Question about Wagner SMART Edge Roller
Filler tube the product I bought will not go in the sectiion that you fill. Is there an adapter that suppose to come with it?
Cannot fill fuel tank at pump
I had something like this happen on my boat. it has a little like flap that is suppose to prevent fuel from backing up the filler tube it was doing the opposite and preventing fuel from going into tank. I use at the time my only resource. my antenna to hold the flap open while filling.
Jul 17, 2015 | Cars & Trucks
How to replace fuel tank filler tube?
Brother John, you've removed as much as you can for access to the filler. Remove the hose clamps/bands that secure the fill tube and vent tube and then remove the screws around the gas cap that secure the fill tube to the body. With the gas cap off, go below and pull the hose and filler neck down and work the hoses lose with a pair of channel lock pliers and sticking a screwdriver between the metal tube and hose to break the seal. Put on the new filler neck and stick it back up in the body and put the screws back in. THEN put the hose clamps back up and tighten them, put the gas cap back on and your done.
Nov 30, 2014 | 2000 GMC Jimmy
Gasoline pump keeps clicking off every few seconds
a suggested have the filler and recovery and evap system of the tank filler tube checked out ..could be perished seals or piping
other thoughts
some gas stations fuel pump sniffers can be more sensitive to shut offs than others....the pump sensor is supposed to be tested adjustable or sensor replaced regular intervals
these days the operator wait till there enough complaints before doing anything
the new model cars seem to have more filler neck filling issues
than in the past
could be the smaller diameter of the pump nozzle
could be the temperature of the day fuming the gas in the cars filler tube
Mar 02, 2014 | 2004 Nissan Pathfinder
Gas fill problem
the filler tube relies on an air bleed hose that runs from the top of the tank to where you place the filler nozzle. This allows air in the tank to bleed out as you are filling it. If this tube is blocked (pinched) then the air has to come out the filler tube past the nozzle and any fuel will cut the flow of at the nozzle.
Nov 15, 2013 | 2005 Ford Explorer XLT
When I try to put gas in the tank it will only take 0.44 gallons and then the pump just shuts off and no more gas can be put in the tank
Usually a sign of a vent problem with the tank, or a blockage in the filler tube for the tank. The tube has a small pipe that is supposed to equalize pressure inside the tank as you fill it.
Someone may have to remove the filler pipe and check for restrictions.
Dec 18, 2012 | 2005 Dodge Grand Caravan
I can only dispense fuel at a trickle when trying to fill my gas tank, the trigger on the handle shuts off when engaged at full capacity. Help!!
One or two things here.... you either have something lodged in ya filler tube or the vent to the tank is pluged. I am leaning more towards it being something lodge it the fill tube. Or another on could be that the fill tube is pinched off not letting the gas get to the tank. Take the clamp off the filler tube on the tank and then off at the filler door. And check to see if there is something in the tube. Hope this helps.
Nov 24, 2012 | Cars & Trucks
My 2004 dodge ram 1500 4x4 with a hemi 5.7 will not accept fuel.As soon as i start to fill it backs up the filler and stops the pump.the only way i can fill the tank is to hold the fuel nozzel out of the...
my 2004 dodge ram 1500 2x2with a hemi 5.7 will not accept fuel.As soon as i start to fill it backs up the filler and stops the pump.the only way i can fill the tank is to hold the fuel nozzel out of the hole ans slowly shoot the fuel into the filler tube.This is not only unsafe for my wife and kids but very time consuming.replaced fuel fill tube already and had breather tube blownout and scoped by a mechanic.He now tells me i need a new $500 gas tank.Is this something i can have the dealership fix for free?
Feb 13, 2011 | 2004 Dodge Ram 1500
I have a 2006 F250 which I have lots of aggravating problems with trying to fuel up. No matter which gas stations or method of inserting the nozzle into the fill tube I use, I am frustrated by the time it...
where the filler neck goes to tank didnt it have seperate tube which is vent or with filler neck hose off at tank look inside tube for another hose it is vent hose take fuel cap off and blow air from tank end towards the filler cap area we have had two ford vehicles lately in our shop when we blow shop air backwards thru hose several little round pieces of foil off of fuel injector cleaner bottles somehow they had become lodged in vent line and one customer had vehicle towed from gas station because they were on empty and would accept no gas you may want to check this doesn,t have to be cleaner bottle tops could be any sort of debris but ours came flying out of fuel cap when when blew air thru you could pump gas with handle all the way down she was happy
Mar 24, 2010 | 2006 Ford F-250 Super Duty
Kenmore 10670187000 Refrigerator. freezer filling with water/ice
You pull it out from inside the freezer but I would try melting any ice that may be stopping it up first with a hairdryer. The water inlet valve on the back of fridge is probably leaking and when the water gets to to fill tube it freezes and partially blocks the tube causing it to spray out. Disconnect the line coming out of the water inlet valve to see if it has a slow leak. You may need to replace the valve.
Sep 03, 2009 | Refrigerators
Wagner SMART Edge Roller Logo
51 people viewed this question
Top Wagner Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Wagner Tool and Hardware - Other Expert? Answer questions, earn points and help others
