Question about Proform Pro-Form TDF Bike Gen 2 - Pro-Form TDF Bike Gen 2
Resistance with gear setting 1 - 1 and 0% incline feels high.
Using TDF Stage 1 profile, the resistance seemed to be high for the gear setting and 0% incline. I stopped the exercise, switched OFF the bike then re-entered a new exercise in MANUAL mode with the same settings with the same results.
maxtreadmill
  • 832 Answers
SOURCE: Just bought my Proform 490 LE elliptical 1 day ago
If you purchase from a store I would take it back and exchange it, or if you purchased it on line then the manufaturer and have send somebody out to take care of this situation you have a warraty on the unit
Posted on Mar 13, 2010
maxtreadmill
  • 832 Answers
SOURCE: The magnetic resistence level seems to be the same
This unit incorporates an adjusting motor for the magnetic boot. This unit also uses batteries for the upper console functions I would check the batteries first and replace them, if you haven't done so before.
If this does not resolve the problem then it could be the adjusting motor, then you will have to pull the the side panels in order to apply a 6v dc to the motor and see if it moves smoothly, if not then replace motor.
Posted on Jun 26, 2010
  • 3 Answers
SOURCE: My Pro-Form 490 LE has
Open the rear part where the "guts" are. The magnet will be stuck against the wheel that turns when you pedal because the cable that the resistance motor pulls to remove the tension will have too much slack in it. The cable probably came off of the pulley wheel that is used to providing the necessary tension to pull the magnet off of the wheel.
To get the case off, simply unhook the right side pedal, remove the 4 bolts holding on the crank thing to remove it, then using a philips head screwdriver, remove the screws in the screw holes on the case cover. Be sure to remove the one screw on the other side near the front in order to allow the front part to "unsnap".
Posted on Jul 14, 2011
ercupa190
  • 12223 Answers
SOURCE: My Pro-Form 330 elliptical has a resistance
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Posted on Nov 28, 2011
ercupa190
  • 12223 Answers
SOURCE: Resistance on elliptical acting weird
1) tight the bolts tension for magnet and clean very well. and proof..if the fail
2) go to test the magnet, use again the magnet from your refrigerator magnet, for attraction and repulsion. If do not pass the TEST replace the magnet in any Hardware such home depot, etc.
God bless you
Posted on Aug 30, 2012
What does the code b0026 mean on my 2009 buick lacrosse?
DTC B0026: Driver Frontal Deployment Loop (Stage 1) Open
It has to do with air bag system
B0026 Stage 1 or B0044 Stage 2 ?€¢
The steering wheel module stage 1 or stage 2 high circuit is less than 2.4 volts and the steering wheel module stage 1 or stage 2 deployment loop is more than 6 ohms for 500 milliseconds.
The steering wheel module stage 1 or stage 2 deployment loop resistance is greater than 4.8 ohms for 500 milliseconds.
has to do with
Jun 30, 2015 | 2009 Buick LaCrosse
Precor error codes 53
Precor Error 53, Can't Read Target, Can't Find Home Switch Probable Cause 1. Blown F2 fuse.
2. Home switch wiring is damaged or has intermittent connection.
3. Gear (elevation/incline) motor wiring is damaged or has intermittent connection.
4. Home switch is bad.
5. Gear (elevation/incline) motor is bad.
6. Gear (elevation/incline) motor target is damaged.
7. Lower PCA is bad.
Corrective Action
  1. Disconnect power from the unit. Remove the F2 fuse from the lower PCA. Using an ohm meter, measure the fuse for 1 ohm or less. If the reading is considerably high, replace the fuse. If the fuse is blown, inspect further for the cause to avoid the fuse blowing again. Inspect for damaged gear motor wiring or a bad gear (elevation/incline) motor. Replace if necessary.
  2. Thoroughly inspect the home switch wiring for damage or intermittent connections. Repair or replace damaged wiring or poor connections as necessary.
  3. Thoroughly inspect the gear (elevation/incline) motor wiring for damage or intermittent connections. Repair or replace damaged wiring or poor connections as necessary.
  4. Ensure the moving arm is away from the home switch and disconnect power from the unit. Disconnect both wires from the home switch. Using an ohm meter, check for approximately 0 ohms. Continue to monitor the home switch resistance and activate the home switch by hand. The reading should change from approximately 0 ohms to open (infinite). If either reading is considerably incorrect, replace the home switch.
  5. With unit disconnected from power, disconnect both wires from the gear (elevation/incline) motor. Using an ohm meter, check for approximately 9 ohms through the gear (elevation/incline) motor wiring. If the reading is considerably high or low, replace the gear motor.
