SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
SOURCE: AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
SOURCE: How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
SOURCE: tengo una lavadora aeg lavamat
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
