Question about Sony CMT-CP333 CD Shelf System
Does not eject
When pushed the button there is no. opening from cd
2 Suggested Answers
  • 223 Answers
SOURCE: stuck cd discs
I think there are a couple of faults here. The first one is maybe a faulty motor on the eject mechanism. The second one is a faulty laser unit as it is not scanning the disc. Hope this helps.
Posted on Oct 05, 2008
My acer x1700 cd drive wont open.. i can hear it attempt to open. i do not have an emergency bottom or push out hole. please help many thanks
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you continue having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Oct 23, 2012 | Acer Computers & Internet
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
Eject does not open
Most hard-drives do *NOT* have an EJECT button.
Most diskette-drives *DO* have an EJECT buttton.
Most CD/DVD-drives *DO* have an EJECT button.
Turn your computer off. Straighten one end of a Norwegian paper-clip, and insert it into the small hole in the front-plate of the CD/DVD drive, until you feel "resistance". Then, push it another 1/4 inch, and the drive-tray should "unlock" and open slightly. Then, gently pull the tray fully-open. Remove any CD/DVD media. Then, replace the CD/DVD drive.
Jan 29, 2010 | Computers & Internet
ERROR 03 WHEN PUSH CD BUTTON
Two solution proposed on other forums:
1. Hold 'eject' button for 10 seconds. The system should eject the cd.
2. Slide a credit card back and forth on the cd opening. Push eject, the cd should be ejected.
Hope it works.
Oct 14, 2009 | 2004 Mitsubishi Endeavor
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
CD-ROM not opening
The eject mechanism is driven by a seperate belt. You'r's is worn or broken, however, there is a small pinhole in the face of the player that you may stick a paperclip into and the tray will open.
Oct 09, 2009 | E-Machines emachines (emachinees) CD-ROM...
DVD drawn bides and won't open when the eject button is pushed.
open "my computer" ...in the left panel click on the "eject the disc"
Mar 20, 2009 | Sony Computers & Internet
Stuck cd discs
Jul 25, 2008 | Sony RCD-W500C 5-Disc CD Recorder
Tray will not eject on LTR 16102B CD-RW
Most likely due to a worn belt. You can use a paper clip in the manual eject hole while pressing the button repeatedly to get it open. The belt or the drive will need to be replaced.
Jul 07, 2008 | Lite On LTR 16102B CD-RW Burner
Cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Mar 13, 2007 | JVC KD-S680 CD Player
Sony CMT-CP333 CD Shelf System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
