Question about Endurance Exercise & Fitness
Parts for treadmill
Plastic wheel cover
Where to buy trimline 7050 motor cover(plastic)
Trimline Treadmill ' eBay
www.ebay.com/bhp/trimline-treadmill
eBayGREY TRIMLINE TREADMILL MOTOR HOOD HOUSING KK-2439 FRONT ENDCOVER PLASTIC. $45.00. Buy It Now. This auction is for a good used treadmill ..
Jan 05, 2016 | Exercise & Fitness
Where can I find parts for my vitamaster 2 treadmill
Go to this link, http://www.searspartsdirect.com/partsdirect/brands-products/Vitamaster-Parts/Treadmill-Parts
Jul 01, 2015 | Exercise & Fitness
How to open the box of the treadmill
You have to lift up the back of the treadmill a little to access 2 phillips head screws that keep the motor cover on, (note that you will also have to unscrew a few phillips head screws on the bottom front of the cover as well in order to remove it completely). Before you begin lifting the back of the treadmill platform off the ground to access the screws underneath make sure the treadmill is on a zero incline setting and it helps to find a sturdy object you can rest the tail end off the treadmill on about 1 to 2 feet above the ground giving you enough room to access the screws underneath. Another option is to lift the treadmill platform all the way up and lock it in an upright position using the locking mechanism and lock handle that is located underneath the machine. I find this route to be unnecessary and cumbersome for what you want to do. Once you lift the treadmill up you will see the 2 small Phillips head screws near the front of the treadmill running platform that you need to unscrew in order to take off the motor cover. You also need to unscrew a couple small screws under the machine located on each side of the wood running board. These screw fasten the top inner plastic side covers onto the top of the running platform which needs to be taken off in order to access the back rollers. Make sure you collect the screws in a way that you will remember where they go later when you reassemble as this is your first time taking them out and you might forget later. Now with the bottom screws out, lower the back of the treadmill down level on the ground and pull off the motor cover, and the Left and Right INNER plastic running platform covers. With the inner covers removed you will find yet another small set of screws fasting the main plastic side covers to the running board which require an allen wrench to unscrew. Use the small wrench that came with the machine if you have it handy. With those off you can pull the main Left and Right plastic running board covers off, just make sure to carefully unsnap them from their snap points near the bottom rear of the machine. With all the covers removed you can now access the bolts that hold your treadmill rollers in place and the drive belt which you will have to slip on and off the motors drive pulley and the front roller using a pull and turn technique. The back rollers are simple and can be removed by unscrewing the tension bolts at the back of the treadmill and pulling the roller through and out of the belt. With drive belt set aside and all roller bolts removed you can take out the front roller in the same way you removed the back roller. Replace the treadmill belt and reassemble the machines components in the reverse fashion you disassembled them using these instructions. Doing this yourself will save you hundreds of dollars service man visits in the future.
Jun 27, 2014 | Epic View 550 Treadmill
How do you remove fly wheel?
Before you try removing flywheel look for wear on the outside shrouds covering the fly wheel area and adjust if need be. If you need to remove flywheel you have to remove the arms first before taking off flywheel shrouds to exspose inners this project will take you some time
Jun 24, 2014 | Golds Gym StrideTrainer 595 Elliptical
TX 5.0 RC just stopped a # 3 came on the screen. After reading several posts we looked at a wheel within the motor compartment(not the wheel with the belt, it's the wheel to the left if your looking...
Info from PDF files located on Sportcrafts website under manuals.
E3 - No speed sensor reading. Unit shuts down. This is the most difficult repair diagnose. The speed
sensor is connected to the frame of the treadmill near the drive pulley on the front roller. There is a
small magnet on the side of the pulley wheel. The sensor tip must be no more than 5mm from the
magnet. If for any reason the distance is greater than 5mm the treadmill will shutdown
Adjust or replace speed sensor.
