Touch screen not working
Turns on but no touch screen
  • 790 Answers
Not enough info. give unit model and details.
Try a Factory Resteration
Posted on Apr 16, 2014
How do I fix my acer aspire touch pad?
some touch pads have a tap to turn off, and a double tap to turn back on... also check you F keys.
Jun 03, 2014 | Acer Aspire Computers & Internet
is it just the touch that stops working? or all off the computer?
May 22, 2014 | Toshiba Satellite Computers & Internet
T-Mobil My Touch cell phone touch screen randomly will not work. Sometimes brings up screens without touching screen?
My son's had dropped his t-mobile so many times it did the same thing. I was able to order the touch screen from amazon for $18 then I looked up on YouTube how to replace the screen and it was very easy to replace by watching the video. I think this is the cheapest fix for your problem.
Feb 24, 2013 | T-Mobile My Touch Cell Phone
Try to remove the battery and insert it back into your gps device and turn it on. If the screen does not still work, then you need to reset the nuvi, by holding down the power button for about 15 seconds, then the unit will restart, that way the touch screen should respond. If it still does not work, then you need to calibrate the screen to get it to work. To calibrate the screen, follow the sreps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi,
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears (white screen with touch dot),
  5. Then follow the on screen instructions.
It might not work trying it once, so you have to try it over time till it works. Calibration is the last resort of all solutions, so if calibrating it does not do the work, then it means it a an internal problem.
Dec 25, 2010 | Garmin nuvi 650 GPS Receiver
My touch screen doesn't work. i tried to calibrate it but it doesn't even go into calibration screen. please let me know how i can fix it. thank you
Since the touch screen is not working, what you have to do is to reset the device. To reset the device, turn it off and on to see if it does the job. If that does not do the job, then hold down the power off/on button for about 10 seconds, the device restarts, that way it should work, but if it does not still work, the only solution is for you to jeep calibrating the screen continuously till you get it done.
The proper process to calibrate your screen is for you to:
  2. press your finger on the upper left corner of the screen (that is before powering on),
  4. Continue to hold on to the touch screen with your finger for about 30 seconds or more till the white calibration screen comes on(white screen with touch dot),
  5. Then follow the on screen information.
Try it several times till you get it to work. It does not just work the moment you try it, you have to try it over and over again.
Dec 24, 2010 | Garmin nuvi 205 GPS Receiver
What to do? touch screen just stopped working? worked, and then 30 minutes later nothing...turned off/on several times, can't enter PIN or push "view map".
Try to remove the battery and re insert it back in to see if it will work. Or hold down the power on/off for about 15 seconds, that should do the job.
If that does not do it, then calibrate the screen, to calibrate the screen, follow the steps below:
  3. While holding your finger on the touch screen, turn on the nuvi.
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears(white screen with touch dot),
That should do the job for you. hope this helps.
Dec 24, 2010 | Garmin nuvi 255W GPS Receiver
When I turn on my NDSL the touch screen is white
The bottom screen is made up of 2 parts the screen itself and the touch screen mambrane which sits on top of the screen, if the touch part is still woking then the screen is faulty and will need to be replaced.
There are some good videos on youtube that will run you through the process of changing just the screen.
Mar 27, 2010 | Nintendo DS Lite Console
Ipod touch screen not working
!!Power it off first!!!
open.. make sure its pluged in all the way,
check for bent/broke wire,,
how did the old digitizer face get broke?
Were did you get the new face?
Mar 12, 2010 | Apple iPod touch
Touch screen not functioning properly. Press one key, get another
The touch screen on Garmin Nuvi 660 is not working at all. It turns on, but when I touch the screeen, nothing happens. Could it be the battery. It was low, so I charged it for 45minutes, then the gps screen dimmed and turned off after just 10-15 minutes of "messing with it"
May 25, 2009 | Garmin Nuvi 660 GPS Receiver
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
