Question about Goulds Pumps Goulds J7S Single Nose Shallow Well Jet Pump, 3/4HP
Our power was out for about 5 hours in -30 degrees C. the next day our water ran out- the pump was running dry and hot so we shut everything down. Thinking that the lines were frozen we poured hot water and salt down the pipe lines sucked it out and repeated. It took us while to keep the pump primed but then when we finally got it going the pressure stayed at 40psi and the primer casing bolt got really hot so once again we shut it down. Any suggestions why that top bolt would get so hot??
Duo Therm Heat Pump Does not Run, Shows Aux Heat Mode, Switches to Furnace Heat
The control that monitors the cutoff temperature may need to be adjusted. Your hetpump may also work effectively at 16 degrees. you have not left any information on the make or model of the heatpump or the thermostat.
Aug 16, 2014 | Heating & Cooling
Waterco 4555100e spa pump
most timers run on a 24 hour cycle may need to reset the timer so the tub will run until the desired tem is reached OR drain some water out and refill with hot water from your in-house heater..help it catch up..
Jan 10, 2014 | Pool & Spa
First My sister inlaw has a 3/4 recirc line. used the by pass h&c under last faucet to use cold as recircu line. Note acutal 3/4recirc is in kitchen but even thou closer to water htr. it is last for...
I don't understand everything being asked, so add a comment any time.
Problem1 is excessive electric bill.
Suspect is new 120Volt Taco recirculation pump.
Look at motor nameplate for amps and watts and HP. Taco pump is usually robust 1/3 HP which is 252 watts or same as running four 60 watt light bulbs.
If pump runs 18 hours per day x 252 watts = 4536 watts or 4.5 Kilowatts per day
Buy a kill-o-watt meter that plugs into outlet, and plug Taco pump into the meter for 48 hours.
This will give you total watts used for that time period.
1000 watts = 1 kilowatt.
Electric bill is probably 12 to 20 cents per kilowatt.
So if Taco uses 4.5 kilowatts per day, that is $.54 to $.90 per day multiplied by 30 days.
So cost is $15 to $30 per month.
Problem2 is Taco runs too long.
Taco operates either by thermostat or by timer. You choose which mode by using slide switch that is usually located under the timer dial. Set switch to TIMER to use timer, and ON to use thermostat, and off to turn TACO off.
If Taco is set for thermostatic operation, the Taco might be defective. Or there could be crossover problem at single handled faucet.
Another problem could be air in the water line: install air vent.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Water-heater-recirculation-system.html
http://waterheatertimer.org/How-to-set-timers.html
Jul 17, 2011 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
Pump lost its prime ran for several hours dry motor runs and pumps water gets very hot and shuts down after about 30 seconds
ITS GOING TO NEED SERVICE. LOOK FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY, USE YOUR ZIP IN YOUR SEARCH
Aug 18, 2010 | Pool & Spa
My 1991 F-150 stalled out on me after driving 200 miles in 90 degree weather I flashed out the codes which told me it had a lean burn, primary fuel circuit failure, secondary fuel circuit faiure, and ecm...
Ethanol fuel in hot weather will vapour lock easier than the old non-ethanol fuels.
Maybe that was all it was.
I get the calls ........usually from shopping centers on very hot days on cranking but no start cars.....and it is 80% just a vapourized fuel problem. TOO HOT FOR THE FUEL UNDER THE HOOD.
The cars start the next morning....or late in the evening.
Aug 23, 2009 | 1991 Ford F150
Engine starves for fuel after running about 50 miles or so...
Has Neon do same, I ran fuel at low level, on hot day, ran engine until it started to act up & threw a fuel pressure gauge on it. Was at approx 5 psi. Cold next morning, 48-50 psi. Always hot day about 30-40 miles into work in morning, o.k. Sit in hot sun all day & would happen 3-4 times on way home. Sit and let cool, 20 minutes or so & go again for a while. Cool day, no problem. Change pump I would.
Jul 21, 2009 | 2004 Chrysler PT Cruiser
Our Eiki LC-986 projector has worked flawlessly for at least 3 years. Last week, the projector shut itself down after approximately 30 minutes of use. This happened at least 5 times, so we replaced the...
It sounds like it is overheating. Are the fans all working? If so, try opening the casing and blowing all the dust out with a can of air from Staples/Office Depot. If the fans aren't working you may need to replace them.
Jun 15, 2009 | Eiki LC X986 Multimedia Projector
2001 S-10, Blowing "ECM Batt" fuse after running for about 30 min
that fuse feeds power to fuel pump relay circuit that feeds pump could be defective pump,or damaged circuit wires that shorts out! and not a good idea to put higher fuse in circuit could cause more damage to circuit! but i know when your stuck, u do what it takes,so inspect circuit related to fuse,
Mar 10, 2009 | 2001 Chevrolet S-10
Kenmore
when its running how hot are the sides the starting amps are too high and 1.5 running amps ain't bad now the the cut in cut out are too high if you look on the dial that the mid point settings that's where you should have it not on 1 1 is hot set it on the straight line that's where you should do all your testing colder settings go up not down you could be overheating the compressor by making it come on too quick the freezer should be about -10 or so do you see any gaps in the gasket
Mar 31, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Goulds Pumps Goulds J7S Single Nose Shallow Well Jet Pump, 3/4HP Logo
35 people viewed this question
Top Goulds Pumps Plumbing Experts
Steve
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Goulds Pumps Plumbing Expert? Answer questions, earn points and help others
