Laptop vga to vga on ilo tv not supported - Televison & Video
2 Suggested Answers
SOURCE: ilo 42'' says no signal on VGA when connected to a computer
Snap off/fully remove pins 11, 12, and 15 from a spare VGA cable and use this to connect the ILO tv. These pins are used for identification of the monitor by the PC. The video signal is now displayed perfectly on my ILO tv, in all supported resolutions.
Posted on Jul 17, 2010
S-viedo from laptop to ilo model iwt3206 is it possable
Can't do an s-video just hook up rgb/vga cable from laptop to tv and put the input to rgb/vga.
Nov 20, 2011 | iLO IWT3206 TV
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
How to hook up a laptop to ilo lfw to watch dvds
You can use VGA cable between the TV and your laptop. Attach the TV to the VGA port BEFORE turning on the PC, turn on the PC and hopefully it will detect the external monitor first, if not, then you have to use the HOTKEYS function (Fn key and One of the key with monitor symbol). The HOTEKEYS function will allow you to select both internal and external at the ame time , or just the internal only, or external only. You will also have to set the refresh rate for he external to be at 60Hz and the resolution not to exceed the maximum the TV can handle, should look to see what the native resolution of the TV is in PC mode.
Nov 03, 2009 | iLO IWT3206 TV
Can i connect my laptop to the tv?
Yes there is a way to connect the laptop to the TV via VGA output. You can easily connect most of the laptops to TV via VGA and your notebook is fine for that purpose as well.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 07, 2009 | Toshiba Satellite L305-S5933 Notebook
Ilo 42'' says no signal on VGA when connected to a computer
Mar 11, 2009 | Televison & Video
Hook computer to ILO tv
The best way is to buy a graphics card with HDMI output. This will dsplay your PCs desktop the way it's supposed to look, and will appear much sharper and clearer than using vga, as the output is digital to begin with. If you don't need to play the latest games, you get get one for around $30. Add a wireless mouse and keyboard and you'll be able to control everything from your armchair. You can also then use your PC to download and watch films etc from the internet..
Jan 06, 2008 | iLO V27DMBX Television
ILO LCT32HA36 as PC Monitor
What resolution are you using?  It might not work if it's set any higher than 1366x768.  And set the refresh rate to 60 Hz.
Dec 08, 2007 | iLO LCT32HA36 Television
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
Ilo 27inch hdmi hd tv monitor
You would need to connect a VGA + Audio to HDMI Converter. The downsize it the converter goes for about $150 us
No signal
Weegee, Unfortunately you are trying to mix two different video types: VGA is an analog video interface found on most computers (except for latest with flat panel monitors, which are usually DVI). Your TV DVI interface is digital (although there is a DVI-A, which is an anlog DVI interface, it is unlikely that your TV has this). So, what you are trying to do probably won't work. I assume your computer does not have DVI output (otherwise you wouldn't have bought the adapter), but some monitors have VGA inputs; does yours? What kind of DVI adapter did you get? Is a DVI-A? Check out http://en.wikipedia.org/wiki/Dvi for info on DVI interfaces.
May 12, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
