Will not turn on unless it is unplugged numerous times. Changed power supply board and still does the same thing
I replaced the power supply board. After two days it will not turn on? I am trying to determin if the plugs in the lower right corner are plugged correctly? they both have four wires. One set has a yellow wire, one has a red wire. I have the yellow wire plug in the lower connector. IF they are correct do you have any suggestions? The Power board cost $130.00. What else would cause this problem?
  • Harold Montgomery Feb 12, 2014
    My TV is a Hitachi model42HDT50M The power supply is a MPF7404 Part #HA01134.. I was told told the power supply board would cause the TV not to power up unless you unplug and plud back in numerous times. Changing the power supply board did not help
  • Televison & ... Master
  • 4,006 Answers
As there is no model number given it could be a software problem, if you turn on the tv and the light changes and stays change but the tv wont turn on it can be the software for the tv is not booting up, tv's with log boot usually do this but a software fix usually sorts it out. check the manufactures web site to see if there has been any updates or reflash using the old file from there firmware page.
Posted on Aug 10, 2017
  • 61 Answers
SOURCE: wire diagram for splitter
On the 205064 hv splitter with the splitter mounted in the set,left to right, hv transformer,red tube,green tube,blue tube,plug on right side goes to screen asy,the black wires plug on the left side of splitter,which are grounds.
Posted on Mar 04, 2008
SOURCE: Power problem
OMG!! I had the exact same problem! I unplugged the TV to paint and it stopped working with a flashing green button. I ran my fingers along the bottom of the screen and it actually worked.. wow THANKS A TON!!!
Posted on Jul 06, 2008
WeListen2You
  • 538 Answers
SOURCE: power supply has a short
sounds a lot like the auxiliary power for the other parts of the board..replace power supply
Posted on Oct 09, 2008
SOURCE: Replace Light Engine
I have the 62HM95 and my light engine went out between 2 and 3 years. I will never buy a Toshiba again. I have had nothing but trouble with the components and the customer support. I am in a class action lawsuit with them, but I doubt very much will come of it.
As far as fixing your TV I was in the same delimma as you. I wasn't willing to pay nearly $1000 to get this set repaired when it already cost $3000 and it started having problems within the year and major issues after 2-3 years. I was willing to risk a couple hundred bucks that I could fix it myself. If you aren't very handy with taking things apart and putting them back together, by all means don't do this. It is pretty easy to do and you can figure it out as you go, but I wouldn't suggest you doing this if you weren't willing to take the risk of really messing it up.
I didn't go to Part Store.com because they wanted $456 and then when I finally decided to do it they raised the price to $556...No way, I found http://www.tristatemodule.com/html/light_engines.html and you can get a light engine that is refurbished for $250, or you can have your light engine refurbished for $200, which is what I plan to do if this one fails in the next two years. I looked at their site and it doesn't show that they have any in stock, but they may if you call. I wasn't comfortable sending mine off to be refurbished because I wasn't sure if I would remember how to put it back together, and I'm glad I didn't because the one they sent me didn't work, which sucks, but it happens. I called them back and sent it back to them and it worked fine. All in all, I had no instructions or any other help besides my memory of how I disassembled it and it only took me an hour at the most, not really too hard.
The only other issue I had with them and it really wasn't with them as much as Toshiba is, I received a light engine for a 46" model, which when I talked to Toshiba they swore up and down that it wouldn't work, when I talked to TriState about it they said that Toshiba would say that and they had used it in 1,000's of 62" models and it's worked fine. After they replaced the broken one they sent originally, the new one worked fine and is still working brilliantly and I have my original 62" light engine to get refurbished if anything should happen again. Their shipping time was good and when I returned the product to them, I received a working part pretty quickly.
For $250, this would be the only way I would go. If this hadn't worked, I probably would have just went out and got a different TV. I hope this helps.
Michael
Posted on Nov 17, 2008
SOURCE: Toshiba 57H81 Flashing Red Power Light, Blown Fused F850+F852
Solved by resoldering some solder joints!!!!!!!
Toshiba Model 57H81 Rear Projection TV - Purchased 11-09-2001
Problem: Toshiba 57H81 Flashing Red Power Light, No Picture/Sound, Blown Fuses F850 + F852
Symptoms January, 2009:
  • Upon turning on set I got flashing red power light and nothing else.
  • Removing plug for one minute and plugging in results in:
    • Audible click, steady red power light for 2 seconds then slow flashing red light
    • Pushing power button results in steady red for about 2 seconds then slow flashing red light, no other set activity
  • Removing power cord for several hours and plugging back in made no change
    • Audible click, steady red for about 2 seconds then slow flashing red light
  • Possible related note: Over past several months occasionally the entire screen would flicker momentarily and at other times be problem free for weeks.