Treadmill: Speed Sensor Replacement
1. Make sure your treadmill is unplugged before you begin.
2. Remove the motor cover located in the front of your treadmill, it is held on by a few screws.
3. Locate your speed sensor; it is the small T shaped part with a red and black wire coming from it.
4. Remove the 2 screws in the speed sensor and remove the old sensor.
5. Place the adjustment holder on the frame with the open holes facing the pulley wheel, the prongs facing
up and way from the pulley wheel. Insert the screws but don't tighten fully.
6. Now place the speed sensor over the prongs with the square part facing the pulley wheel and the red and
black wire to the far right.
7. Plug the treadmill back in and slide the speed sensor until it is 5mm from the magnet inside the pulley
wheel, you may have to do this several times until you can position it so it no longer shuts down. Use 2
nickels to figure out the spacing. The width of 2 nickels is 5mm.
8. Once you find the correct position tighten the screws all the way; being careful not to touch any of the other electronics
9. Place the motor cover back on and enjoy your machine.
Also:
Use an epoxy to glue it. It is a plastic that is difficult to adhere to.
Jan 22, 2013 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
I just got a schwinn srb-1800 recumbent exercise bike from my parents, it has hardly been used and in good condition but when I went to start it the computer is saying error 1 and won't work I put in...
Follow this step
o
Open the battery cover from the back of the control screen and take out the batteries.
o 2
Use the screwdriver to take out the screws on the left side of the large plastic enclosure that encased the batteries. You can now bend the enclosure so that you can reach behind it to make the repairs.
o 3
Use the crescent wrench to unfasten the nut that holds the left pedal onto the crank.
o 4
Unfasten the mechanism that keeps the pedal on the crank with the allen wrench.
o 5
Unfasten the screws that keep the plastic side panel on the wheel. Use the stubby Phillips screwdriver to get these four screws off. You will have to bend the outer plastic enclosure to reach the screws; make sure you don't break it. Remove the plastic wheel side panel.
o 6
Put the batteries back in.
o 7
Find the cord that moves the magnetic plate at the base of the wheel. Manually pull the magnetic plate back from the wheel frame. Now that the plate is unstuck, the error message should disappear.
o 8
Replace all parts in the reverse order you took them apart.
Nov 14, 2011 | Exercise & Fitness
Where can I order a plastic cover for the motor?
The only place that would possibly have the motor shroud would be Precor and they may say obsolete no longer available. This particular model # is not familiar to me since the common numbers on the older treadmills are 905e, 9.1, 9.17. 9.2 etc I assuming this was not intended to be sold in the USA.. I Suggest going to Precor's website and get the appropriate phone # to call.
May 31, 2010 | Precor 9.21 Treadmill
Treadmill stops after 7 seconds
you have a broken spinner. Take hte motor cover off and look on the opposite side of the motor. there will be a partof the spinner wheel there. I have yet to find a way to short cirut the connectors nor a replacement wheel.
Feb 16, 2010 | RTO Image 15.0R Treadmill Walking Belt
Turned on, runs a few seconds, shuts off with a #3 on display
Contact the manufacturer. You need the optical disc. It is the speed sensor. Eric For Treadmill replacement parts, please contact our Consumer Affairs Dept. at (800) 526 - 0244
Aug 06, 2009 | Exercise & Fitness
WANT TO REMOVE THE MOTOR FROM SPIRIT TREADMILL TO SEE IF IT CAN BE FIXED. HOW TO ?
Remove cover at front of treadmill,4 pillips screws on each side, 2 screws at front. Lift off plastic cover. Loosen motor belt tightener at top of motor mount ,remove 4 11/16 " nuts holding motor to treadmill base, remove red and black motor wires from control board. Lift motor out.
Aug 04, 2009 | Spirit Exercise & Fitness
Exercise & Fitness Logo
13 people viewed this question
Top Endurance Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Tom Chichester
Are you an Endurance Exercise and Fitnes Expert? Answer questions, earn points and help others
