Question about Casa Vieja Dryers
Light kits which kits will work for this product
Xerox 8560 Maintenance Kit remaining life
You're probably lucky that your machine still works after using non-xerox products, in any event, I'd suggest a new Xerox Extended kit, it's possible the non-xerox product didn't work as intended and your replacement kit wore out faster because of it.
The kit contains a micro chip which "resets' the counter in your machine, as the count comes from the kit, not the machine itself, however, the machine is capable of sensing when the maintenance kit has reached end of life regardless of count.
Additionally, you should check the wiper blade (you can see it when you remove the maintenance kit) for excessive wax buildup which generally means the machine needs service.
These are great printers, very fast for the quality. They can be quite a nightmare to service due to so many systems which have to be exact!
My #1 advice on this product is if you own one, never ever move it while it's hot! or you could face a very expensive repair!
Mar 27, 2014 | Xerox Phaser 8560N Laser Printer
Maintenance reset
Reset the maintenance-kit counter
1. Turn the product power off and then on.
2. When XXX MB appears on the control-panel display, press and hold down the OK button until all three control-panel lights flash once, and then stay on. This might take up to 10 seconds.
3. Release the OK button and press the up arrow to scroll to NEW MAINTENANCE KIT.
4. Press OK to reset the maintenance-kit counter.
May 22, 2013 | HP Laserjet P4515x Printer
Club car brake light not working
2008 precedenmt golf cart dash light keep coming off an on
Mar 02, 2013 | Power Equipment Solutions 2002 Club Car DS...
Sun damaged / faded headlamp lenses on VW passat i have been told that it can be polished out and then have a film applied i would like to nkow about specific products and process to restore lense
Thers a product i use, this is made by 3m, its a 4 step product, first you sand, then sand again with a finner sand paper then you use a wheel with a cleaner on it and last you polish the lens and it comes out good, the key is to sand it good and take your time, napa sells this product, this kit comes with everything all you need is a drill,a good drill. good luck, also if you google 3m headlight restoration you will see theres even a video on youtube that will pop up, becareful theres a kit for 379.00 thats not the one, the kit i speak of is about 25.00 and will do a few sets of lights maybe two.heres a picture of it.
http://www.youtube.com/watch?v=_t1RBw0IGXAjohnjohn2_81.jpg
Mar 17, 2011 | Volkswagen Passat Cars & Trucks
Wireing a pig tail onto 95' jeep grand cheerokee.
The kits are great, they work, They eliminate the need for running extra wires for the brake and blinker, they don't mix well. Also, you need a real good ground on your trailer or you will get dim lights, or no lights at all.
Feb 15, 2010 | 1995 Jeep Grand Cherokee
I recently had a flat battery and tried to jump start my car. Since this day, the Sony Ericsson HCB-300 Bluetooth kit hasn't worked, and I cannot locate the in line fuse. There is not light or power going...
The main question is about the power supply and especially with the 12 volt dc and the 12 volt ignition.
Maybe the car kit has been installed without taking account of the 12 volt ignition which is important to unpowered the kit and preserve the product more longer.
Sometimes no ignition on the key.
I do not know what sign on the sony, but in some vehicle on the market you have to inverse fuses to make it working longer.
Some of the car kit can work during a certain time, but a day to an other will not working any more.
Feb 01, 2010 | Sony -Ericsson OEM HCB-300 Bluetooth...
Replace/clean headlight lens - 1998 Buick Century
At my shop we have a product from Ever-Wear, it is a headlight restoration kit, do it on the car and works great. Did one light on my car and left the other one foggy as a demo. Great Product
Nov 16, 2008 | 1998 Buick Century
Can't find light kit for altura 68 in.
Last time i bought it from amazon, take a look Amazon com altura 68 light kit. hope this was helpful. cheers
Aug 05, 2008 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
27 people viewed this question
Top Casa Vieja Dryers Experts
tsalagi152
Stan Ford
Tom Chichester
Are you a Casa Vieja Dryer Expert? Answer questions, earn points and help others
