Question about Electrolux Washing Machines
Front door will not open Electrolux EWN 14991
3 Suggested Answers
  • 19 Answers
SOURCE: I have a electrolux Insight EWN 14991 W which I
It sounds like the micro door switch could be intermittently faulty. Switch unit off from power supply and unplug for 10 minutes. Restart. If problem reoccurs then you will need a service call.
Posted on Jul 26, 2011
Daniel S
  • 4323 Answers
SOURCE: electrolux insight EWN 14991 W
Hi
If the washer won't fill you'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Posted on Aug 19, 2011
Electrolux front load washer door won't unlock. How do I get the door open? Model number: EIFLW55HIW0......unplugging didn't work
Disconnect power supply. Remove top panel.
Now is door lock accessible. Open door, remove door gasket from housing (not from tub), remove two screws and replace door lock.
Dado
Mar 02, 2017 | Electrolux Washing Machines
My electrolux ewf 1087 front loader door wont open
You will need to remove the drum and reset the alignment.
The cloth is struck and has jammed on the drum movement.
click this link: drum removal
Jan 21, 2013 | Electrolux Washing Machines
I own a 1Q-Touch Front-Load Electrolux washing machine. The door won't open. What can I do?
Hello Elizabeth P Cochran - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Jan 15, 2013 | Electrolux EIED55HIW Electric Front Load...
Electrolux washer door won't open
Hi.
Usually the door does not open because there is water inside the tub.
Disconnect power and empty the machine through the drain filter. With Electrolux front-loading washers the drain filter access is located in the front lower side of the machine.
Jun 11, 2012 | Electrolux Washing Machines
I have a electrolux Insight EWN 14991 W which I have for over 2 years. The problem is that it keeps coming up to make sure door is closed properly which it is. It stills refuses to go through a cycle. ...
Jul 26, 2011 | Electrolux Washing Machines
The washing machine Electrolux AURUM16 Problem
Make sure the water is drained or the door wont open
Sep 08, 2017 | Electrolux AWF1220 Front Load Washer
Ewn 14991w washing machine door won't close
http://appliancejunk.com/forums/index.php?topic=2846.0
OK go to link, above scroll down to LAUNDRY, and download one of these "Generic" service manual, inside you have troubleshooting procedures and repair how to's. It is what us engineers use to repair.
I think you may find you will have to replace the door handle assembly, and switch, interlock. This is a common thing.
http://safemanuals.com/user-guide-instructions-owner-manual/AEG-ELECTROLUX/EWN14991W-_A
Owners manual,
http://frigidaireservicetips.com/pdfs/493_LaundryCenterwithTumbleActionWasher.pdf
Generic service manual, troubleshooting and repair.
Apr 11, 2010 | Washing Machines
Cannot open the front door on an Electrolux ECO 7 kg front load washing machine. Feels as trhough the door clip has broken
I really did not fix the problem. I think the plastic linkage may have been broken and I was looking for a fixto open the door.
Thanks anyway,
Jim Charlesworth
Jan 10, 2010 | Electrolux EW1200i Front Load Washer /...
Error code e40 on my washing machine electrolux ewn 16781 w
The Error E40 warning means the door is not properly closed. The E40 error code indicates a loss of electrical power usually but not always due to the door not shutting properly or not locking. But, since you smelled burning it could be any electrical short that blew a fuse and shut the machine down. It could also be the motor windings with the internal overload protector shutting it down.
Thank you for contacting Fixya.com
Aug 06, 2009 | Electrolux Washing Machines
Washing Machines Logo
23 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
