Morris wdw 60811 manual
Could you please tell me how many degrees is the "cold wash" programme. Regards Korina
2 Suggested Answers
SOURCE: Bosch WF2001 washes only 30 degrees programmes
We had this problem and it turned out in our case that the hot water inlet filter was blocked. The pump wasn't receiving any hot water into the machine so wouldn't start on anything except a cold (30degree) wash.
We turned off the the hot water tap on the plumbing at the back, disconnected the inlet pipe from the machine, then put the end of the pipe in a bucket and turned the water back on, and saw loads of sediment spurted out.
We ran it until we'd filled the bucket, then turned the tap off, emptied the bucket down the drain, then disconnected the hose from the plumbing and cleaned the hose separately (there's a gauze at the plumbing end of the hose so make sure that's clean).
Then get some pliers and where the hose attatches to the machine there's a filter that you can pull out. Clean this out. In our case this was completely blocked with limescale sediment etc.
Reconnect everything, check it's all tightly fastened etc. then turn the tap on the plumbing back on - turn it on to a hot wash, press start ...and in our case it all worked a dream again.
All this info is in the manual if you've got one, but I thought I'd write it out in case you've got this problem and don't have the manual.
Ahhhhh... cleeean washing again! Hope this works for you. Happy go laundry!
Posted on Sep 22, 2011
Which is hot & cold inlet connection
If you want to connect up a washing machine that uses hot and cold water but you only have a cold water supply (such as in a basement or garage) you can use a Y Piece connector to connect the hot and cold fill hoses to a single cold water supply (external link to 4Washerhelp spares).
The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may also be able to buy this part from a DIY store like B&Q)
If you don't connect a water supply to the hot valve (and simply connect the cold water hose to the cold valve leaving the hot valve with nothing connected to it) then some wash programs may not work as some programmes only fill with hot water. However, some washing machines will work OK with only the cold fill hose connected. You can always try it and see. The worse that will happen is the washer could either stick on the odd wash programme or may abort on some. If you do this though it's possible for water to drip out of the hot valve on some machines during fill. It's best to use a y-piece if possible.
The fact that you have connected cold water to the hot valve is irrelevant, the washing machine will not know any different and will just heat the water up to the correct temperature. The washing machine may use slightly more electricity but if it's less than 10 years old it shouldn't be significant unless you use a lot of 60 or 90 degree washes. On 40 degree washes, manufacturers argue it's more efficient to fill with cold water only and slowly heat up the water to 40 degrees.
Apr 30, 2011 | Washing Machines
I have an epiphone korina explorer bass guitar, made in korea in 2002, the colour is natural, how much is it worth?
They've been listed as cheap as $399.00 new:http://www.google.com/products/catalog?oe=UTF-8&gfns=1&q=epiphone+korina+explorer+bass+guitar&um=1&ie=UTF-8&cid=11627556200103526247&ei=iI0BTbViiqOdB4TvmOUN&sa=X&oi=product_catalog_result&ct=result&resnum=4&ved=0CDkQ8wIwAw# Depending on how much wear and tear etc. the value could be 60% of that. Here is another source:http://www.usedprice.com/items/guitars-musical-instruments/all/bass-guitar/
Dec 09, 2010 | Epiphone Korina EXplorer Bass EB LTD
Cothes are being put on a 40 wash but coming out stone cold is there a way to check if water is heating as no fault is flashing up on display
I would expect the clothes to be cold after the cycle is finished, as it will have completed at least 3 cold water rinses, so I do not think you have a problem.
If you want to check if the heater is working o/k, then select a hot wash programme, say 90 degrees, and feel the door glass after 30 mins or so, it should feel warm , and if the heater is not working, then normally the washer will not complete the programme.
Dec 01, 2010 | Washing Machines
Some 1 gave my daughter a slimline zanussi dishwasher not sure what model it is but looks quite old. need a manual as the program numbers have faded and cant see them regards chris oh and its a aqua save...
If the model is correct then even without a manual the control set up is as follows.
From Lhs you will see on/off/ button next are the 2 lights top one is on/off and the bottom is for salt low light.The next button to the right is rinse and hold next Intensive 70 Degrees,next Normal 65,next Bio 50, next Quick wash 50 Degrees.To cancel a wash programme open the door and press the button for the prog. underway for more than 1 second until the corresponding light goes out.
The dishwasher is now reset and you can select a new programme.You can try this site for a manual.
www.appliancehelponline.com
Hope this helps.
May 27, 2010 | Zanussi 18 in. ZDT5052 Slim-Line Built-in...
Mar 04, 2010 | Bosch Washing Machines
Washing wool?
I assume you are asking if there is a wool programme.
There should be a seperate wool programme incorporated in the timer or programme control unit, and it is usually a 40 degree wash.
Please rate my solution.
Thanks.
Nov 11, 2009 | Bosch Classixx WVF 2402 Front Load...
Programmes in washing mashine Eurotech FL 807 are really long (very old washer?) I want to run an empty mashine on 90 degrees (C) to clean it, can I combine hot water with a shorter programme although the...
yes - there is no thermostat to tell it the water is warm - go for it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 20, 2009 | Washing Machines
Washing Machines Logo
189 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
