Question about Canon Imagerunner 1025IF Grayscale Copier
Lines copies Black lines are on each side of the papers being copied.
  • 26 Answers
SOURCE: Black Line printing on copies
Just clean the glass top of the scanner and the slit of glass on the left hand side of the scanner.
Posted on May 20, 2007
SOURCE: Black line on copy while using paper feeder
try cleaning the feeder glass
Posted on Dec 04, 2007
SOURCE: Wide black line down middle of paper
I have same problem, with new ink cartridge, also tried cleaning the print head, no luck.
Posted on Jan 15, 2008
SOURCE: black line on copies
If your copier has an automatic feeder and your line is present when using the feeder but not when you copy from the glass,just clean the small glass at the point where the line appears.
Posted on Feb 29, 2008
Cogz
  • 1326 Answers
SOURCE: Black stripes on copies using a Canon D1120
Do you use the Doc. feeder? Try to make a copy off the copy board glass. Is the line there? Now make a copy with the adf. Is the line there? If so, you need to clean the small glass under the doc feeder. It looks like a glass ****, about a 1/2 inch wide. Clean it with windex and that should solve your line problem...
Posted on May 12, 2010
Single narrow black vertical line about 1 3/4 inches from right side of copy. Line runs the entire length of the copy. Happens only during copying color or black and white.
The line issue is caused by something on the image sensor. To get to it and clean it just pull the front up where you put the paper into it to scan. Inside you will find a glass strip, this is the image sensor. Use a paper towel dampened with window cleaner and gently scrubbing the glass strip, After cleaning the strip let it dry for a minute or teo before you close the cover and try a scan. It should be clear and should copy great again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
Jun 18, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
3 thin black lines on copy
Do the black lines show up when you use the adf or if you make a copy from the copyboard glass. If the lines only show with the adf > there is a small **** of glass on the left side of the copy board glass > I would clean the slip glass with windex or a damp cloth..... Good Luck
Jun 08, 2010 | Canon imageRUNNER iR C2880 Color Copier
The screen says the Paten glass needs to be cleaned. What is the paten glass? Also when copies are made a black line is showing up on the edge of the copy.
paten glass is the copy board glass.try cleaning both side,if still same.it can be off in additional funtion [copy board glass sign.turn it to off ]
Mar 17, 2010 | Canon imageRUNNER 1023iF Black and White...
Black line down one side of paper
Lift the auto feeder cover and clean the narrow glass that the originals are scanned across...sounds like you have some dirt there -maybe correction fluid? That's the most common.
Please rate me :)
Jun 23, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Black line down the side of copied paper
is this on only copy or also on received paper.if only on copy just check ur fax scanner may be it is dirty .just clean it with a soft tissue .may be some led is gone dead inside the scanner.just see whole lamp is working or not.MIAN AKHLAQ
Nov 25, 2008 | Office Equipment & Supplies
Black line down paper
Please clean the scanner bed with clean cloth and then scan
May 14, 2008 | Canon imageCLASS D860 All-In-One Laser...
Canon Imagerunner 1025IF Grayscale Copier Logo
old marine
old marine
