Question about Conair Compact Garment Steamer Iron
Steam will not come through hose - Conair Compact Garment Steamer Iron
Why do water drops form om my clothes while steaming
You have a build up of water In the hose. Sometimes happens because the hose is too low to the ground. Try stretching the hose up and tap it and the water should travel back down the hose.
Another reason could be that you are using too much steam for that particular fabric.
Jul 08, 2014 | Rowenta Commercial Garment Steamer - White
Euro-Pro X
Check the hose for something clogging it. It will be past the flattened area (by that I mean further from the steam cleaner). It sounds like something got stuck in the hose, and as the steam cleaner kept sucking on the hose, it caused the hose to flatten.
Sep 08, 2007 | Euro-Pro Steam Generator EP8001 Iron
Issues with Rowenta Steam Iron DG 05030 steam hose
Does your iron have a self cleaning feature? It sounds to me like you have calcium build up and when you squeeze the hose it displaces the "clog" just enough to allow steam through.
Nov 12, 2012 | Rowenta Steam Generator DG050 Iron
Hot hose but no Steam
Don't know this machine but if it has brass jets on the head stick a pin or a needle into them twisting while pushing in and out, some times these jet block up. other wise undo hose and blow through it hope I have helped in some way.
May 19, 2010 | Rowenta Commercial Garment Steamer - White
Conair GS33 fabric steamer spews too much water..can't be normal, eh?
Are you setting the body of the steamer on a table? If part of the hose sits lower than the steamer body steam will condense in the hose and collect in the low spot. Steam pressure will push the water out through the nozzle. If your steamer starts to sputter lift the hose so that it is completely above the level of the water reservoir and let the water drain down. Its a good idea to keep the steamer body on the floor so the hose can never get lower than it.
Feb 03, 2010 | Conair Irons
Solenoids workin, steam lines fine, but no steam
take hose off from iron end,press iron button ,breifly! keep tight hold of hose [best to put towel around hose while holding]see if steam comes out.if not hose could be blocked, then take hose from solenoid end and press button .if no steam comes out the solenoid is either faulty or the valve hole inside is blocked,turn off power and take nut off top of solenoid ,check spring and plunger for condition.the small hole may be blocked in the solenoid housing,try a needle in the hole to clear any blockage.
Jun 24, 2009 | Irons
Russell Hobbs Steamglide 2200 - no steam
Same with mine! What you have to do is keep taking the water cannister off and pushing back on until its lined up correctley. Also have the whole unit at the same height as the ironing board, that should do it! Can you help with filters? I cant find them anywhere.
Mar 23, 2009 | Irons
Parts
Call 800-711-6617 to get a new Hose Base for $3.00. I just ordered three of them and with shipping it was around $17.00. They didn't give me the part number.
Jul 05, 2008 | Steam Fast SF-450 Iron
EP8001 Steam generator.
Sears sells a screwdriver set (47486 is written on the handle) that has a lot of non-standard drivers. There is one on there that will fit the nuts on this unit.
Also, I used a rubber tube from an Auto parts store to replace the cracked hose. I figured the Automotive hosing was designed to withstand the heat of an engine. So, it should work on this iron.
Bring the cracked iron hose with you to the auto parts store.
Oct 07, 2007 | Euro-Pro Steam Generator EP8001 Iron
Conair Compact Garment Steamer Iron Logo
75 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Conair Iron Expert? Answer questions, earn points and help others
