Whirlpool sm 8280869
Is there an adjustment for the load size selector? "Small" load is way too small.
  • 351 Answers
SOURCE: small dark circles on laundry after washing
if you do cold to warm washs all the time you will get sludge between the drums,try several 95 degree washs with no cloths in it and see how you go .hope this helps.do you use fabric softner.
Posted on Mar 26, 2008
  • 1314 Answers
SOURCE: Washer only fills up 1/2 way.
sounds like the pressure switch is bad
Posted on Mar 11, 2009
garing
  • 998 Answers
SOURCE: water leaking out of bottom - whirlpool top load
tip it to the back look at the pump for signs of water stains or water drops if so replace just 2 clips to remove
Posted on Aug 21, 2009
SOURCE: small front loading maytag lhw0050pq needs minor adjustment
I had this problem and just had to clean teh fliter . it is on the bottomright hand corner of teh front of teh machine. there will be a bunch of water in there so it could be messy.
Posted on Aug 25, 2009
drsn
  • 42 Answers
SOURCE: Whirlpool Washer model # LSN1000KQ0 overfilling
did you plug the hose back into the water level switch, double check to see if it is plugged, if it is your water level switch might be defective. trouble shoot by taking the front panel off... turn on the washer by using the timer, set water level to small...on the bottom of the tub housing there should be a nipple where the clear hose connects onto.....follow the clear hose from the switch down to the bottom of the tub.........disconnect the clear hose on the bottom of the tub.....plugg the nipple with your finger.........gently blow into the hose with your mouth.......but make sure the water level in the tub is at least at half way full...and the washer is on and filling up with water ...after you blow into the hose the washer should agitate.......if it does agitate your water level switch is defective...connect hose back........get your model number and source for the switch.........
Posted on Apr 10, 2010
Testimonial: "drsn helped me diagnose the problem in two short postings. Rock on Dude. I really, really appreciate your help."
No problem as yet. Just purchased a whirlpool front load top of the line. The instructions are very good except I can't find any instructions regarding adjusting the water level for smaller and la
For the Whirlpool WFW96HEAC front-load washer, the water level adjustment is made by the washer based on the size of the load. If only 3-4 items are in the tub, it will do a small load. If you fill the tub completely, it will do a large load. (Note: if the clothes are packed into the tub, they can't tumble and won't get cleaned.) Loading the tub with clothes until it is 1/2 or 3/4 full are the other load sizes.
Please add a comment with the model of your washer, I'll be glad to give additional help. I hope this helps.
Mar 01, 2013 | Whirlpool Washing Machines
If I have a small amount of clothes to wash, will the water level adjust itself?
the unit may due it due to the load size but the unit is only using about 2 -4 gallons of water depending on load, and only 16-18 gallons through the whole wash cycle, I hope it helps
Feb 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Load size select nob is stuck in small load position & i can't get it to turn
the selector knob has finally taken a dump and needs to be replaced the part number you need is gonna be located on the back of the selector without a model number i have no way of looking it up for you
Jul 23, 2010 | Whirlpool LXR9445JT Top Load Washer
Apr 10, 2010 | Whirlpool Washing Machines
How do you set the Cabrio to wash a small load?
this one only has 1 setting on water level. same size uses same level
Feb 25, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Ice maker only fills the tray partially.
There is an adjustment, but first check your filters, including the one in the inlet of the control valve. To find the adjustment, take the cover off the front of the ice maker. On the side may be a little hole. Look for any 'increase' arrow or such. If not, use a small screwdriver to turn the adjustment a half turn and let it make a load of ice. If it gets smaller, go the other way, use small adjustments. If you can get the owner's manual, it will help a lot. Google your unit for one, you may be able to get it downloaded free from Whirlpool.
May 05, 2009 | Whirlpool Freezers
The washer only fills up full even when I put the load size on sm
Check the other knob or switch on top. Perhaps it has some settings regarding small, medium, or large load. This switch may be defective. Go to
www.repairclinic.com for more help on removal and replacement. You can also order a new one from them.
Mar 14, 2009 | Washing Machines
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
