Question about Packard Bell Istart 2479 8 In 1 Card Reader Go-c81lar
I need a card reader driver go-c81lar download
Computer does not recognize card reader
You have need to install card reader driver for windows 7, download driver or if you have driver CD install card reader driver then try it will work.
Jun 16, 2012 | GE Televison & Video
Acer card reader driver
These are the card reader drivers available for download from the Acer website. One of them will be correct for your reader.
Card Reader Driver
Card Reader Driver (TI7412)
Card Reader Driver
Card Reader Driver
May 07, 2012 | Acer Computers & Internet
SDA Standard Compliant SD Host Controller not working
That's associated with your Card Reader. The SD Card is a type of card that you pull out of your camera and plug into the computer. Try going to your manufacturers site and download and reinstall the Card Reader or SD Card Reader Drivers.
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Card Reader or SD Card Reader drivers.
May 02, 2012 | Toshiba Computers & Internet
Question mark at mass storage adapter it says no driver installed. for gateway mx6453
There are a few drivers that may need to be installed.
Click Here to go to the download page for your model.
Once there, bookmark the website, as you may need it in the future.
Second, download the "Chipset" driver - install it by double clicking on what you downloaded, then after it finishes installing - reboot your computer. (THIS SHOULD FIX IT)
Check to see if the problem is still there.. if so, try the following drivers from that website:
Card Reader Driver (TI 2.0.0.9)
Card Reader Driver (Gateway 2.0.0.2)
Memory Card Reader Driver (Gateway 1.0.3.2)
Feb 23, 2011 | Computers & Internet
My card reader on my samsung q45 does not work i have tried everything i think i need a new card reader
try first the new card if it si working or not , if the same problem the card reader terminal has a problem need to open the unit and fix
Sep 11, 2009 | Samsung Q45 Notebook
Downloading pictures from a memory card
Generally card readers will either come with a built in driver, or it would come with a driver disk. You may need to visit the website of the card reader to check for downloadable drivers is possible.
Oct 17, 2008 | Archos 605 WiFi Digital Media Player
On my toshiba R100 / SD card reader doesn't work
this problem bugged me for weeks!! finally figured it out today
download the sd card reader drivers from toshiba (not a 3rd party site) boot into safe mode delete all the sd card reader drivers currently installed install the downloaded driver reboot into normal mode
let the computer go about its business installing the driver, then it should work.
cheers, thomas..
Sep 28, 2008 | Toshiba Portege R100 Notebook
Sound card
Hi Zigma,
Some internet applications needs video and or sound stream controls needed some file to run or view. In this case, you can hardly tell what downloaded programs you have installed that overrides the default installed drivers. In some case upon uninstalling some program it will ask "are you share to remove the shared file xx.xx?" Now to regain back the sound card driver you had. You must check the sound card driver at control panel sound settings property. Remove it or update the driver you will need to. Note: check if any the soundcard driver file properties has an error marked. This helps you determine the drivers fault or conflicts.
Best regards,
Rosener Guyano
Jan 14, 2008 | Computers & Internet
Download pics
If you are using a removable memory card, you can get the images directly from the memory card by using an external card reader (if your computer does not have a card reader for your type of card built in). If you need to download the pictures directly from the camera via the usb cable, you can get the driver from the samsung website... you'll probably have to download drivers for the model 401 which I believe is the same as the 4010. If your computer is running Vista, new drivers may not be available, in which case you will need to use a memory card and card reader.
Nov 10, 2007 | Samsung Digimax 4010 Digital Camera
Packard Bell Istart 2479 8 In 1 Card Reader Go-c81lar Logo
192 people viewed this question
Top Packard Bell Computers & Internet Experts
carey w mason
carey w mason
Steve Sweetleaf
Steve Sweetleaf
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
