Question about Logitech Z320 2 Speakers
Power supply required - Logitech Z320 2 Speakers
Hi I have a car amp in my room which is hooked up
Car amplifiers cannot be powered by laptop power supply. These amplifiers have different power ratings. You need to check the Car amplifiers power requirements / rating (Voltage & Current requirements) and then get a power supply with the exact same Power ratings. If the power supplied to the amplifier is less than the rated power it needs, it will not be able to drive the amplifier IC's and transistors in the amplifier and will not produce good sound.
Please check the power requirements for the amplifier and buy a suitable external power supply for it.
Sep 01, 2014 | Computers & Internet
Not turn on
Unplug all power cables and check for bad connections. Reconnect all cables. Does the power supply fan rotate? Yes or No? Looking through the vented left side of the tower with the power cable plugged in do you see an LED lit? If no fan spinning in the power supply and no LED lit, then I suggest you change the power supply. Either do it yourself (very easy to do or have a tech shop do it for you - it's cheaper to do it yourself).
1. Un-plug all power cables.
2. Unscrew side panels.
3. Count how many of each type of power cable is required for on board devices.
4. Calculate power requirements by watts.
5. Purchase new power supply that has the cables you require and the required wattage to support your devices.
6. Unplug all power cables inside.
7. Plug in new power supply.
8. Plug in power cable first before turning on the computer. The green LED on the motherboard should come on. Congrats you have power.
9. Turn on the computer.
10. Enjoy!
May 18, 2014 | Acer Veriton M420 PC Desktop
What voltage is required for the power inlet port or is the USB cable enough?
The 2.5 inch external drive (laptop drive) does not require separate power supply because USB cable can supply enough power for this drive. The 3.5 inch external drive (desktop hard drive) requires separate power supply and it depends on the model.
Mar 01, 2014 | SimpleTech SimpleDrive 160 GB External USB...
Need a power supply for a linksys WRT546 What are the voltage requirements for this model?
The Linksys WRT54G requires a DC power supply of 12V.
You can purchase this power supply from any electronics store or online vendor.
Mar 07, 2011 | Linksys Wireless-G WRT54G Router
I removed the power supply to install motherboard and did not pay attention to the 3 wires attached to the case. what is the order of the wires? They are green/yellow, blue and brown.
All the wires from the power supply are power connectors, depending upon the motherboard not all power connectors from the power supply maybe required. If there are no matching sockets on the motherboard, then that power connector is not required.
Nov 07, 2009 | Antec AR300 300-Watt Power Supply
Need Power supply
As per manual. Please use a power supply that is able to handle the system voltage requirements.
It is recommended that a power supply that can withstand high power consumption be used (300W or greater). The power supply link included should be more than efficient to run your GA-8I945GZME-RH MB.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4465483&csid=ITD&body=MAIN#detailspecs
Limited warranty, 60 months.
Cheers!
Mike
Oct 29, 2009 | Gigabyte GA-8I945GZME-RH Motherboard
What power supply is required. The rear input
No. It is not recommended to use this power supply, since it outputs only 12 watts of power, whereas the required power to run your speakers is 26 watts.
You will have to use a power supply which outputs 13 VDC, with at least 2A.
May 16, 2009 | Altec Lansing ACS 90 Computer Speakers
Problem with minebea atx power supply
The one extra cable with the small socket may be for the newer computer that require a power imput to the CPU. Also some of the more poswerful Viseo cards also require their own power cord supply. Many ATX power supplys have extra leads not being used .
Feb 12, 2009 | HP/ Minebea 160w ATX Power Supply...
Do this graphic card require supplementary power???
no need, unless the FAN requires an external power source, but you can use your powersupply to supply it.
Jun 11, 2008 | Nvidia GeForce 6600 Graphic Card
POWER SUPPLY REQUIRED
you don't a new power supply for that speaker because they all have in the package with the power supply adapter ..all have to do is to plug the adapter to ac power outlet your speaker is gonna be function...
Dec 14, 2007 | Creative Labs Inspire T7900 Computer...
Logitech Z320 2 Speakers Logo
15 people viewed this question
Top Logitech Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
JP Services
JP Services
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
