Question about Pioneer DV-420V-K DVD Player
Update firmware usb not working
Update firmware lcd tv toshiba 32pb10e
How to Update Toshiba TV Firmware
  1. Plug a USB flash drive in to an available USB port on your computer and copy any files from the drive that you want to keep into a separate folder on your computer.
  2. Format the drive as a FAT32 file system. This erases all of the files currently on the USB flash drive.
  3. Click here to open the Toshiba Support home page.
  4. Click "Product Support" in the menu along the top of the home page. The Product Support drop-down menu opens.
  5. Select "Televisions" beneath Choose Category.
  6. Select your type of Toshiba TV beneath Choose Family. For example, options include 3D TV, LCD TV and LED TV.
  7. Select your Toshiba TV model beneath Choose Model.
  8. Click the red "Go" button to the right of the Choose Model section after selecting your Toshiba TV model. The product support page for that specific TV model will be displayed.
  9. Select the "Downloads" tab. If there are no downloads available for your TV model, either your won't be able to click the tab or there will be a message within the tab that says there are no downloads at this time. If this is the case, no firmware updates are available for your Toshiba TV. Check back periodically, as firmware updates are released as needed and aren't scheduled.
  10. If there is content in the Downloads section, look in the Category section for an item titled TV Firmware. If this option doesn't appear, no firmware update is available. However, if this option does appear, click the clickable link associated with the firmware. The TV Firmware Update and Release Notes dialog box appears. In this dialog box you can see the size of the firmware update file, when it was released, exactly what it addresses and more.
  11. Click the red "Download Now" button and save the file to your connected USB flash drive.
  12. Extract the contents of the ZIP file on the USB flash drive.
  13. Disconnect the USB flash drive from the computer after the firmware update file saves successfully to the device.
  14. Power on the Toshiba TV and then connect the USB flash drive to the USB port on the Toshiba TV.
  15. Wait a few moments for the "Firmware file is detected in USB" dialog box to appear on the screen. Select "Yes" to update the firmware. A progress bar displays on the screen. Be careful not to turn your TV off while the firmware is updating. The progress bar changes to a "Success!" message after the update successfully installs.
  16. Disconnect the USB flash drive from the TV and then restart the TV. After the TV restarts you can resume using the TV as you normally would.
May 22, 2014 | Televison & Video
Mitsubishi WD-60638 firmware
Make sure software was in top menu in USB stick. Not ib a folder. Try reset buttons on front of TV. Could be bad e2p module. (boot firmware.)
Mar 30, 2014 | Mitsubishi WD-60638 DLP TV
Firmware update for LG bp125 gone bad
I ran into issues updating my BP125 to the LG_BD_7300M51.ROM firmware with a USB drive but was able to work around them. I think they occur because the BP125 expects the firmware to be in the upg_all subdirectory during part of the update. To successfully update, it needs to be in upg_all on the USB drive. If you update with LG_BD_7300M51.ROM firmware file in the root directory, the Bluray drive won't complete booting but a workaround can restore the Bluray drive. Here are the steps I took:
First, I tried to update with the LG_BD_7300M51.ROM file in the root directory on a USB drive. The update found the firmware, started the update, then powered off. I powered the Bluray player back on, and it said the update had failed and gave me an option to update using USB or Network. Neither worked with the LG_BD_7300M51.ROM file.
Second, I downloaded the BP120 LG_BD_7200M51.ROM firmware file, renamed it to LG_BD_7300M51.ROM, and put it in the root directory. The Bluray player found the firmware file, and I updated to it. That put the BP120 firmware on the BP125.
To update to the BP125 firmware, I renamed the LG_BD_7300M51.ROM file to LG_BD_7200M51.ROM and put it in the upg_all directory on the USB drive. The Bluray player then saw the update. I applied it successfully to get to the latest BP125 firmware.
Feb 23, 2013 | LG BP125 Bray Player
I updated my PS3 to OFW 3.55 (via USB), now i want to update the Kmeaw CFW3.55 (via USB) and get the error code 8002F997 (after 78% of PS3 copying the update). It does not work if i try the update in...
8002F997
- This error is caused by an issue with updating the PlayStation 3 firmware by USB drive. Ensure there are no problems with the USB drive. Download the firmware update to the USB drive again to ensure the firmware file is not corrupt. Try the installation of the firmware again. If all else fails, update firmware over the network.
