Question about Whirlpool Dryers
No heat Mod #gew9520pwo
  • Whirlpool Master
  • 2,696 Answers
Could be a few different things,bad heater,popped thermal fuse or the high limit on the heater box,if the dryer hasn't been taken apart and cleaned out in a long time and it should be done once a year if gas and 18 months if electric,clean out the cabinet where the motor is,clean out the duct that the lint filter slides into and blow out the vent line,if the air isn't moving and it's been taking longer to dry your clothes most likely you popped the thermal fuse,you have to clean it out or the fuse will keep popping and it's a none resetting fuse or the high limit thermostat popped on the heater box,both are from the dryer running to hot and either the thermal fuse or the high limit will pop as a safety.you'll need to unplug the dryer and get in there with a meter to see what part is bad,remove the bottom panel,pull out the lint filter and then remove the metal duct that the filter slides into and you can read out the parts,you have to remove at least one of the wires on the part you check,on top of the blower wheel housing you'll see a white piece with two wires going to it,pull off one wire and check it with your meter,if that's good go to the right and check the heater and the t-stat in the back on the heater box,hope this helps
Posted on Feb 13, 2014
Aquamark hand held mod.am680 not steaming why
hi there did you find a solution i have the same problem thanks
Mar 01, 2013 | McCulloch MC1246 Handheld Steam Cleaner
Friedrich ductless heat pump will not start up.
Did you check to see if the compressor is running? Check out start relay/capacitor.
Sep 21, 2017 | Heating & Cooling
The driver seat heater just quit. all fuses are good. how do you tell if the relay is good?
Swap it with a relay you know to be good and see if it works again,pick a relay that is not important to the function of your car.
Nov 01, 2009 | 2004 Cadillac SRX
Mod: LGR5620KQ1 dryer keeps running. timer stays the same.
sounds like short to ground and feed back to timer
Aug 31, 2009 | Whirlpool Dryers
Gas dryer mod.# MDG6000BWW, Igniter lights but no flame
Replace the flame sensor on the side of the heat canister. You may also have to replace the gas valve coils.
Aug 27, 2009 | Dryers
Amana gas dryer mod #NGD5240TQ0 intermitten heat
i went to a local appliance store asked them for assistance. they were more than helpful and sold me the parts i needed. fixed the problem for under $30.00. i also didnt have to pay for their ADVICE !!!
Aug 22, 2009 | Amana Dryers
Laars lite 2, mod-lg125n, sn. d03pj3400.
sounds like heat exch is plugged.remove top of unit and inspect for nests.could also be plugged with soot because of poor burner flame characteristics.with top off,turn htr on and look straight down into unit. you should be able to clearly see burner flames between fins. if not remove exchanger and clean
Jun 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
My x box freezes on all of the games?
You need a thorough Xclamp mod. Most Xclamp mods do not do a permanent repair. The mod that uses screws through the case and locknuts on top of the heat sinks is most thorough method. The foam pads and screws through motherboard does not effectively solve the issue. PlaystationClinic.com does good mod for $50 plus shipping.
Dec 26, 2008 | Microsoft Xbox 360 Console
Console freezes and we are unable to do anything. No red lights just green. Anyone any ideas?
You are in dangerous waters!!!!! The problem with xbox's is cheap tin solder. when this solder gets hot your connections start to get bad. Slight problems cause freezing which almost always turns into bad connections leading to the ring of dealth. If it is in warrenty send it in!!! If not, Take it apart and use a heat gun on it. I have tried every thing on my first box after the ring of dealth. Tried, xclamp mod, eraser mod, cut out metal fan shroud mod, cooling plenum divider mod and others with no long term solution. I finaly took it apart and gave it about a minute of even heating with a heat gun on low and I have been playing the box hard for a couple of months now!!! Knock on wood!! Also I recommend the intercooler 2 to help with cooling your box down. It's load but it cools the box down dramaticly. Good luck
Sep 22, 2007 | Microsoft Xbox 360 Console
Dryers Logo
41 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
