Question about Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with EZ-Change Ice and Water Filter
Stopped making ice
Stopped and then started 3 days later with no repair now stopped again on 7th day
  • 531 Answers
SOURCE: ice maker stop making ice
if you have water filter check it or your icemaker is bad or water valve
Posted on Apr 02, 2009
  • 3 Answers
SOURCE: ice maker not making ice
i had same thing happen the line going to the ice maker was froze i too everything out of frezzer and let line unthaw for about an hour now works fine
Posted on Apr 28, 2009
hiltonjug
  • 612 Answers
SOURCE: 3 month whirlpool refrig. whole system seems to be shutting down.
You most likely have a bad pc board. If I were you I would call Whirlpool and have them send a technician out and fix it under warranty. The number should be on your paper work that came with unit. If not, call 1-800-555-1212 and ask for the number. I could try to help fix but if you mess with it, the warranty will be voided.
Posted on Oct 16, 2009
  • 1214 Answers
SOURCE: the ice maker continues to jam. after this happens
Sounds like the mold heater or something in the mold heater circuit (mold thermostat, heater switch, etc.) has failed.
These ice makers are cheap, and can be purchased from Lowe's or Home Depot, if not from Sears. Just make sure the new one has the same plug on it that the old one uses. Don't splice the wires to make the new one work where the old one was!
Posted on Dec 11, 2009
  • 256 Answers
SOURCE: Fridge makes clinking noise periodically
If the noise is only heard when you activate the icemaker, then your problem is probably with the icemaker. Some icemakers make more noise than others. If it's unbearable, replace the icemaker.
Posted on Feb 19, 2010
Where can I get a repair manual for a Hotpoint Fridge
First of all, the model number you gave is not complete. But check you defrost system in the freezer, when the refer section stops cooling, your evaporator in the freezer is possibly full of ice and the fan won't move air through ice. When the refer sections fails to cool, check for a fan in the freezer. If it works, you have a defrost problem and is occurs every 3 - 5 days. The unit should defrost once or twice a day. Good Luck
Apr 20, 2016 | Hotpoint Refrigerators
MY MAGIC CHEF IWORKS FINE 2 TO 3 WEEKS A TIME ,AFTER 3 WEEKS IT STOPS COOLING - I REMOVE EVERYTHING OUT FRIDGE AND UNPLUG IT FOR A DAY ,A DAY LATER I PLUG BACK AND IT OPERATES FINE FOR ABOUT 3 WEEKS AND I...
Hi and welcome to FixYa, I am Kelly
Without your model number here is what most likely has happened:
The automatic defrosting system is not working due to a component failure.
The components of the automatic defrost system are:
1. Defrost control
2. Defrost heater
3. Defrost thermostat.
4. Wiring to inter-connect 1 - 3 above.
What your currently doing is a manual defrost cycle every 3 weeks because ice blocks the air-flow across the evaporator in the freezer compartment so everything starts warming up in the fresh food section first and finally the freezer as the ice block gets larger.
FYI you can unplug it... remove the contents from the freezer...use an external directed into the freezer compartment for just over 2 hours to do the same process your doing in 24 hours. Until the automatic defrost system is repaired you should do a manual defrost at least every 4 days.
Most units are on an automatic defrost cycle of 6 - 8 hours (usually) all the way up to 10.35 hours per cycle. Yours just is not working at all.
Thanks for choosing FixYa,
Kelly
Kelly
Aug 15, 2011 | Refrigerators
KENMORE 106.53644300 ice maker type 2 with front door dispenser. ice maker stopped making ice, than 3 days later started again then stoped, day or so later ran again then stopped. I removed the unit put...
That is a Whirlpool module type ice maker that seems to have has been so strict with their information I will need to give the manual's another way about a 5 year life span. I have some manuals but because Whirlpool stopped letting people post what they believe is their property. I guess I need to only understand but if I place them here I will lose my subscription. Click Here=> My E-Mail and I will send it to you. May have to fill out the capsha first. Below is what I am talking about as far as how they work and yes I have the schematics and tech sheets, I will look to hear from you, Thanks, Sea Breeze
Click Here=> 8201515 Ice Maker Module
May 05, 2011 | Kenmore Refrigerators
From time to time stops working and making a noise like boling water
A refrigerator must defrost 2 - 3 times a day. It does this via the automatic defrost cycle. When the cycle starts alll motors shut off and there is a heating element that is in the evaporator / freezer section of your unit. That heating element melts the ice until the 60 Deg F bi-metal thermostat cycles and terminated the automatic defrost cycle. During the defrost cycle is is normal to hear a hissing sound as the melting ice drips on the heating element assy. Addiionally you may hear coolant gurgles as the unit shuts off to start the defrost cycle and the coolant system equalizes the internal pressures between the pressure and return lines. Again another normal sound. If your unit did not stop to defrost 2 - 3 times a day in a matter of 3 to 4 days you would have a large block of ice in the back of your freezer section and the evaporator fan blades would be hitting that ice block. The freezer would say cool yet probably no longer make ice. Also the fresh food compartment would start warming up. Hopefully this resolves your concerns. If you need more assistance just respond to this post and I will help you.
Thanks for choosing FixYa.
Kelly
Sep 05, 2010 | AEG S72348KA ST STEEL Refrigerator
We have an Amana side by side D7535470. One day the ice maker just stopped working and then about a month later out of no where it started to work again. But then that same day my freezer started making a...
Yes, I can tell you that your unit is frozen up and has a bad defrost system in it now. This is a simple repair and your fan is hitting the frozen ice. You should unplug it for a few days and let the ice thaw out completely before replacing the defrost system.
You can contact us at accurate-appliance-service.com.
We hope this solves your problem.
Oct 28, 2009 | Refrigerators
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore fridge stopped cooling
sounds like its freezing up on you. check the drain outlet and make sure that its clear. also i would replace the defrost timer on this unit because its suppose to bring on the heaterfs to melyt the ice so thaat yoiu don't have to. they are around 30 mdollars at the appliancew repair store and all you need is the model number and serial number for the uit. after you get it it's either on the very top of the refrigerator section or in the very back. It has 4 wires going to it. good luck.
Jan 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
ICE MAKER
See the following fixya thread:
http://www.fixya.com/support/t127529-water_ice_dispenser_not_working
Dec 14, 2007 | GE GSS25JEMWW Side by Side
Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with EZ-Change Ice and Water Filter Logo
23 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