  6. Inspect the gear (elevation/incline) motor target for rips, tears, or bad scratches. If any of these are found, replace the target.
  7. During the start up sequence, check the voltage at the gear (elevation/incline) motor. Voltage should be approximately 12VDC. The voltage should only be present between the time the sequence was started and the error 53 occurred. If the voltage is considerably low or absent and the F2 fuse proved good, replace the lower PCA.
Precor Error Code 53
Nov 02, 2013 | Cars & Trucks
My Schwinn doesnt gain speed
axel bearing either is bad or needs grease or not adjusted correctly
Oct 08, 2012 | Schwinn 700c Mens DSB Dual Sport Bike
Reebok z8 feels like its on an incline even when it's on zero incline
1) readjust the speed sensor, clean it and tight the wires connector well
2) see the block diagram.
3) RUN the software calibration for diagnose, troubleshooting , fix it
4) lube the gear and shift elevation motor.
5) adjust the POT, a little and see if you have a better improve.
6) see the diagram, and proceed
God bless you
Jul 09, 2012 | Reebok Exercise & Fitness
Ge profile f2 error while broiling in upper oven
F2
During
BAKE Control senses oven
temperature above 615F-630F If actual over temperature condition occurred: Look for
welded relay contacts on bake or broil relays. If this happens, replace oven
control (also called clock or ERC).
If no over temperature condition
occurred
: Look for a high resistance connection or any other cause of high
resistance in the oven temperature sensor circuit. Check sensor, sensor harness
and sensor harness connection at sensor and oven control. Replace sensor if
found defective.
Remember: Oven control (ERC) measures resistance
of sensor circuit , not actual oven temperature. F2
During
CLEAN Control senses oven temperature above
915F-930F If actual over temperature condition
occurred
: Look for welded relay contacts. If this happens, replace oven
occurred
found defective. Check door lock switches.
(ERC) measures resistance of sensor circuit , not actual oven
temperature.
Jan 24, 2011 | GE Profile JTP56 Electric Double Oven
When using the oven the error code F2 comes on. What does this mean and how do I get it fixed?
F2
During
occurred
found defective.
During
occurred
occurred
temperature.
Dec 19, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Ref. Ice despenser motor does not turn. Auger turns
I had this same problem today, and after tearing apart the door and digging with the multimeter, I found that the bulb was drawing to much current {probably due to age} and that pulling it made everything else start working. The high resistance was drawing too much current from the IC on the door panel board.
I'm going to get a new bulb tomorrow, but if you yank the bulb it'll probably work. {If you have the same problem}
Nov 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
1983 dodge power wagon 4x4
put truck in reverse hit brakes constantly and then go for drive in first gear. .... problem was brakes got all locked up ...... to not drive a vehicle is the worst thing u can do to it . hope i helped ELI
Nov 02, 2008 | 1983 Dodge Ram 50 4WD
About visual basic coding
The standard way of creating a database using VBA, which can be modified to suit your needs is this--> Note: the code (wspDefault.CreateDatabase("Newdb.mdb"...), can be altered to save the database in a folder  such as "C:\NEWDB\text.mdb". sub NewDatabase()     Dim wspDefault As Workspace, dbs As Database     Dim tdf As TableDef, fld1 As Field, fld2 As Field     Dim idx As Index, fldIndex As Field     Set wspDefault = DBEngine.Workspaces(0)     ' Create new, encrypted database.     Set dbs = wspDefault.CreateDatabase("Newdb.mdb", _         dbLangGeneral, dbEncrypt)     ' Create new table with two fields.     Set tdf = dbs.CreateTableDef("Contacts")     Set fld1 = tdf.CreateField("ContactID", dbLong)     fld1.Attributes = fld1.Attributes + dbAutoIncrField     Set fld2 = tdf.CreateField("ContactName", dbText, 50)     ' Append fields.     tdf.Fields.Append fld1     tdf.Fields.Append fld2     ' Create primary key index.     Set idx = tdf.CreateIndex("PrimaryKey")     Set fldIndex = idx.CreateField("ContactID", dbLong)     ' Append index fields.     idx.Fields.Append fldIndex     ' Set Primary property.     idx.Primary = True     ' Append index.     tdf.Indexes.Append idx     ' Append TableDef object.     dbs.TableDefs.Append tdf     dbs.TableDefs.Refresh     Set dbs = Nothing End Sub
Hope this helps! Please let me know if you have any questions.Thank You,Raph30
Apr 10, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Proform Pro-Form TDF Bike Gen 2 - Pro-Form TDF Bike Gen 2 Logo
512 people viewed this question
Top Proform Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Proform Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
