Question about Music
Use 1000ma instead 1200ma is this a problem - Music
Tune Guitar strings 1,2 & 3 to Banjo and play with finger pickers. Bass strings to accompany. Developed complicated chords (Including Bass strings) I need to record this on paper - any tips?
Are you familiar with Tablature notation. It's instrument specific and instead od a regular staff you maje a duagram od the instruments strings looking down on the neck and then instead of notes the number of the fret goes on the relevant 'string'
https://www.guitartricks.com/helptab.php
and it's similar for banjo. Google tablature explained and a page comes up with a selection of instrument tabs.
Sep 15, 2017 | Bass Music
My korg x5d doensn't show bank A anymore. Instead of A01 - pipedreams lcd screen shows blinking A01 and InitProg01???
You can try this.
STEP 1:
Set Program protect and Combi Protect to OFF.
- GLOBAL
- Using PAGE+ or PAGE-,
find untill the display show "3A-MEMORY PROTECT".
Set the parameter to OFF by using YES or NO button.
STEP 2:
Data Load.
- GLOBAL.
find untill the display show "05A-PRESET DATA".
Change ALL to PRG (your case).
Use Left/Right Arrow button to moving cursor.
Choose "PRE-a" (your case).
Move cursor to "OK?".
Press YES when "OK" blinking for confirm.
Exit (Go to PROG button).
Feb 26, 2013 | Korg X5d
I'm having problems with a Behringer PMP5000 board. the dual effect chanel instead of number 0-99, it come up as letter and number i.e e1-5
In spite of the display, does the effects work and do they change when you dial up and press the knob down? If they do, then likely the display is at fault. If the effects are NOT working sound wise, check the +5 volts as the whole effects runs from that, It should be within 10% of the 5 volts.
Sep 30, 2012 | Behringer Europower Pmp5000 Powered Mixer...
I have purchased a replacement power cable for my dm5 pro and it doesn't seem to work. it is a uk ac 9v 1000Ma adapter. what is the problem? how do i solve it? thanks, lee
Make SURE the adapter is NOT a DC output adapter. You need 9VAC output at about 1000ma. (1 amp) Many people try to use "universal" dc adapters and they will NOT work with the DM5.
Aug 23, 2011 | Alesis DM5 Pro Drum pad (DPDM5P)
When I hit each button, it plays each note twice instead of once. This is without holding down the note repeat button. This same issue happens when I am playing back the beat; each note hits twice instead...
Make sure you are NOT in looping mode. Make sure you do NOT have effects such as reverb inline to the amp and speakers. This will cause an echo of the note.
May 08, 2011 | Akai Xr20 Xr 20 Beat Production...
Hi My yamaha PSR S500 keyboard is not turning on! I bought a new adaptor but it still wont come on
Check that your adapter is a 12VDC with a current rating of at least 1 amp (1000ma) AND that the center pin of the connector is the POSITIVE.
Feb 07, 2011 | Yamaha PSR-S500 Digital Keyboard
I need to know the polarity diagram for the ypt-220 so I can use a replacement power tip
The YPT220 is similar to many of the PSR keyboards and will use the same adapter. MOST, like your YPT220, use an adapter with the center pin positive AND are protected by a series diode in the keyboard such that damage will NOT occur if wrong polarity is used. You should use an adapter that provides 10 to 12 volts with positive on the pin and negative on the shell capable of 1 amp (1000ma).
Dec 18, 2010 | Yamaha YPT220 PAK 61 Key Keyboard wAC...
How can I connect my mackie mixer 1202-vlz3 to my mac mini
use the xlr (3 prong) main left and right outputs of the board. get xlr to 1/4 inch cables. one end will be 3 prong, to plug into the mixer, then the other end will be a mono 1/4 inch plug, like a big headphone plug. Then you have to get a dual mono 1/4 inch to stereo 1/8 inch adapter and plug it noto the line in. if there is no lone in, but a microphone jack instead, you will get a mono signal instead of a stereo signal. in this case, just use 1 channel of the mixer, instead of both of the stereo outs, and use a single mono 1/4 inch to mono 1/8 inch adapter.
the xlr to 1/4 inch cables can be purchased at a music store. the 1/4 inch to 1/8 inch adapters will probably need to be purchased at radio shack.
Nov 03, 2010 | Mackie 1202vlz3 12 Channel Mixer
Brand new mixer pmp3000 and two brand new speakers (passive) new cables.. plugged in mic , signal is shown but no sound out of the speakers. why????
Make sure the slider switch is set to the correct mode.
The TRIM controls must be advanced while the sliders are at 70%.
A common problem is to MISTAKENLY plug 1/3 inch input cable into the Effects Insert jacks instead of the inout IF you use 1.4 instead of XLR inout.
Make sure the channels of interest are NOT muted!
Dec 05, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Music Logo
24 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
