Question about Klipsch ProMedia THX 2.1 Personal Audio System Black
Can't connect speakers to subwoofer
I have two sets of speakers. The 2.1 and the 4.1. I am currently using the 2.1 "main" speaker with the 4.1 setup as I have a problem with the 4.1 main speaker. I have two subs that are basically identical, but they will only accept connections from a 6 pin mini DIN male connection. My 4.1 "main" speaker has a 8 pin DIN connection. I was wondering if there was an adapter that would connect a 8 pin DIN to a 6 pin mini DIN out there.
2 Suggested Answers
  • 91 Answers
SOURCE: RCA jack in back of the speaker is no longer
cut connectors from board & join cable of speaker & output wires
Posted on Jan 26, 2011
Where to plug in powered speaker (subwoofer) on yamaha emx88s mixer? I tried monitor but it doesnt work.
To connect powered speakers and/or subwoofers follow the instructions on page 19. Connect the powered speakers from the Main L and Main R.outputs
"MAIN (STEREO) jack: The stereo (MAIN L,R) bus signal which has passed through the MAIN MASTER control and graphic equalizer."
for the subwoofers set the YAMAHA SPEAKER PROCESSING switch on/off for best sound as desribed on page 13.
To test this I would play the song Let's Go by Calvin Harris.
for best results use a matched pair of speakers and subwoofers
such as the Electro Voice Live ELX112/ELX115 to the elx118p subwoofer.
Dec 16, 2013 | Audio Players & Recorders
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Subwoofer output issue 5.1 setup. 2 speakers
Try turning up the sub out-put, in the Receiver settings
Sep 11, 2013 | Yamaha RX-V757 Receiver
No output to the subwoofer using the sub pre out RCA jack.
I'm assuming your subwoofer is self-amplified, otherwise it won't work with a preamp (rca) input.
Under Speaker Setup you have to have Subwoofer set to YES (page 16).
If you have good bass-capable main speakers I would recommend setting the subwoofer playback mode to LFE+Main, otherwise just LFE.
Beyond this we would need to know something more about the subwoofer and its controls.
Connect any other preamp out channel, like CDR/Tape OUT, to the sub and tune an FM station to see if the sub is capable of processing audio. A 'normal' audio signal would sound muffled but it would prove the cabling, amp and speaker at least function and point us back to setup as the culprit.
Dec 08, 2010 | Denon AVR-587
Can we use the subwoofer as an amplifier for speakers? it has jacks for speaker in/out, but i can't figure out how to make it work because the speakers have no sound.
I don't believe this hookup is amplified; but, if you have used the regular unfiltered speaker connections from your receiver/amplifier to hookup the subwoofer, the system will pass the signal thru the outputs subject to the crossover adjustment on the back panel. You cannot get the full signal if your system is sending only the bass signal to the subwoofer. I have copied the instructions below from the manual. You would set the high freq crossover to the low end of your satellite's frequency range. The full manual is here:
High-Pass Control
• If you hooked up your subwoofer
as shown in Hookup
3 on page 4, you also have
the capability of adjusting
the high-pass frequency.
The High-Pass control
determines the frequency at
which the main speakers
will start reproducing
sounds. If your main speakers
can comfortably reproduce
some low-frequency
sounds, also set this control
to a lower frequency
setting, between 50Hz –
100Hz. This will concentrate
the subwoofer’s
efforts to the ultradeep
bass sounds, while your
main speakers continue to
reproduce the mid-bass
information. If you are
using smaller bookshelf
speakers that do not extend
to the lower bass frequencies,
set the high-pass crossover
control to a higher setting,
between 125Hz – 180Hz.
With this setting, your main
speakers will not have the
burden of reproducing any
low-frequency sounds.
as shown in Hookup
1 on page 3, the high-pass
frequency is fixed at 180Hz.
as shown in Hookup
2 on page 4, there is no
high-pass control. Unless
incorporates a high-pass
crossover, your main speakers
will continue to get a
full-range signal.
Final adjustment and blending
of the low-pass and high-pass
controls may evolve over several
listening sessions. A good
starting point would be to set
both the low- and high-pass
controls to the same frequency
and adjust from that point.
Sep 07, 2010 | JBL PSW-D110 Speaker
What's the proper way to wire 2 sets of speakers,
the center speaker is easy just wire it to the center main posts (connections are near the middle of the box) (just match up the colours)
and the powered speakers do they have their own amplifier or are they just speakers
if they have their own amplifiers then use the pre out connections near the top of the box
if they are just speakers then
wire them to the front main speaker connections near the right of the box
May 10, 2010 | Denon AVR-1700 Receiver
1) Understand the basics of all car stereo systems. A car stereo system consists of 4 main components and the wiring that connects them. These are the head unit, the main speakers, optional amplifiers and the subwoofers, which are also optional but generally considered a necessary part of any good system. 2) Know that the core of any car stereo is the head unit, which is the cassette or CD player that goes in the dash. All the other components are connected to the head unit by at least one pair of wires. 3) Know about car speakers. The main speakers are usually 2 in the front and 2 in the back, although with what are known as component speakers, each speaker is broken down into two speakers: one for the highs and one for the bass. Each speaker or speaker set (known as a channel) connects to the head unit via a pair of wires. Generally if you are installing a new head unit you want to install new speakers. 4) Know about amplifiers. Amplifiers provide extra power to your speakers and/or extra channels of power for additional speakers. The most common use for an amplifier (amp) is to power subwoofers. The amp connects to your head unit via an RCA cable and often a "remote on" wire, and also connects directly to your car battery through a fused "hot" wire and to the car's chassis with a short ground wire. This article assumes the use of a single amplifier connected to a pair of subwoofers. If you do not have these components simply ignore the steps specific to the amp, doing so will not affect the rest of your installation. 5) Know about subwoofers. Subwoofers are part of any good stereo system. They provide the deep bass that small speakers cannot achieve. Subwoofers are connected to the amplifier which can usually be mounted right to the subwoofer box. If you do not have subwoofers you can simply ignore the steps specific to them. FOR more help click on this link directly ------ This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 25, 2010 | Car Audio & Video
Denon avr 2802 can't get subwoofer to work all else fine
in the Denon setup under speaker configuration set the sub to LFE+Main
Jan 02, 2009 | Denon AVR-2802
I have Harman Kardon speakers and subwoofers connected to a Denon AVr 1508 receiver. All my five speakers are working but my subwoofer doesnt work. I m pretty sure I have connected the subwoofer properly...
There is a setting under your speaker setup to turn the subwoofer on. If speakers are set to small it auto matically sets the subwoofer to ON. If the speakers are set to large it turns the subwoofer off but you can manually adjust.
May 02, 2008 | Denon AVR-1506 Receiver
Control and amplification circuit boards are not recieving power
If there are no visable ways to get into the box from the back then you must remove the speaker from the from and gain access through the hole the speaker came out of. It is not too uncommon for speaker units to built this way. Good luck.
Feb 06, 2007 | Logitech Z-680 Speakers and DVD218 System
Klipsch ProMedia THX 2.1 Personal Audio System Black Logo
43 people viewed this question
Top Klipsch Audio Players & Recorders Experts
Sock Puppet
Are you a Klipsch Audio Player and Recorder Expert? Answer questions, earn points and help others
