Question about Exercise & Fitness
Our nordic track commercial 2450 model NTL19112.2
The screen quit counting 1/4 mile laps and the marker no longer moves on the track. It had worked correctly and quit in the last two weeks. The firmware was just updated.
  • 64 Answers
SOURCE: Nordic Track Treadmill will not run
If console lights up but doesnt respond when buttons are pressed, you more than likely have a console problem. Key pad issue would be my best guess.
Posted on Jun 08, 2009
  • 103 Answers
SOURCE: Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Posted on Jan 13, 2010
Testimonial: "Although I haven't attempted this solution, but it makes perfect sense and will attempt it as soon as I get back to the treadmill - Thank you"
maxtreadmill
  • 832 Answers
SOURCE: manual for a Nordic Track Personal Performance
Go to iconservice.com click on to manual Input manufacturer : Nordic Track then model # NTL349050 and you manual await you.
Posted on May 15, 2010
SOURCE: Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Posted on Jul 10, 2010
  • 34 Answers
SOURCE: Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Posted on Aug 18, 2010
Why my commercial vr resistance levels not working at all? Do i have to replace the resistance motor?
https://service.nordictrack.com/CustomerService/manuals.do?dr=NT
https://service.nordictrack.com/CustomerService/contactUs.do
Jun 16, 2014 | Nordic Track NordicTrack Commercial VR...
Nordic track commercial 1500 no power
looks like there is power to the board. the board the sends power to the console. there could be a loose connection at the board
Mar 04, 2014 | Nordic Track NordicTrack Commercial 1500...
I have a Nordic track commercial1500 and the belt motor will not run. Everything else works fine. The fuse is good on the board.
1) see if the belt is tight or loose, repair or replace the belt
2) test the input voltage motor, if there ARE the motor need repair see my personal TIPS for motor help
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulyt, replace see the b.diagram attached.
Jan 09, 2013 | Nordic Track NordicTrack Commercial 1500...
My Nordic track 1500 motor will not run, everything else still works????
Step 1:
1) test the input voltage motor,if there are the motor need repair,see the diagram attached, and see my personal TIPS for motor help
Step 2:
tes the output voltage board, for input voltage motor, if there are NOT the board is faulty, replace see the block d.
God bless you
Nordic Track X5 belt won't move
1) Lube the deck belt, this happen because the electronic system protect the system and shut down.the cause is deck worn.
2) Lube the rollers bearing too.
3) Measure the input voltage motor, if there are the motor need repair.
4) Measure the output voltage board, for input voltage motor, if there are Not the board is faulty.
God bless you
Jun 12, 2012 | Nordic Track Exercise & Fitness
How do I get the motor hood off a nordic track commercial 1500
Download a manual for this model . This will make it easier to find the hidden screws.
Apr 06, 2012 | Nordic Track NordicTrack Commercial 1500...
Nordic track commercial 1300 manual
It sounds like reed switch inside the side panel located on the frame by the large pulley either needs to be adjusted or replaced. Try adjusting the switch first the clearance between the switch and large pulley magnet will be 1/8" if you have the same result then replace the switch.
Jun 12, 2010 | Nordic Track Exercise & Fitness
Exercise & Fitness Logo
76 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
