3104 328 42742
Where can I find a power board for a Phillips 42" plasma TV. 3104 328 42742
  • 133 Answers
SOURCE: LG 42 plasma power problem
needs power supply Part number 6709900023A
it is a 171 dollar part, you should be able to order through LG,
Posted on Jan 10, 2009
D_LLAMA
  • 6 Answers
SOURCE: 42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Posted on Mar 03, 2009
  • 814 Answers
SOURCE: LG Plasma TV 42''
These problems are probably bad inverter board that supply the inverted voltages to the back lights. It also could be a failure of the back light itself. This problem should be taken to a service center, where they can test the inverter board and the back lights. You can got to the website of the product and check out the frequently asked questions to see if your problem or similar one have been posted and answered. Hope this helps you with your problem.
Posted on May 14, 2009
dsacco86
  • 1077 Answers
SOURCE: No power to my Phillips 42 inch Plasma
Most likely it going to be a power supply related problem. The red blinking light is a code for a TV tech to diagnose the problem on the power supply board itself or the board that regulates the power for the screen. Some manufactures call it a Backlight Inverter Board. A TV repair shop should be able to look at it for you and tell you which board is bad.
Replacement boards can be found at a good price at Shopjimmy.com
Posted on Sep 06, 2009
SOURCE: Y - BUFFER BOARD - PCB: LJ41-02760A : Parts FOUND!!!!
You can also find it here: http://www.itritek.com/ysusbufferforsale.html It's a lot cheaper than partstore and they offer repair too.
Posted on Sep 22, 2009
My 42 lcd phillips tv colur turns red and zig zag lines then turns itself off why is it doing this
You are not the only one I can tell you that. I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Oct 21, 2010 | Philips 42 in. Plasma TV
My 47" phillips plasma tv doesn't want to turn on a litle red light up at the front is flashing red? what is the problem?
The board where the a/c power cord plug into it.The the power supply board,it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 23, 2010 | Philips 42PF9631D 42 in. Plasma Television
Tv just turns itself off and then starts clicking like its trying to turn on and off
Solutions?
Hope this helps
Mar 03, 2010 | Samsung PS42C91HDX 42 in. Plasma TV
My phillips flatscreen tv is making this clicking sound and it wont turn on?
Power supply board it dead.Replaced the power supply board to get power back.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for replacement.
Feb 12, 2010 | Philips 42PF9630A 42 in. Plasma Television
No power to my Phillips 42 inch Plasma 42pf7321d/37, just a red blinking light
Sep 05, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Our 52 inch Phillips Plasma tv is not working
open the back of the set and inspect the power supply board -- there should be two fuses on the board- they cost around 2 dollars at radio shack -- check all connections for wear or damage -- there are two boards in most televisions -- a power supply board and a audio / digital board -- one is probably board
Feb 28, 2009 | Philips 42PF7220A 42 in. Plasma Television
for more detail.
Jan 06, 2009 | Philips 42FD9932 42 in. Plasma Television
Phillips 427220a
After you remove the back cover inspect the power supply board for swollen or bulging capacitors. Pull and check any capacitors that you suspect to be swollen. Next, look for a sticker in the upper right hand side of the TV set. Use the values you find on the sticker to calibrate the voltages on the power supply board.
Mar 08, 2008 | Philips 42PF7220A 42 in. Plasma Television
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
Electro Med Services...
