My tv is Panasonic vesta has a HDMI output but my toshiba SATELILITE L300 has not got a HSBI port is their any way I can connect to my tv to watch films off you tube.
    Guru:
  • 452 Answers
Use this cable converter to connect laptop to your TV
VGA to HDMI
My tv is Panasonic vesta has a HDMI output but my  - ecadb4f4-455d-4217-9d34-10bb54cbbd21.jpg
Posted on Feb 09, 2014
  • Big Steve
    Big Steve Feb 10, 2014
    Apart from the pretty picture, this solution adds nothing. I had already that there is an adaptor but at $130+ it is not really worth it.
  • 1,087 Answers
Many guys seem to have this problem. On your laptop you seem to have a VGA connector output (a 15 pin socket 2 rows of 7+8)
you'll need to use this VGA port instead. This is a practical solution if your flatscreen TV has a VGA port included - a standard VGA cable coupled with an audio cable (see above) will be sufficient. You may even be able to view HD content this way.
Otherwise you'll need an expensive VGA to TV Converter (about $130) which is not worth it.
Rick60639
  • 29 Answers
SOURCE: can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Posted on Dec 01, 2008
leecom72
  • 4806 Answers
SOURCE: how do i connect my acer 5738 laptop to my tv
First of all your TV should support both HDMI and VGA.
If it does lets start with HDMI as you will get audio through the HDMI cable.
Connect the HDMI cable to the TV and set the source on the TV to HDMI using your remote control, connect the other end to the laptop, hold down Fn and hit F5 to toggle between screens.
See if that helps and let me know how you get on.
Good luck
Posted on Aug 21, 2009
  • 733 Answers
SOURCE: Connected A300 Satellite to HDMI TV worked
power off your pc completely and remove hdmi cable. with the tv on, plug the hdmi cable back into your pc and power it up. tv should be recognized.
Posted on Mar 28, 2010
Current009
  • 135 Answers
SOURCE: can I connect my Toshiba NB 205 to my TV to watch
Interfaces 1 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x Microphone - Input - Mini-phone 3.5 mm , 1 x Headphones - Output - Mini-phone stereo 3.5 mm , 3 x Hi-Speed USB - 4 pin USB Type A
The above interfaces are in your laptop. There is no S-cable or HDMI interface.
If your TV have VGA port you can connect your TV to the VGA port in laptop. This will alow you to convert the TV as monitor.
Posted on Jun 01, 2010
dmcmullenii
  • 12 Answers
SOURCE: I have a Toshiba Satellite L505D-S5983 Laptop with
The price difference in the cables are what type of metal wire that is in it. One might have copper or even gold plated and the lower price one might have some low end metal. I have not seen any difference. Yes, all you have to do is plug it in and Windows 7 will recognize your TV. You might want to go into the Control Panel and open Sounds and make sure you have the audio turned on for your HDMI connection. Your laptop screen and the TV will be displaying the same.
Posted on Sep 04, 2010
Testimonial: "Thanks so much. I really appreciate it."
How can you connect a Toshiba L300 laptop to a Panasonic TH-L32X20Z TV
Your laptop should have a AVG port , run a cable from this to the HDMI port on the TV ,showing AVG port
Feb 25, 2015 | Toshiba Satellite Pro L300 Notebook
What tv cables work with HP 6510b please?
You will need standard HDMI only if your laptop have HDMI port. I think hp 6510b not include HDMI port. It has VGA and SVEDIO Output. Your toshiba TV have many PC INPUT Ports such as
S-Vedio, D-sub , VGA like old Desktop PC connection with Projector). So buy VGA cable or S-vedio Cable, then you can connect.
Jul 24, 2013 | Computers & Internet
Panasonic home cinema connection issues
What other audio/video outputs does the TV have? Does it have an HDMI port? If so, connect TV to your home theater using HDMI to HDMI.
Jun 07, 2013 | Panasonic SC-BTT490 5.1 3D Home Theater...
How to connect to a sony tv
If your laptop has an HDMI port you can buy an HDMI cable and connect to your Sony TV. Most TVs now come with an HDMI cable
Once connected your TV should show the screen from your laptop if not
press Function and F5 buttons simultaneously! Alternatively you can restart your computer!
Still problem! Go to control panel and click on display and choose Sony TV good luck!
Sep 24, 2011 | Toshiba Satellite Pro L300 Notebook
If our Toshiba Satellite Pro 300 laptop does not have a HDMI output, is there a way we can we still hook up our laptop with our TV?
Yes. The best option would depend on what TV you have. The HDMI inputs on most consumer displays won't accept PC resolutions. Assuming you want to take the VGA output of your PC, and that it doesn't have a Display Port or DVI output, and without knowing the model of your TV, the safest recommendation would be to use a product specifically designed to cross-convert VGA to HDMI formatted for consumer displays (1080p, 720p, 1080i), such as this one.
http://www.atlona.com/Atlona-VGA-to-HDMI-Scaler-Converter-USB-Powered.html
Jun 03, 2011 | Toshiba Satellite Pro L300 Notebook
What do I need and how do I connect my Toshiba L305 model PSLB8 050302f to my hdtv to view online tv?
I dont believe that laptop has an HDMI port on it. If you have an LCD TV then your TV may have a VGA or DVI input on it. You can connect your laptop to the TV by using a VGA to VGA or VGA to DVI cable. If you your TV doesn't have one of these input ports, then you're not going to get your laptop connected to your TV.
Mar 03, 2011 | Toshiba Satellite Pro L300 Notebook
I don't know what kind of cable i need to connect my Toshiba satellite L305D laptop to my hdtv
depending on how old you laptop is because the L300 range has been going for a while will be either a HDMI cable or a VGA to HDMI cable but if you require sound and you have to use the latter you will need a headphone jack to auxhilary lead to go from the headphone port of your laptop to the line in on your tv
Jan 19, 2011 | Toshiba Satellite Pro L300 Notebook
Can I connect my Toshiba NB 205 to my TV to watch etflix movies? the netbook has a VGA out, and the TV has S-cable and HDMI inputs. Thanks!
May 31, 2010 | Toshiba Computers & Internet
Hi, I purchased a Toshiba M363 in China. I am trying to connect it to my TV which only has HDMI connection. Although I have a HDMI port on my laptop which is also connected, I can't get my monitor to...
Have you turned your TV via the Input or Source on your TV or remote to HDMI? Also look at your "F" keys to see which one switches the computer to TV mode. Generally on Toshiba's it's the F5 key. Try pressing "Fn + F5" simultaneously while you have the TV set in HDMI mode.
Mar 20, 2010 | Toshiba Satellite Pro L300 Notebook
Sony Viao HDMI to Panasonic Plasma TV HDMI Input handshake
Try all of your HDMI inputs, one may be rated at the correct voltage to be able to display the video. The offical part that Panasonic was giving for this was PDPHDMIKIT, its basically a HDMI extender that regulates the voltage. The part is still available online, try partstore.com or andrews-electronics.
Apr 23, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
