing Machines
Model 8600 , drum makes loud noise, not a squeak
HI,
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Jul 26, 2008 | Maytag Dryers
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
DRYER IS MAKING A CONSISTENT BANGING NOISE WHEN RUNNING. DRUM IS TURNING AND DRYER DOES DRY OK.
There are several things that can cause a dryer to be noisy. There are a lot of moving parts in a dryer that can cause noises to occur when they get worn. Several parts support the drum, and may make noise or vibrations when worn out. Many times a dryer will squeak just a little bit as it first starts. This should go away in just a few seconds. Make sure nothing is loose inside the drum. Remove the lint trap and look below the lint trap holder for any loose items that may have slipped through the cracks. The blower wheel is always moving and lint is constantly going by it. If it’s noisy, it may have gotten clogged with lint, or it may be worn and need to be replaced. Clean out the area around the blower. If it’s still noisy, replace it.
Many dryers use a center spindle to support the clothes drum. This spindle may be a ball-and-socket support, or it may be a shaft inside a sleeve. When these component bearings get worn out, they may make a squealing or rubbing sound. Replace this bearing when it gets worn out. Many dryers also use plastic glides in the front end of the clothes drum. When these glides are worn out, you may hear a lot of noise. If the glides are worn, replace them as a set.
Some dryers use rollers to support the clothes drum. If these rollers or wheels are worn out, they can be extremely noisy. You ought to replace the whole set at the same time. A belt that has been damaged or frayed may make a thumping or slapping sound as the drum turns.
The gas valve solenoid will make a buzz type of sound as it opens. The valve itself will give a little click as it starts the heat cycle, when ignition begins, and when the burner is turning off. The burner flame itself makes kind of a low-pitched roaring wind sound.
Thanks for using Fixya.
May 28, 2009 | Frigidaire Dryers
Dryer makes noise when turning like bearings going or belt squeek
check the following -
It's noisy
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
good luck.....
Mar 28, 2009 | GE WSXH208A Front Load Washer
When our dryer is turned on it has a very high pitched noise as if some metal is rubbing on the drum. It is model number DBXR453GVOWW.
It's noisy If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Mar 07, 2009 | GE Dryers
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore Dryer Mod.76990100...shreiking noise when drum turns??
hi,
Dryer Is Noisy
1) Some noises are caused by objects bouncing around inside the drum. Scour the interior of the drum for loose objects.
2) If you cannot find any loose objects inside the drum, the noise may be caused by a defective part, such as a worn or defective drum belt, idler pulley, support rollers, glides, or worn motor bearings. It’s best to call an appliance repair service to replace these parts.
Thanks for using FixYa
Jan 03, 2009 | Kenmore 63942 Dryer
Maytag MDE8000 dryer noise
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.The following site provides mor troubleshooting info:
http://www.repairclinic.com/0088_8_1.asp#Level1_4
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Sep 28, 2008 | Dryers
Dryer is very noisy during dyring cycle.Used to be so quiet you would have to check to see if it was running.
Your complaint is;"Dryer is very noisy during dyring cycle.Used to be so quiet you would have to check to see if it was running".
You have not provided a brand name or model number. I I can only offer information based on genric or common solutions. Below is a link that should prove helpful if you need additional information.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 15, 2008 | LG Dryers
Zanussi TD4112W Electric Dryer Logo
57 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