  • Fuses F850 and F852 found blown
Repairs Made:
  • PD0074 DEF/CON Power Board
    • There are two main power supply capacitors in this set. They are C-809 and C-810. One their negative lead on the printed circuit board re-soldered leads and nearby contacts. I’m told that because the factory left out a printed circuit board eyelet, the connection will come loose over time. When I called Toshiba customer service they said there was a known solder joint problem causing blinking red light.
    • Replaced blown fuses F850 and F852.
      • I actually installed a fuse panel on the inside of the cabinet and routed the fuse connections here instead of ordering the special fuses and replacing them on the circuit board.
      • Had to use a 5 Amp SLO-BLOW for F850. Fast blow does not survive power up. Get the red blinking light.
      • Used a fast blow 2 Amp for F852.
  • PD0073 SIGNAL Board
    • Re-soldered Q751 + Q752 STK392-110 Convergence Amps
    • Re-soldered adjacent pads that looks suspicious
Total Cost to Repair about $10
  • Twelve hours of my time over three days to research issue, disassemble set, make repairs, add fuse panel.
  • Already owned Service Manual and Circuit diagrams from a different 2004 repair.
  • Less than ten dollars at Radio Shack for fuses and fuse panel. Already had wires, etc.
  • Some solder. Already owned de-soldering tools, etc.
  • Visited both local authorized Toshiba factory service repair facilities. One said repair would have to include replacing Q751 + Q752 STK392-110 Convergence Amps with ST392-180, and realigning set for a total of $500+ and it would be more if they had to order a power board. NO THANK YOU! Other shop said $65 for site visit and $30 to make an estimate that could be applied to repair.
Posted on Jan 05, 2009
Tv wont turn on, not power supply board
If it's a samsung they have a one time free repair. Call 1-800-Sam-sung. Your model may be on the list
Apr 02, 2015 | Televison & Video
Vizio lcd tv keeps turning off
Since you replaced the power supply,it couldn't be bad capacitors so I would replace the main board.
Mar 19, 2014 | Vizio L32 32 in. LCD HDTV
Tv will not turn on unless it is unplugged numerous times and will not stay on unless it has a program at all times? If not, it goes to standby and shuts off 42HDT50M Hitachi
There are components on the power supply board that are failing. www.shopjimmy.com has a wide array if service parts kits that contain the most often failed components. Prices are good. These are for do it yourselfers, so if you are uncomfortable with a soldering gun, then have a repair shop do it. After 11 years, though , it may be time for a new one.
Jan 24, 2014 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
My vizio worked fine and then it will not turn on unless the manual button is pushed and held numerous times. once on the remote works fine and can turn off. any cheap or easy remedy?
could be just bad capacitors on the power supply board they tend to puff up on top and then several attempts of pressing the power buitton is required to finally get the set to power up.
Feb 01, 2013 | Vizio VA26L 26 in. LCD HDTV
Panasonic viera th-50pz800u won't turn on. Red power light blinks 10 times.
thats a sos error for numerous supply voltages missing. Send a email to me for assistance as I cant post the info here slinteriors@yahoo.com
Apr 01, 2012 | Panasonic Viera TH-50PZ800U Plasma TV
My e-machine t-3616 makes a beeping noise when I try to power on. It will not power on unless I plug, and unplug numerous times then finally it will start up.
If you've never changed the battery in your computer, I would try that first. It is sort of like the batteries that you would see, say in a bathroom scale, and it keeps your system information such as time and date current even when your machine is unplugged. After five years, it may simply be too drained to do its job.
Nov 12, 2011 | Gateway Computers & Internet
The tv starts to turn on I hear a high pitched noise then it turns right back off. This will happen 3 times and then it won't turn on at all unless I unplug. It is a RCA model # R52WH74.
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where.If otherwise, Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Jun 15, 2011 | Televison & Video
My toshiba regza model 32wl68p is difficult to turn on from standby.Ihave to unplug in and retry numerous times before it turns on
Please replace bad capacitors in power supply board or replace complete power supply board available HERE to solve tv problem.
Thanks.
Jun 09, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
For the past 4 days or so when I turn it on it will cycle on/off numerous times before powering up and staying on. Today, however (5/26/10), it would not power up at all - nothing, no light in front, no...
Ur tv the power supply board before it have those parts call capacitors it have gas leakage,that why u turn on/off numerous times it powering up.The power supply board,the board the a/c power cord go into it.that ur power supply board.Now all those gas leakage capacitors are bulges up on it top or puff on it top are total dead now.U know basic electronic's and soldering?Searches all around the power supply board and it supporting boards.Replaced all those defective dead capacitors that bulges up on it top or puff on it.Ur tv power well return and work.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 26, 2010 | Vizio VP322 32 in. Plasma TV
32 LCD, Shuts off, power light flashes 7 times. Never stops. Will not turn back on unless I unplug. Works for a few mins and shuts off again.
Power supply board is dead.Replaced the power supply board will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 22, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
Televison & Video Logo
Top Televison & Video Experts
