Panasonic as-ak200 - Audio Players & Recorders
CD Stero System Model SC-AK200 remote is not working. Therefore Clock cannot be set. Can clock be set manually? Is there any trick to re-initialising a remote when a new remote is used on the old system...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
http://remotes.com/remotes/servlet/rs?v=1&o=c&o=c&a=Search&uid=0&m=SC-AK200+&uuid=A13101189236741
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Jul 08, 2011 | Panasonic SC-AK200 CD Shelf System
My sound system, the panasonic SA-AK200 shows me an "F61". How can i solve this problem? Kind regards
F61 usually means the amp has detected a short or a severe microprocessor error.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Jul 02, 2011 | Panasonic SC-AK200 CD Shelf System
The disk skips without there being dust or scraches
You need to clean or replace the optical pick up.
Nov 08, 2010 | Panasonic SC-AK200 CD Shelf System
SA-AK-37 Music system showing 'F-61'
its got a door problems a part in the cd deck bracks off and its basturd to fix.
Mar 20, 2010 | Panasonic SC-AK200 CD Shelf System
Switching off of SA-AK-37 Music system
Do you have the manual, I think panasonic put some of there fault codes in the back.
Seems to have lots of people saying it could possibly be a power supply fault, an amp fault or shorted speakers.. Some people have gone to the extreme of actually buying new components and trying to unsolder and resolder to try to fix it themselfs.
Try contacting Panasonic, they will be able to advise you better ot possibly repair / replace the system.
Jan 31, 2009 | Panasonic SC-AK200 CD Shelf System
SA AK200 does not appear to turn off completely
HiFi system actually turned Off when you press power button and display of hello, heavy, vocal etc is demo mode of this system and it activates when unit goes to power off.
You can change its settings like not to show demo mode etc and this procedure is described in owner's manual.
Thank you.
Dec 15, 2008 | Panasonic SC-AK200 CD Shelf System
Cd tray remains open
you need,tray alignment or electronic failure,see a doctor.
Feb 01, 2007 | Panasonic SC-AK200 CD Shelf System
24 people viewed this question
 Grubhead
Grubhead
