Question about Hamilton Beach Kitchen Appliances - Others
Levers will not latch - Hamilton Beach Kitchen Appliances - Others
Hood won t close
Check out the cable connection between the latch and your internal latch control. Till you locate the problem I would suggest tying down the hood with some sort of strap so it does not pop open at speed.
Apr 24, 2017 | Chevrolet Malibu Cars & Trucks
Passanger side door locking problem. when I insert the Key, it can turn forward to lock the door, but can not turn backward to unlock the door. And I tried the second key, does not work either.
Really sounds like one of 2 possible problems.
First, perhaps the door latch itself is broken, and that is unlikely, except that I am unfamiliar with that particular latch on that particular car.
Second, it sounds like, if you were to take the door panel off, you would find the latch is locked because one of the locking levers is holding the door latch locked.
There or 2 or 3 lever like things that affect the latch.
There is a lever from the outside door lock that goes to the door latch.
There is a lever from the inside locking handle that goes to the door latch, and yet may be one more.
If any of these are "stuck" or broken, they will "hold" the door latch in the locked position.
Be blessed.
Feb 07, 2013 | 1998 Nissan Altima
I have a 98 eddie bauer ford explorer I can not puss the hood down and make it latch, how do I fix that problem fix it so it latches down?
the lever for the release cable is probably rusted up. If you look down into the latch you should see the cable attached to a lever. It may help to have somebody pull the hood release to help you find it. Spray the hood latch with some penetrating lube and push the lever back with a small long screwdriver. Be careful not to dislodge the cable from the lever. Pull on the hood release and if necessary push on the lever with the screwdriver. Continue lubing, pulling and pushing until everything works on its own.
Feb 14, 2012 | 1998 Ford Explorer
Kitchenaid artisan ksm150 - Motor Head Locking Lever stuck in locked position
Get a copy of the Repair Part List of your model from Kitchenaid.com
Remove the Motor Housing (1). The Latch Lever (3) is connected to the Latch (10)
and held in place to the Lower Gearcase (5) by the Latch Bearing Screw (8). This
screw is visible from the outside and located near the Latch Lever.
Tighten this screw to fix your problem.
Aug 03, 2011 | KitchenAid KSM150PS Artisan Series Stand...
How do i open the hood.
there should be a lever that is on the bottom edge of dash that is under the steering wheel along the trim. if the handle is broken you can use pliers to grab the cable and pull it to get the hood to realse. if you found all that and i seems to work ok then when pulling the release lever have a friend hit or shake the hood to get it to pop up a little so that you can open it all the way.
Nov 20, 2010 | 1997 Ford Explorer AWD
Microwave door will not latch closed
I just had this problem with a Samsung microwave/hood combo. I pried/popped the inside molding out with a screwdriver. The little lip that the spring attached to had broken. I drilled a hole in the center of the door latch, reattached the spring, replaced in door, replaced inside decorative molding, and fixed in 5 minutes. Thank goodness because it's such a pain to replace these units.
Jun 30, 2010 | Neff B4540 Stainless Steel Electric Single...
Replacing the lever latch
Look at the parts diagram in the following:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212057.pdf
and in particular:
9 24452 Latch, Link & Lever
Hope that helps you figure out where the parts go.
Apr 07, 2010 | KitchenAid Classic Stand Mixer
Trunk latch on 2002 Civic EX 4-Door won't close
trunk latch cable probably needs to be replaced
Jul 06, 2009 | 2002 Honda Civic
Door (tailgate) won't open...the handle extends but doesn't open
there is a lever that the handle slides into on the latch. the lever over time bends and the handle doesn't pull on it. try pulling on an angle either to the left or right. you might need a new latch as the lever is part of the latch.
Mar 07, 2009 | 2005 Ford Expedition
Kitchen Appliances - Others Logo
56 people viewed this question
Top Hamilton Beach Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
ken skalski
Are you a Hamilton Beach Kitchen Appliances - Other Expert? Answer questions, earn points and help others
