Question about Sport & Outdoor - Others
Action will not lock
No part seems broken do not know how to remove barrel
    Problem Solver:
  • 16 Answers
Your barrel is threaded into your receiver, this is not a job for anyone other than a qualified gunsmith.
Posted on Apr 12, 2014
  • 3 Answers
CHECK YOUR MANUAL
Posted on Apr 13, 2014
How to remove a barrel lock
Push in on latch while removing barrel
Sep 02, 2014 | Cars & Trucks
Wrong key broke off in ignition of a 2004 focus how do i removed this piece
Might have to have the barrel drilled out and replaced, I have removed broken keys with very fine crochet needles and a lot of patience. To take a barrel out without damage the key needs to be turned into the first position to depress the barrel lock pin, which you can't do with the broken key in. Good luck
Jan 23, 2014 | 2006 Ford Focus
Remove ignition lock cylinder
Remove the ignition lock cover, there is a release button at the end of the lock cylinder, push in with a flat tip screw driver and turn key to the "on" position but don't start car, pull cylinder out with key.
Jan 12, 2014 | 1993 Ford Festiva
Why wont ignition make contact 1998 range rover hse
Sounds like the ingnition switch or cylinder lock. Was the truck stolen?
If they removed the ignition switch off the back of the cylinder lock then that may be your problem, that may be the reason why you do not get the spring action at the end turn of the key. look at the rear of cylinder lock and see if switch is removed.The other problem may be the cylinder lock may be broken, remove the cylinder lock and see if the arm that turns the switch is broken.that would also cause the problem you are having,
Let me know the results. good day
Jun 08, 2012 | 1998 Land Rover Range Rover
The key has broken in the ignition and the lower section of key is stuck in the barrel. The car still starts and runs . How do i remove the broken section of key from the ignition barrel, I have removed...
on the left side of barrel, look for a dowel, there should be a vary small opening that you can take something as small as a pinhead and push the dowel in ,while pushing in on dowel pull the barrel out.the key may need to also be in on position for removal. try that and see if it works. if not please repost your question. thank you for choosing fixya.com
Dec 30, 2010 | Suzuki Esteem Cars & Trucks
Lock barrell on the drivers side is broken
you'll need to remove your door panel (screws are by the door handle, arm rest, under door and side of door) and pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything.
I'm not sure what you mean by lock barrell.. I'm guessing the cylinder which you'll just have to bolt back onto the door.. you may need to find a specific bolt though....
Aug 10, 2009 | 1998 Volkswagen Passat
When i lock my car the window roll down and the
the lock barrell on the drivers side will be broken causing the total open and close function to work.remove the lock barrell and you will see the paddle on the end of the barrell does not move in relation with the lock barrell itself.new barrell will sort you out ....
Slide arm does not go completely forward
My Friend,
It seems you really have outdone yourself! The only thing I can recommend is to go to your local gunsmith ( a gun store could help in the location of one hint, hint) and have them disassemble the old gal. they will assess the damages done by your rookie mistake, and hopefully it's not too bad eh (she's a beauty she is). next time I STRONGLY recommend you take every precaution necessary to not damage you the guns or others. I STRONGLY recommend cleanings after every use, and please be sure to slide the slide arm all the way forward next time. You are lucky you were not hurt.
In my opinion though you may have broken a crucial spring, lock the slide gate shut, and/or dislocated the base of the spring. the shell not fitting I would say is a barrel issue with unburnt black powder, or a small dent in the barrel form the slide mechanism. BUT I HIGHLY recommend you do not try to repair this in your home or take my diagnosis as I have not seen the gun, nor am I a professional gunsmith.
Best Wishes,
KidKRYLON
Mar 22, 2009 | Winchester (026196062448) (20 - 60x70 mm)
How do you get out the ignition barrel
on alot of vehicles from the mid 80's and newer you have to take off your steering wheel and get a tool called a lock plate remover... take off your horn assembly.. your lock plate(locks your steering wheel from moving.. ) and then you need the key... try to turn it to the accesory position.. towards you.. it should slide out and new lock switch slides in... these are generic steps.. your car may be a little different.. but it should give you a good enough guide to either try or maybe get a friend to help good luck..
Sep 22, 2008 | 1990 Volvo 760
Sport & Outdoor - Others Logo
64 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