Sep 14, 2011 | Sony Playstation 3 (PS3) Console
I have a Vizio Model E420VL and it gets into a state which the audio does not work (from HDMI input #1) and remote control processing in the unit also does not work. I had played around with the side...
hi,
It can be difficult to get things right on the first try. With that truism in mind, Vizio Incorporated includes USB ports on their televisions that you can use to load firmware updates onto the television. Vizio has released firmware updates only for certain television models, and the instructions for installing firmware updates vary slightly by model. To upgrade your television's firmware, you need to download and copy firmware drivers to a USB flash drive and then read and follow Vizio's specific installation instructions for your model.
1. Connect the USB flash drive to your computer
2. Click the "Start" button, and click the "My Computer" icon.
3. Right-click the flash drive, and click "Format" in the menu
4. Select "FAT32" in the drop-down menu, and click the "OK" button. Windows will format your USB flash drive with the FAT32 file system.
5. Open your Web browser, and navigate to the Vizio support Web site at www.vizio.com/support.
6. Click the "Select Your Product" drop-down menu, and select your model of Vizio television from the list. A new page will open that displays available downloads for your television
7. Click the "Firmware Update" link, and save the firmware update file to your computer.
8. Click the "Firmware Instructions" link, and read the instructions specific to your Vizio television model.
9. Right-click the file that you downloaded, click "Rename," and then rename the file to the exact name that is specified in the firmware instructions 10. Right-click the file, and click "Send to" > "E: USB Drive" or whichever drive letter corresponds to your flash drive. The firmware update file is copied to your USB drive 11. Right-click the "Safely Remove Hardware" icon on the right side of the Windows task bar, and eject the device from your computer
12. Disconnect the USB drive, and plug it in to your Vizio TV's USB port.
13. Follow the steps in the firmware instructions to install the firmware update to your television.
Only you can find is the problem with firmware by udating the frimware of your tv. ok
Aug 05, 2011 | Vizio E420VL 42 in. HD-Ready LCD TV
I have ncomputing L300 thin client with usb port. I attached Cannon Laserjet LBP2900 to thin client usb. also installed drivers on host. printer is detected & shows printer ready. but when i give...
Since you posted this four months ago, there has been some major updates from NComputing to improve the USB architecture. This should improve support for peripherals such as your printer. Download the latest software for either W2K3 (v4.9.5) or W2K8r2 (v6.1.3) and update your system. Lastly, it is critical, and I mean absolutely critical, that you update the firmware on the L300 as well. The firmware is included with the vSpace update so once the host is updated, go to the L300 and tell it to update the firmware. The current firmware version that works with v6.1.3 or v4.9.5 is v1.4.1. As of this writing, 8/16/11, those are the current versions.
Apr 21, 2011 | NComputing L230 Network Terminal
GRAPHIC TABLET GENIUS G-NOTE 7100 DOES NOT WORK AFTER FIRMWARE UPDATE
The new firmware does not work, it disables the device LCD screen but the device is working, take batteries out, put them in to be sure the device is off, press DELETE+NEW and plug the usb with those keys pressed, release them, launch the program you used to flash the firmware and burn the original one (located on a directory in the download files). Once the process is finished, unplug the USB and voila you have your tablet working again. We should contact genius to tell them that the firmware update does not work.
Jan 07, 2011 | Computers & Internet
I can not connect my cradlepoint mbr1000 to my new time warner usb wipipe. it works with my laptop but will not connect to the cradlepoint
You may need to update the firmware on your CradlePoint. Newer firmware supports the release of new modems, which you might have a version of firmware on your CradlePoint that does not "know" your Time Warner USB stick.
Here's how you update the firmware:
http://knowledgebase.cradlepoint.com/questions/13/Updating+the+Firmware+on+your+CradlePoint+Router
Aug 31, 2010 | Cradlepoint Personal Hotspot 80211BG...
How to update sharp aquos lc32d64u firmware. won't read from usb device to update S0803271 to S0909081. firmware name is "SAL2A217.UVP"
I was able to successfully update my Sharp's firmware by using a USB drive that was:1) formatted in (fat, not fat32)2) had only the one update file (.uvp) and3) a small USB drive (4gb - other posts said 2gb or less)
Feb 08, 2010 | Sharp LC-32D64U LCD TV
No USB mode in Settings menu c250
Updating firmware video
http://www.youtube.com/watch?v=kVLoG4FWEjc
Jan 22, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Pioneer DV-420V-K DVD Player Logo
22 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
