Question about Pride Go Go Elite Traveller Plus HD 4 Wheel Scooter
Rear end has to be forced on it is now hard to re assemble
How to fix my Tanaka chainsaw rope to recoil back?
replace teh recoil section as there is a problem with the spring or the pulley section holding the cord.
Apr 26, 2015 | Tanaka TCS33EB/14 32 cc Gas Powered 14-in...
Tip
Mazda 5 SUV/van brake light assembly replacement
This is easy and takes maybe ten minutes. You need a phillips screwdriver and a pair of pliers. Open the hatch and remove two screws at the back of the brake light assembly. Pull the light assembly hard straight backward until the little pop-clip holding the front end of the light lets go. (This is the hard part, because there aren't any great places to grip the light and the front end pop-clip is stubborn.) Then unscrew the bulbs from the broken assembly (don't touch the bulbs or the slight oil from your fingers will make them explode when they heat up - use surgical gloves if you think you can't help handling the bulbs). Gently remove the wiring harness from the NEW light assembly and discard it. Push the existing wiring harness into place in the new assembly and screw the bulbs in. Line up the assembly's pop-clip to the front end screw that it pushes onto, and push hard from the back until it pops on. Have a helper lean into the light from the side to line up the two screw holes at the back, and put the screws back in. Use a pair of pliers to unclip the rear baffle from the broken light (two clips), then pop the baffle onto the new light.
on Jun 07, 2015 | Mazda Cars & Trucks
Replace rear wiper assembly
The wiper arm has a cover on the left end that pops up after gently spreading the two bottom sides apart. That allows the arm to swing out for cleaning the window or replacing the blade.
The wiper blade assembly attaches to the end of the arm . It is pressed in and will pop out with a little force rotating the left side away from the arm. It pops back in with a little push. The arm remains attached to the rotating shaft assembly.
I believe you can then replace just the rubber blade and not the whole blade assembly, if that is your fancy.
Dave
Oct 18, 2013 | 2008 Toyota Highlander
Winchester model 1200 action stuck open
You have to make sure the hammer on the trigger group is cocked and then you have to make sure the slide arms are in the cutouts on the bottom of the bolt assembly.
You assemble the trigger group to the receiver by carefully working the front end of the trigger group into the slots at the front end of the receiver. Then gently push the rear end of the trigger group down into position. This should go in easy if everything is lined up--don't force it.
Then install the trigger guard pin from right to left until its flush with the receiver.
I took all the above from the pdf manual I have for the model 1200 that I found online. The pictures would help (page three). I'm looking for a link to the manual and will post it when I find it.
Here, its on page three of the manual: http://gunmanuals.net/Manuals/winchester_1200.pdf
Sep 28, 2013 | Sport & Outdoor - Others
2010 chrysler sebring brake light replacement
I had the exact same problem. After you take off the wing nuts there is one more piece holding the taillamp assembly in place. It looks like a little white plastic piece with a metal ball in it. In my complete laymans terms,its just a small metal rod that has a ball end. If you pull the taillamp assembly out enough that the screws are not in the metal body of the car, just pull the assembly with a little force towards the rear of the car. It should pop out. I found a video that shows exactly how its done. http://www.carcarekiosk.com/video/2007_Chrysler_Sebring_Limited_2.4L_4_Cyl./lights/brake_light
Apr 14, 2012 | 2009 Chrysler Sebring
I need a schematic for the rear brakes on an F150 super cab with 4.6L automatic trans 4wheel drive
Drum, Rear Brake System Standard Rear Brake
Item Part Number Description 1 2069 Brake Shoe Hold-Down Spring Pin 2 — Rear Wheel Cylinder Retaining Bolt (2 Req'd) 3 — Washer (2 Req'd) 4 — Anchor Pin (Part of 2211) 5 — Wheel Cylinder 6 2028 Brake Shoe Anchor Pin Guide Plate 7 2A637 Parking Brake Lever 8 2296 Brake Shoe Retracting Spring (Short) 9 2296 Brake Shoe Retracting Spring (Long) 10 2200 Rear Brake Shoe and Lining (Secondary) 11 — Washer 12 2106 Parking Brake Lever Pin Retainer 13 — Brake Shoe Adjusting Lever Cable Guide 14 2A642 Primary Brake Shoe Parking Brake Lever Link 15 2A601 Parking Brake Link Spring 16 2068 Brake Shoe Hold-Down Spring 17 2A176 Brake Shoe Adjusting Lever 18 2048 Brake Shoe Adjusting Screw Socket 19 2047 Brake Shoe Adjusting Screw Nut 20 2041 Brake Adjusting Screw 21 2049 Brake Shoe Adjusting Screw Spring 22 2200 Rear Brake Shoe and Lining (Primary) 23 2A178 Brake Shoe Adjusting Lever Cable 24 2211 Brake Backing Plate
Heavy Duty Rear Brake
Item Part Number Description 1 — Rear Wheel Cylinder Retaining Bolt 2 00538 Lock Nut 3 2212 Rear Brake Backing Plate 4 2262 Rear Wheel Cylinder 5 2A642 Primary Brake Shoe Parking Brake Lever Link 6 2A601 Parking Brake Link Spring 7 2A637 Parking Brake Lever 8 2106 Parking Brake Lever Pin Retainer 9 — Parking Brake Lever Bolt 10 — Secondary Shoe Assembly 11 2A179 Brake Shoe Adjusting Lever Cable Guide 12 2068 Brake Shoe Hold-Down Spring 13 — Adjusting Lever Pin 14 — Adjusting Lever Return Spring 15 2A176 Brake Shoe Adjusting Lever 16 2047 Brake Shoe Adjusting Screw Nut 17 2049 Brake Shoe Adjusting Screw Spring 18 2041 Brake Adjuster Screw 19 — Primary Shoe Assembly 20 2068 Brake Shoe Hold-Down Spring 21 2200 Rear Brake Shoe and Lining 22 2035 Brake Shoe Retracting Spring 23 2A178 Brake Shoe Adjusting Lever Cable 24 2092 Brake Adjusting Hole Cover 25 2069 Brake Shoe Hold-Down Spring Pin
The rear drum brakes:
  • Have internal shoes that expand against the brake drum (1126).
