Question about Vacuums
My D4C SE doesn't have good sucktion now after getting the brushes replaced
Vacuum started to squill and smoke so our repair shop replaced the bearings and brushes now it doesn't have the suction it has had in the past. Should I replace the complete motor now?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 134 Answers
Check all your filters first and the hoses first
Posted on Feb 11, 2014
reddevil6
  • 1673 Answers
SOURCE: Rainbow E Series Suction Problem
Being an E series some have a corrgated filter in the top, there is also a filter on the back. Could be a motor problem, not turning as fast as it should, in which case you will have to replace the motor. You might check, some had a 10 year warranty on the motor. If you are the original owner and only have had it 5 years, then it may be covered.
Posted on Jan 19, 2008
  • 4088 Answers
SOURCE: brush spin,good suction at hose, no suction at
Air passage from back of brush head, through the joint, and up to bag, may be blocked.
Posted on Jul 12, 2009
nwj2468
  • 76 Answers
SOURCE: My Bissell cleanview is NOT suctioning well, all
did u check the filter above the dirt cup?
twist the yellow piece and wash the filter
Posted on Aug 22, 2009
SOURCE: motorized brush bar not turning on Dyson Vacuum
Apparent common failure is that either the thin yellow and or blue motor drive wires that run from the LH side of the vacuum where the "control board" is located down into the hinge / ball area become stretched and then fray and eventually break. Happened to my Dyson twice. First repaired under warranty, second took about 20 minutes. You need a Torx screwdriver to remove the LH panel ( 4 screws) and also an access panel (2 screws) at the side of the ball which permits access to the blue / yellow wire connectors. I replaced with a new wire and connectors having fed the wires through the access hole making sure sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
Posted on Oct 04, 2009
  • 69 Answers
SOURCE: new eureka vacuum has not real suction
Is the belt slipping. Are all the seals good
Posted on Mar 27, 2010
Will D4c se plug into D4c
The Rainbow D4, D4C and SE all are the same vacuum base, only changes were made to the nozzle. As long as the nozzle cord on your D4 has 2 prongs, not 3 prongs you can use the D4 nozzle that looks like This or the SE PE (SE Performance) Nozzle that looks This
Sep 01, 2014 | Rainbow Vacuums
How to fix a vacume that is smoking
any electrical unit that smokes,is ,not worth repairing
Jul 01, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
I want to take apart and clean my D4C Rainbow and my E series 1 speed, I bought both of them on Ebay, and both have odors,( They are suppose to be the vacuum that cleans and purifies the air) that leaves...
Sorry, but a Rainbow D4 has no filtration at all. The E series has a HEPA filter that needs replacing. You can put liquid Lysol in the water on the D4 and that will help
Apr 30, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Is the roller brush supposed to turn when the power is on?? the sucktion is on but the brush doesnt roll
That means that you need to replace the belt which turns the roller brush. Here is the belt you need to replace and the manual which has instructions:
Eureka Altima Belts
Owner's Guide
Jan 01, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Hoover canister vacuum (windtunnel)- turned it on and it had good suction, then smoke came out and it smells like something is burning. Is it the motor burning up or something else?
Probably the belt..
Turn it over so the bottom is facing up..
Remove the plate that surounds the brush..
Check to se if brush is spinning frely and that the belt is on there poroper
Jul 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
What's the difference between the rainbow D4C SE and the D4C?
the se has a newer updated version of the power nozzle. the power nozzle is smaller.the d4c is older
than the se. the attachments are pretty much the same and the se is a darker color than the
d4c
Jul 01, 2009 | Rainbow 75th Anniversary Canister Vacuum
My kenmore hida filter vacuum cleaner no longer has the sucking ability it used to have. It is only 4 years old and has worked extremely well up until this week. The motor is functioning well, as is the...
well i've hade one come in a while ago and it didn't have good suction so I looked at the bag it was buljing w/ dirt so I put a new bag in it and it had better sucktion but still not good enough so I cheched the fabrick filter and it was dirty too so I washed it and it had even better sucktion so try the paper filter on the end too and if your vacuum still haves bad sucktion try looking if the hose is clogged buy putting your mouth on the end and blowing through it i recomend whiping the end off befor blowing if hard to blow it is clogged, if clogged i would put something thin like a metal rod or or a stirty stick to push the dirt out i'm sorry if my info didnt work out :D
Jun 12, 2009 | Kenmore Whispertone 23312 Bagged Canister...
No suction on wind tunnel vaccum cleaner
Your brush might be clogged with hair. while uplugged, flip over the vacum and check to see if there is any hair or string wrapped around the brush...
Jun 03, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Vacuum was used to clean up after plaster sanding.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=645474
Generic problem for all Vacuums
Posted by veronica1113 on Jun 04, 2008
Could the debris from plaster sanding cause my rainbow series D4C vacuum not to work? If so how is the best way to clean it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Rainbow D4C will still work but not @ the highest efficiency rating – the suction will be reduced because the sheetrock dust gets into the motor and the fan blade(s) Quan 3 and would need a professional cleaning 1st or 2nd. Replacement of the motor; if it is too serious and or too expensive. It’s a good vacuum back it is suggested that people use a good Shop Vac for the sheetrock dust removal. Feel free to contact your local vacuum cleaner dealer in your area or you can try to repair and change out the fans, clean out the carbon brush area and cleanup the armature. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 04, 2008 | Vacuums
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
