Question about Samsung RS263TDRS 25.5 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door
Controller flashing
I change two board on the back. After that two bars of freezing controller start flashing
  • 41 Answers
Hi
Check your defrosting elements and sensors.
Posted on Feb 23, 2014
Freezer side not freezing
Check for ice / frosting inside the freezer .... If present you probably have a defrost problem.... This causes the freezer coil to ice up and block the air flow ... the causes could be a bad defrost heater , defrost timer, defrost sensors, or control board. Also make sure that the condenser coil is clean. remove ALL dust with a vacuum and a coil brush .the coil is located either on the bottom or on the back side of the unit... You didn't give the Make and model #
Apr 04, 2014 | Freezers
Control board and wiring harness which are supposed to replace Frigidaire 242000406 are apparently not correct. I have now installed 2 of the new control boards and I am unable to get any power to the...
Hello Gentlemen;
My name is Peter; I am a retired field service refrigeration technician.
The two of you are on the right track.
The board that you replaced;
Substitution: 5303918498
The electronic control board controls the major electro-mechanical components in the refrigerator. When the electronic control board senses the compressor needs to run to cool the refrigerator, it sends voltage to the compressor and fans. It then receives input from temperature sensors to monitor the temperatures inside the refrigerator and freezer sections.
This is a substitution and can not communicate with your existing electrical control board. You need tor replace this board was well:
Substitution: 241973711 Cost: $83.00
The electronic control board 241973711 controls the major electro-mechanical components in the refrigerator. When the electronic control board senses the compressor needs to run to cool the refrigerator, it sends voltage to the compressor and fans.
When you plugged in your old board and got power, that is because the two boards were communicating.
When you change the board be careful to ground yourself by touching something that is bare metal. Static electricity will knock out a board.
The Electrolux Frigidaire Refrigerator is a good unit. It should last you 20-30 years. If you want a unit that is in constant repair, buy either a Samsung or LG. They have the highest failure and repair cost of all of the manufacturers.
Aug 09, 2013 | Electrolux Frigidaire Refrigerator Control...
Temprature blinking
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Jul 07, 2013 | Freezers
I have " E
E1 - Control board problem
Notes: C, E
C:
Disables clean mode in Thermador device, allows cook and microwave
E:
1. Turn the clock selector knob to OFF
2. "Tweak" the oven control by turning the clock selector knob slightly to the left
(counter clockwise).
This may stop the flashing message/beeping and clear the display window.
Hope helps.
Jul 24, 2011 | Thermador T18BF70FSE Freezer
I have a frigidaire upright frost free freezer model number is FFU2065FW3 I put in a new electronic temperature control Board and when I plugged the freezer back in, the control board was flashing "E" and...
OK, this is a failed controller board, any E4* is Power supply & Controller Board, probably caused by a power spike.You need to get the unit looked at to see if it is able to be repaired, and if parts are available. If you wish to try and repair this yourself, you must get a service manual, to do so, and to be able to order parts.
Apr 03, 2010 | Frigidaire 20.3 cu. ft. / 575 liter...
Hoshizaki ice machine KM500-MAE not sending water to harvest
I would not change the pump. If it runs for 3-5 minutes and stops, it has to be a control. The control board runs the freeze cycle for the first 5 minutes. This prevent "Short Cycling" of the freeze cycle. The board looks at the float after the first 5 minutes for the proper water level but should not effect the pump. If the pump does not run in the wash mode, check out the "Power/ Wash" switch. I would start there before I go spending hundreds on pump motor or control board. You may be able to get by on a $20 fix! Do this and get back to me. We will get it going.
Good Luck
May 06, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Servis frostfree fridge freezer
Hi, I had that last year - It was the control board!
Oct 24, 2008 | Freezers
Hoshizaki Ice Machine Model KM-500MAF
(Quated From Hoshizaki Technical Bulletin)
An alarm code of 3 beeps
every 3 seconds means that the control board has shut
down on the 60 minute freeze cycle back up timer.
The “E” control board has a 60 minute timer that starts at
the beginning of the freeze cycle. If the float switch fails
to open and start the next harvest within 60 minutes, the
board will automatically start the harvest cycle. If this
occurs in two consecutive cycles, the control board will
shut the unit down on the manual reset, freeze cycle
back- up timer. The yellow fault LED marked “60 min.”
will illuminate. This safety is designed to help prevent a
freeze up of the evaporator.
Once you have identified the 60 minute alarm, there are
several things to check. Reset the alarm by depressing
the white reset button to the right of the fault LED’s.
This must be done with the power “ON”. Now check the
float switch to see if it is stuck in the up position. A stuck
float can occur if scale is present on the reed switch
shaft inside the housing. To check it, drain the water
reservoir, unplug the black float switch connector (K5)
from the control board and check it with an ohm meter
for a closed switch (zero ohms). If the float switch is
sticking, clean it with ice machine cleaner or replace it as
necessary.
An inlet water valve which is slowly leaking by during the
freeze cycle can cause a 60 minute alarm. If the inlet
water valve is stuck wide open, it is unlikely that any ice
will form on the evaporator. Check for a slow leak by
allowing the unit to cycle into the freeze cycle and
disconnecting the hose at the outlet of the water valve. If
water leaks by during the freeze cycle, the water valve
diaphragm is likely damaged or the small diaphragm bleed
port is clogged with scale. Clean the bleed port or replace
the diaphragm or entire water valve as necessary.
(I Recommend to get a refrigeration tech for this part).
Another possibility is a refrigeration system problem. You
should use normal refrigeration diagnosis procedures to
check for one of these problems. If the thermostatic
expansion valve is not feeding properly or the refrigerant
charge is low, the evaporator will not form ice as it should
and a long freeze cycle will occur. This could also be the
result of the hot gas valve not closing completely during
the freeze cycle or if the compressor valves are weak or
inefficient. An inefficient compressor however, will
usually show up first on the KM model through a longer
than normal harvest cycle. This is because of cooler
than normal discharge gas. Use proper refrigeration
practices to repair a refrigeration system problem.
While these are not the only reasons for a 60 minute
freeze cycle, they are the most common and should be
checked to resolve a 3 beep/yellow fault LED alarm.
Feb 27, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Cannot control internal temp plus clicking relay on control panel.
Where is the fast defrost button on Kenmore chest freezers?
Nov 20, 2007 | Freezers
Samsung RS263TDRS 25.5 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Logo
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
