Question about Ovens
Teka oven model no UN-BUD720S. Fan making loud noise. Oven not cooking efficiently
  • 1462 Answers
SOURCE: Oven
oven has two fans. the second fan is out of sight and cools the casing. it is operated by a seperate stat. not unusual for it to run for up tohalf hour after switching off. if it runs for an excessive time may be a fault nwith fan stat
Posted on Mar 20, 2007
barkencoa
  • 3463 Answers
SOURCE: zanuisi top oven making noise
Yes , there is a cooling fan located at the top of the oven
It could be the fan blades catching, or a noisy fan bearing.
You would have to access it by removing the top oven cover to check., and yes it could be as a result of having it cleaned.
Plz rate my solution.
Thanks.
Posted on Jan 02, 2009
barkencoa
  • 3463 Answers
SOURCE: noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Posted on Feb 09, 2009
barkencoa
  • 3463 Answers
SOURCE: Delonghi ESM465ST Oven Noisy Fan
If it is a fan assisted oven, then you are likely to have 2 fans, an external cooling fan, and a fan inside the oven for ciculating the hot air.
So to answer your query, yes it is a noisy fan you are going to have to establish which fan.
It could be a worn bearing, or the fan blade has come loose.
If it is a worn bearing, thge only cure is a new fan.
Hope this helps with your problem.
Posted on Dec 02, 2009
Testimonial: "Thank you for that. It's noisy even when the fan inside the oven isn't running (ie, just on convection) so guess that means it's the external fan?"
  • 291 Answers
SOURCE: Frigidaire Oven making vibration noise when
This usually is caused by a bad convection fan motor. This is something that you should have a technician replace, but ask for a price quote first. Fairly expensive to fix and usually very complicated to get at. Good Luck, Appliance Specialists
Posted on Dec 11, 2009
My oven fan has recently started to make a very loud rattling noise for around 30 seconds once every few minutes while the oven is turned on in fan mode.
The fan needs be cleaned and lubricated. To do this: Turn off stove/oven. Remove fan cover plate. Remove fan. Clean and lubricate the shaft bearings with 3 way oil. Install fan and cover plate.
May 16, 2016 | Smeg Ovens
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
My new world double oven fan makes a loud noise and now the large oven does not heat up
Newworld model 444447289 made a loud bang and doesn't come on. The top oven oven is ok. What could the problem be
Oct 11, 2013 | Ovens
Kitchenaid superba oven
What is the model number?
Jun 19, 2013 | Ovens
My AEG competence oven is making a loud buzzing noise coming from the top fan? The food tonight was either burnt or under cooked? The buzzing is also loud when switched off/cooling down? Any ideas please.
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
Dec 12, 2010 | AEG D4101-4 Electric Double Oven
Loud noise from Baumatic B905 oven whilst cooking and after.
not that familiar with the brand but in other case have fourn the board to be engaging the self clean. not a good sign. and for this model i would think very costly. wishful thinking says the oven temp sensor but i think you have a fauly board. get the same thing with alot of frigidaire ranges.
Aug 01, 2010 | Baumatic B905SS Stainless Steel Electric...
Is there a way to turn off the fan in the oven, and still use the oven to cook? My oven is far too fierce.
Unless your fan oven specifically has a control to turn off the fan, then the answer is "no". Disabling the fan will cause the element to overheat and fail.
Fan ovens are far more efficient for most types of cooking, but you have to adapt by using either shorter cooking times, lower temperatures or both. Many ready meals have separate fan oven instructions for this exact reason and you can search the web and buy books for recipes and methods specifically aimed at fan oven users. Once you're used to fan cooking you'll hate using regular ovens again.
I hope that you have found my answer to be of use and ask only that you return the favour by rating my answer.
Oct 24, 2009 | Ovens
720 EF Fan oven fan making a scrreching noise now
It could be that cooking residue has run down the inside of the fan cover and it is restricting the fan movement. The fan cover is held on by four self tapping screws, one on each corner. Remove the cover and have a look to see if there are any rub marks on the inside. You should be able to remove some of the gunge by soaking the the whole cover in hot soapy water. If that doesn't work, buy the Lakeland brush on oven cleaner - that definitely works - you can use it on all of the inside of the oven. Whilst the cover is off, briefly turn the oven on to see if the fan still makes the same noise. If it does, it looks like the fan bearings are suspect and a new fan may be required. If not you have found the problem with the cover. Page 37 of the Handbook tells you how to replace the circulating fan.
Sep 23, 2009 | Stoves 720EF Electric Double Oven
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
Oven hotter at the back
You should always preheat oven to operating temperature before cooking anything.
Do not put too much in oven, leave plenty af space for good air circulation.
Do not place any reflective foil or the like on the bottom of oven or shelves, as this reflects heat, and you will get uneven cooking.
Make sure fan is working efficiently if it is fan assisted.
Dec 09, 2008 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
51 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
