Question about Hon Company HON10762C 2-Drawer Lateral File 36"x20"x29-1/2" Harvest
Hon 4 drawer lateral file-- all 4 drawers are stuck shut. How do I correct this?
We recently moved an empty 4 drawer lateral file by hon. We had to tip it on its side to transport it. When we stood it up non of the drawers would open. Is there a solution to this?
Can you remove the drawers? We need to move it upstairs, and it would me much easier without the drawers.
Try pulling the drawers out as far as they go, then put some lubrication where it's stuck and gently try and wiggle them out.
Aug 02, 2013 | Baby Cache Montana 4-Drawer Dresser -...
Sub zero freezer drawer frozen shut
Subzero freezer: We had all our drawers stuck, including the ice drawer. We turned off the refrigerator, took all the drawers out and defrosted the rails with a hair dryer. The ice drawer was misaligned, so we reset the allen screws on the left to be the correct width. All better!
Sep 08, 2012 | Refrigerators
Metal file cabinet problem
sometimes wd40 works on stuff like that too
Jul 28, 2012 | Hon 534CQ Vertical Metal File Cabinets...
The bottom freezer drawer is not closing so the freezer is getting an ice build up
It sounds like you either have a drawer that's off track, or something has fallen behind the drawer, not allowing the drawer to close. Empty the freezer, and pull the drawer all the way out. Look behind the basket of the drawer and see if some thing has fallen behind it. If nothing is behind the drawer, then the drawer must be off track. At this point, you'll need to pull the drawer out to the most extended point. Now push the drawer back in about 3-4 inches an **** it open fairly hard. Not hard enough to move the whole refrigerator. Just enough to put the drawer back on track. Hope this helps. : )
Apr 24, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
When i put the conditioner in the drawer it fills up with water
But the soap the bleach and the conditioner all at the same time in ther hon slot. Just make sure that u had 1/3 of conditioner that is water! to get away from the moldy smell i sai do two wash with bleach and then 2 wash with everything! just make sure u do all of them withouth clouths
Nov 19, 2009 | Washing Machines
Repeats "empty coffee grinds drawer". drawer is empty.
Check the area behind the draw there might be some ground coffee preventing the tray from sitting correctly.
Jul 05, 2009 | Saeco Royal Professional Espresso Machine
F&P double drawer (DD603) won't empty
Ok you need to remove the motor rotor it's under the spray arm and comes out like a light bulb from the top draw and check for anyting stuck under it or any damage done to it. Try swapping it with the one out of the bottome drawer and see if that works. When you first start the washer does it drain all the water?? if still no luck try swapping the motor contoller modules (computer board) from the top drawer to the bottom drawer and retry both drawers ,if the fault moves drawers with the part, then that part is faulty cheers
Mar 18, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Jammed storage drawer
svineyardWelcome to fixya.
I'm Huuum and happy to assist you,
You said, Y inherited a GE Spectra XL44 in the home I recently bought so you don't know much about it. There is a pan stuck in the storage drawer and You can only open the drawer about an inch and a half before it jams.
You need two people.
One strong person to slide the range forward, so he can tilt the range far enough back, that you can access the drawer from the bottom and the pan will fall back inside the drawer as you pull the drawer forward and out enough for you to reach the pan and turn it around or what ever you need to do to get it out!
Bravo, I want to hear that you succeed!
Be careful not to hurt your self.
Bless You Huuum.
Please do not forget to leave a rating when you are done.!!!!!!!!
Aug 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Xerox 8830 - 2 Drawers / Trays non-operational
I would suggest to have the proper service rep work on it. albeit pricey if you want it to work correctly have it professionally serviced.
Or say, Dearly beloved, we gather here today LOL.
Dec 18, 2007 | Xerox 8830 Copier
Hon Company HON10762C 2-Drawer Lateral File 36"x20"x29-1/2" Harvest Logo
121 people viewed this question
Top Hon Company Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Hon Company Office Equipment and Supply Expert? Answer questions, earn points and help others
