Question about 2007 Nissan Titan - All Titan models - Windshield Sun Shade
Cooling system whenever going up slopes it starts to overheat .... or in traffic .. anyother times it runs normal
    New Friend:
  • 4 Answers
It could be an intermit water pump or thermostat, if not those I would check the head gasket
Posted on Feb 12, 2014
The radiator fan on my 2007 bmw 525i works fine while car is driving. Once i stop at a red light or in traffic the the fan stops working, ac blows hot air and mins later the car overheats. The car has a...
My guess is that your electric fan is NOT operating at all. Under normal conditions, just going down the highway, your cooling system will function just fine without a fan running. The air flow through the radiator is adequate to keep things cool. However, when you stop, you quickly get into an "overheat" situation. Actually, you should be able to hear your fan begin operating when your engine temperature starts climbing or your air conditioner requires the fan to do its thing. Note: If you've ever severely overheated your engine, your problems may be worse than just a fan not running, but you really do need to confirm whether your fan is operating correctly, or not. Another note: I had a vehicle with a tendency to overheat when stopped. It turned out to be a faulty (leaking) pressure cap on the cooling system.
Nov 04, 2013 | BMW 525 Cars & Trucks
Overheating problem, what is the most probable cause?
You need to stop using it immediately before you
cause some damage or more than you may already have
That is just common sense. It should not overheat or
be any different than it was in the past without problem
The car has to be checked over/diagnosed,tested,etc for
various issues to resolve
Borrow or Rent a car until resolved
No way to guess at the problem
You should have some type of codes avail even
if the check light isn't on,you need professional help
to get a start on resolving
The timing belt maybe worn & jumped or the head gasket
bad.
Over heating isn't usually a cheap repair unless the thermostat
sticks partially closed
The RPM moves around the car is 11 years old,so it may just
need a though going over
Timing Belt,O2 Sensors,Exhaust Converter,Spark Plugs
and such
If you depend on a repair shop to do things & don't
have the knowledge to request work done throughout
the year,then you run into a lack of proactive preventative
maintenance situation. Most things are simple looking
back, once resolved
Sep 06, 2012 | 2002 Chevrolet Prizm
Coolant temp rise to around 210 degrees when idling or in stop & go traffic bur drops back to around 196 when cruising. Is this normal?
completely normal those readings are perfect this car comes with a 195 degree thermostat,210 is fine for stop a go traffic remember a cooling system with the proper amount of coolant in it and under pressure will not overheat till about 240 degrees your in great shape no conerns!!!!!...
Sep 01, 2010 | 2006 Chevrolet Corvette
When idling my jeep overheats. The cooling fan is running and it speeds up when temperature goes up. The temperature gets close to 260 degrees and the engine tries to stall. when I start moving it cools...
At idling speed an engine does build up a lot of heat and the cooling fan will kick in. In slow moving traffic or traffic jams the temperature gauge can touch the red - particularly on hot days. The reason it cools down when you start moving is because of the air flow through the radiator.
Presumably there are no leaks from the cooling system otherwise you would have mentioned it. In normal circumstances the fan will not be running as you are driving at speed, as the air-flow through the radiator is sufficient to cool things. The fan only kicks in to get rid of excess heat - and this usually occurs at idling speed or after you have parked the car.
If the fan is running all the time as you drive, this points to either a fault in the fan switch, or the car is running too hot. presumably in normal driving the fan isn't running and the temperature gauge reads normal?
It is common - in stationary traffic many cars overheat (particularly big engined models) try to stall and 'cut out'. Restarting can be difficult until the engine cools down.
Is your car overheating in normal driving conditions or just at idle speed? Overheating in normal driving conditions can be caused by things like a failing water pump, blocked radiator, collapsed hose, faulty thermostat or, in the worst case scenario, cylinder head problems.
Overheating at idling speed is 'common'. Check your coolant level. If your car isn't using/losing coolant then there probably is no major problem. You can flush out the cooling system and refill with new coolant - and also check your radiator. Are the cooling fins crumbling with age? Or maybe they're partly clogged with insects and debris from the road? A blast with a hosepipe wil sort that out ..
The question is how much does your car overheat in normal driving? If it doesn't .. it appears as though you have nothing to worry about as such. Most cars have 2 speed fans... the 2nd faster stage kicks in at some point dependant on engine temperature. Perfectly normal.
Aug 14, 2010 | 2003 Jeep Grand Cherokee
I have a 2002 Volkswagon Jetta and just started to overheat when stuck in traffic, the gauge goes up to 240 and the overheat light goes on but drops to normal when traffic is moving again - any idea what...
Check
1)thermostat and also that the electric fan is kicking in when it gets above normal temp
2)blocked radiator
3)worn water pump (more so from electrolysis, ie not using the right antifreeze)
Aug 08, 2009 | 2002 Volkswagen Jetta TDI
The car overheats only when sitting in traffic. The temperature will rise to 220 then drop to normal after the car starts moving. The temperature remains normal at all other times and conditions. The...
Hmm.. That is VERY tipical of a fan not working.. Maybe its ot working propery..
Could be the thermostat..
Next time you pull into your driveway --
let it idle in park.. Open the hood.. See how long it takes for the fan to come on.. See if the temp goes way up before the fan comes on..
Hope this helps !!
Please rate me good ;o)
Sometimes when these fans go - it wont spin as fast as it should or as long as it should..
Jul 10, 2009 | 1999 Oldsmobile Aurora
1998 Cadillac DeVille Overheats
The cooling fans will not come on until 225 degrees. Normal temp is around 199-215. Sitting still in traffic most will inch up around 220 or so. When you turn ac on it turns the fans on and may cool down engine, Check fan operation.
Jun 16, 2009 | 1998 Cadillac DeVille
Radiator whines and overheats when not moving
Have someone flush cooling system & check condition of rad for debris in front of rad & blow or spray it out as necessary. Next time it runs hot, turn your heater temperature up high, blower fan on high, and see if gauge starts to come back down a little. If it does, my guess is your rad needs replacing, or at least consider trying a good reverse flushing of the system first, then rad.
Apr 22, 2009 | 1998 Dodge Grand Caravan
Thermostate ranges from overheating to just fine while driving.
is the fan working? if the fan isnt working it will overheat when idling, as it wont be sucking cold air through the radiator. a quick way to diagnose that your cooling system is fine is when stuck in traffic, turn your heaters onto hot, if the engine temp gauge shows that the engine is cooling down, the cooling system will be fine 9/10 times.
hope this helps.
Mar 18, 2009 | 1996 Buick Regal Olympic Gold
2007 Nissan Titan - All Titan models - Windshield Sun Shade Logo
100 people viewed this question
Top Intro-Tech Automotive Vehicle Parts & Accessories Experts
David Harrelson
David Harrelson
Lawrence Oravetz
Tom
Are you an Intro-Tech Automotive Vehicle Part and Accessory Expert? Answer questions, earn points and help others