  • Are a single-anchor type.
  • Are actuated by one rear wheel cylinder (2262).
  • Have two pistons in the rear wheel cylinder (2261). One exerts force against the upper end of the primary shoe; the other exerts force against the upper end of the secondary shoe.
  • Adjust rear brake shoes and linings (2200) automatically.
  • Need manual brake adjustment if the adjusters are not operating properly or after the rear brake shoes and linings have been replaced.
When the brake pedal is applied, hydraulic fluid pressure forces the pistons in the rear wheel cylinder outward, moving the rear brake shoes and linings against the brake drum.
The rear drum brake system includes the parking brake mechanism. Refer to Section 206-05 .
Apr 04, 2009 | 1997 Ford F150 Regular Cab
How do I replace a taillight lens on a 1991 Geo Storm?
Rear Turn Signal, Brake and Parking Lights
STORM COUPE
  1. Disconnect the negative battery cable.
  2. Lift the luggage compartment floor carpet toward the front of the vehicle and remove the spare tire cover panel.
  3. Remove the ten plastic retaining clips from the rear end trim panel.
  4. Disconnect the luggage compartment lamp electrical connector.
  5. Remove the luggage compartment trim panel and the rear end trim panel.
  6. Disconnect the rear combination lamp assembly electrical connector. Fig. 1: Rear Turn Signal, Brake and Parking Lights — Storm
  1. Remove the seven nuts and the rear combination lamp assembly from the vehicle.
  2. Disconnect the rear combination lamp electrical connector.
  3. Remove the four bulb sockets from the rear combination lamp assembly and remove the four bulbs from the sockets. To install:
  4. Install the four bulbs to the sockets and install the four bulb sockets to the rear combination lamp assembly.
  5. Connect the rear combination lamp electrical connector.
  6. Install the rear combination lamp assembly to the vehicle and the seven nuts.
  7. Connect the rear combination lamp assembly electrical connector.
  8. Install the rear end trim panel and the luggage compartment trim panel.
  9. Connect the luggage compartment lamp electrical connector.
  10. Install the ten plastic retaining clips to the rear end trim panel.
  11. Install the spare tire cover panel and the luggage compartment floor carpet.
  12. Connect the negative battery cable.
Mar 21, 2009 | 1991 Geo Storm
Removing Tail Lamp Assembly
The inner panel has to be removed and that will allow access to the back of the assembly to replace bulbs,
Mar 11, 2009 | 2002 Jeep Grand Cherokee
89 toyota corolla rear drum brake problems.....
there should be three or four large nuts on the inside of the drum. now these nuts are on realy good so it takes a lot of force to get it off if you have trouble getting it off you should get an extender to help with the force. Now with the break fluid going every were it could be cause you broke the metal tube.that is easy to replace. just follow it up and undo it.
Nov 11, 2008 | 1989 Toyota Corolla 2 Door
Changing inner drum
you must be fairly competent to have got this far! So! it now needs a bit of brute force. I assume you have removed the drive pulley? Now lay the unit down, 'pulley side uppermost', support the outer tub from the floor with a couple of bricks at either side to give floor clearance to the inner tub, use a piece of hard wood (to protect the shaft end) and give the wood a HARD BLOW with a 4 pound hammer. The shaft is just 'stuck' in the bearings. Dont mess around tapping the shaft end with a small hammer, you will only bruise the shaft end. As they WOULD say around here
'' GIVE IT A GOOD SCUT WITH A 4 POUNDER''
Nov 03, 2007 | Kenmore 44042 Front Load Washer
Pride Go Go Elite Traveller Plus HD 4 Wheel Scooter  Logo
23 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
