Question about VOX Amplification Vox Valvetronix VT50 Modeling Combo Amp
I have a Vox VT50 Modeling amp. Bought it about 4 years ago. Played maybe 3 hours if that at very low volumes. After 2 years when I turned it on it would work fine until I changed volume then it would lose almost all volume and punch. If I turned it up it would go up but without out punch or the normal volume. If I changed modeling sounds it would be fine again till I changed volume then do the exact same thing. Master volume works fine just the regular volume knob does this. What can I do??
3 Suggested Answers
  • 5603 Answers
SOURCE: When I use the Master
I suspect you may have either a circuit board crack or the volume pot is bad or soldering of it is bad. Vibration will make things come and go. Look for broken solder around the pot leads first. Then look for a cracked circuit trace on the board near the ground end of the volume pot. If you put cleaner in the pots NEVER use Deoxit or Blue Shower. Use CRC226 which is available at Home Depot in the electrical dept.
Posted on Apr 29, 2011
  • 5603 Answers
SOURCE: I have a VOX NT15.
You LIKELY have a bad filter capacitor. The additional load of the Triode load is probably dragging the supply causing flattopping and the power supply ripple frequency to come through. Have the unit serviced.
Posted on Jul 26, 2011
Testimonial: "OK"
Can I use my vox vt50 amp to play my bass guitar?
You can use it, just keep the volume low. The amp doesn't care what yu play through it, but the speaker isn't designed for loud bottom end.
Dec 17, 2015 | Bass Music
Is it possible to lower the VOX VT50 transfo outgoing voltage?
bulbs have tolerance, that means it can work with + or - 6.3v just use the 7.6v which a diffrence of 1.is ok for it to work.
Jun 27, 2014 | VOX Amplification Vox Valvetronix VT50...
My VOX ADVT50 is not putting out any sound
Firstly check all valves are glowing, if they all glowing, check speaker cone isn't blown
Jun 29, 2012 | VOX Amplification Vox Valvetronix VT50...
Peavey Vypyr 75w
If you hear any difference in the sound while moving the pot and not scratching sounds while moving it then its not the pot...
If i understood the problem right, i have seen it in 2 ELKA guitar amps.
In their case it was the TL072 opamps in the preamp section the problem and i tracked it and it must occured due to no earth connection in the wall socket and as a result to the amp...
Mar 11, 2012 | Peavey Electronics Peavey Vypyr 75 -...
I just bought a Behringer K3000FX amp and it sounds GREAT with my keyboard. However, just bought a Shure SM48S voice mic and it just doesn't come thru the amp with much volumn...have to turn amp
Greetings! Ok, your amp has an XLR (3-prong) Low-Impedance input on Channel 1 for a Mic. All the other inputs are 1/4" High Impedance inputs, which are for instruments and/or other High Impedance items including low quality High Impedance Microphones. The SM48S is a high quality Low Impedance microphone, so if you use it with a 1/4" plug, it will be in a High Impedance channel, and will be very LOW in volume in comparison with everything else. So, you must use an XLR (3 prong) cable from the Mic to the Channel 1 input on your amp. That will do the trick. Good Luck with your new amp and Mic!
Dec 02, 2017 | Behringer Ultratone K3000fx 300w Keyboard...
I bought my g-dec jr form ebay last summer and really like this little amp but this past winter I went to use it, it worked for 3 to 5 min and shut down, but the power light just blinked moderately. I...
This amp uses a TDA2050 chip that has thermal protection. It is also a small amp that is NOT capable of high sound levels. If *********** can't stand to be within 5 feet of this amp you are playing TOO LOUD for this amp and it will shut down until cooled off to protect the amplifier chip. This amp is intended for practice. It would be adequate for sensible listening level in a 10 foot by 10 foot room. If you need more sound you will have to get a bigger amp. I would suggest you get a sound meter and verify the sound level. DO NOT exceed 4 hours at 90 DB... I know a lot of deaf musicians that have lost their hearing and they are not much good anymore.
Jul 16, 2011 | Fender G-DEC Junior Modeling Guitar...
I have a vt50 and it has an extremely loud buzz when I turn it on with nothing plugged in. It sounds like the speaker is going to blow. I don't know what's wrong.
Yes you could blow the speaker. There is either a problem in the power supply or possibly the power amp chip has shorted to one of the power rails. Some of the vox stuff uses th LM3886 chip as the power amp. While these are supposedly protected, they can go bad. Download A schematic that MIGHT be close to your unit... it is for the VT30 but probably is similar:
http://elektrotanya.com/vox_ad15-30vt_sch.pdf/download.html
Scroll down to "Get Manual" and click on it to download the schematic. Do this test: Adjust the power level control. IF it doesn't vary the level significantly, then check the voltage across the speaker... IF it isn't less than 1 volt DC (bias) replace the LM3886 chip. Use thermal grease and any insulators they are using. Chip about $8 from Digikey.com. Note these come with two different pre-bent leads... make sure to get right ones. IF the output bias is with 1 volt DC of ground, check for bad filter caps and rectifiers.
Apr 30, 2011 | VOX Amplification Vox Valvetronix VT50...
High pitched squeal when the input jack is used.
Sounds like your master volume is turned up too much. The channel volume will make the squealing go away(caused by high gain and humbuckers). The best thing to do is dial in your favorite presets and change the channel volume to the correct level with the master volume where you usually keep it. I use my Spider Valve at master volume at about noon and the channel volume between nine o'clock and noon. Let me know if this does not solve the problem......
Aug 22, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Crate flexwave 120 head sound cuts out
You have a broken solder joint. You'll have to disassemble the amp enough to get at the soldered side of the circuit board that the controls are mounted to and touch up any suspect solder joints. Just be sure to resolder only the joints that were originally soldered or need to be soldered. Hope this helps.
Jun 07, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
My Line 6 Amp has a sort with the volume, the volume will be low and for no reason shoot up to about 8 or 9. how do I fix it?
Sounds Like You need a new volume pot you can buy them at radio shack, Best buy, Click Here to see it. Its very easy to replace if you have soldering experience if not it should be to expensive to fine somewhere to do it for you.
Hope this helps and if you have more questions let me know.
Sincerely,
Michael Scott
May 03, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
VOX Amplification Vox Valvetronix VT50 Modeling Combo Amp Logo
Top VOX Music Experts
rhodesworks
David
David
Are you a VOX Music Expert? Answer questions, earn points and help others
