Question about Sharp 27K-S300 27" TV
Turn off pip sharp - Sharp 27K-S300 27" TV
We cut cable and are trying an antenna without success. Is the Sharp component-in Pip/mts compatible with an antenna?
is this a TV , if so it should work with an antenna if you select the proper input type which might be AIR or antenna
Nov 13, 2015 | Sharp Cameras
Pip won't turn off. can the pip be removed or bypassed?
Some of the older sets with PIP require only the original remote to operate or turn on and off.
The PIP board usually develops problems with surface mounted caps and there is a "modification" where traces are cut and two 4.7 mfd caps inserted which will bypass the PIP board from the set--a model number would tell me if this is possible in your set or not--you missing the original remote? Almost any Mitsubishi remote of the era with PIP controls should do the job.
Dec 02, 2012 | Mitsubishi Televison & Video
Sharp CX80H6 Has sound, no picture for TV or AV OSD works
This style of failure with the CX80h6 and indeed other CX80 & SX80 series SHARP 80cm sets is usually due to problems with the PIP (picture in picture) sub-board. This small board plugs vertically into the main left hand PCB (seen from rear of set) and is sealed in tin-plate for RF shielding. I've had two CX80h6 sets recently with this exact failure and both had problems with the PIP sub-board. One needed a new regular on the board while the other had a dry joint on the connector. This sub-board is not available from SHARP anymore, but in most cases the failed component is a discrete that usually can be sourced in it's own right. So this sub-board is where I think you should start your fault finding.
Regards,
Romsey
Mar 15, 2010 | Sharp 32C-240 32" TV
We have a Sharp Aquos TV with an annoying black box in the upper left hand corner of the screen. How do we get rid of it?
You may have PIP or picture in picture turned on and set to a input that has nothing connected to it. That's why the box is black. There should be a button on the remote for PIP. Try to turn it off. Or turnit off in the menu.
Jan 24, 2010 | Sharp Televison & Video
Black square on screen that covers half the picture appeared on my 42" sharp aquos tv.
sounds like you might have PIP turned one (picture in picture) .. if there is no input hooked up for the PIP . you will just get a black screen ... you should be able to move that PIP around and change its size .. indeed turn it off .. look for a menu item called PIP .. select PIP off ..
Nov 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hey there i have a sharp tv mts stereo pip and it turns off after 10 seconds.. i turn it back on.. and it turns off after 10 seconds.
i sujjest you download the complete 46 pages service manual from my ftp sight,and do a factory reset of the set,request it at computec40@hotmail.com
Nov 04, 2009 | Sharp 32F640 32" TV
Television powers off, after being on for seconds, 1997 sharp PIP
this could be a memory error.please,contact the nearest repair shop.do not turn it on again until then,please.
Jul 12, 2008 | Sharp 25R-S100 25" TV
Sharp 27K-S300 27" TV Logo
19 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
