Lg surround sound rear speakers do not speak - Audio Players & Recorders
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
See if there is a Factory or Return to Default procedure in your owner's manual. If that doesn't take care of the issue, your unit has a condition known as DC Offset, meaning a damaged amplifier.
Posted on Feb 10, 2014
techman
  • 3130 Answers
SOURCE: Surround Sound Speakers and AUX
You have the mode selector for the surround sound on the wrong switch setting. Look at the owners manual to see what setting you need for synthensized suround. Go to http://www.samsung.com if you need an owners manual. You will find it with a little bit of searching. Good Luck
Posted on Oct 09, 2006
Pattods
  • 116 Answers
SOURCE: no sound through tv speakers
Well the problem is that the PS3 only allows output on one channel. So, this is only going to be optical out, or hdmi, or even AV. You only get one option for the output.
Now, if your TV has the capability.. Run the sound through the HDMI to the TV and then let the TV output the digital sound to the surround system. This will give you the option of turning off the surround and re-enabling the TV's stereo speakers.
I hope this gives you an idea of what the problem is. If I were you, I'd just do as I said. This is exactly how I have mine setup. I have a 600w sub on the surround, so late night movies can't be played on it without the neighbors being woke up. So, I simply disable the TV's output and use it's speakers. :)
Posted on Sep 13, 2008
renx
  • 71 Answers
SOURCE: Rear surround sound speakers not working during movie.
Look on your manual, page E16. Go into your speaker setup. Select your speakers (Front,C,Surround, Sub) and make sure each are selected as "small" (make sure you go through each one). If the surrounds are selected as "none" the rear will not activate and will light up as red on the display. Let me know if this helps.
Posted on May 02, 2009
SOURCE: no surround on LG HT904 when using iPod
TRY TO CHOOSE THE SOUND TYPE TO BE MATRIX
Posted on Feb 03, 2010
  • 11800 Answers
SOURCE: LG HT752TH Surround sound system rear x2 and
They will work only if the source signal is itself 5.1. If it's stereo then you must convert it to 5.1 using the Virtual sound setting (press VSM to access it and select 5.1).
Posted on Sep 02, 2010
Lg HTS how do i change from stereo sound to Surround. The rear and centre speakers are not working at present
Music only plays through those two speakers, only movies with 5.1 format will play through all your speakers
Sep 18, 2012 | LG 5.1ch 1100w bluray hts 5 speakrperp...
Bought a LG Blu ray DVD Home theater system last weekend and set up with LG lcd tv and has been working fine till today. We had the radio on and I turned the TV on and the two rear speakers do not work...
In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
Stereo-Front Left and Right speakers including subwoofer
Dolby Digital or PLII Movie-these are the bost options for your surround sound
Direct-All speakers connected get full range signal
Good Luck
Jan 07, 2011 | LG Audio Players & Recorders
I have an older model Yamaha HTR 5830 receiver and I want to set it up for surround sound (5.1). When I test the receiver all five speakers give back a signal, but nothing ever comes out of the center or...
The broadcaster of the TV station has to tell you they are transmitting surround sound - sometimes they are just transmitting stereo. Also, the media as in CD's and DVD movies must have surround sound embedded or recorded on it to allow surround sound.
Jan 02, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Lg lht854....wont play sound out of rear and center speakers
Try setting it first on surround mode because it is normal for the rear speakers not to come on when it is the surround mode is off. For the center speakers make sure it is hooked up properly. Follow the instruction if you have one. Lastly I never heard of center speakers have two speakers in it but if it does and you only have one set of wire to it then one of the speakers is no good.
Jun 26, 2010 | LG LHT854 Theater System
Unable to connect surround sound with a stero player
There is a obvious difficulty here. If you have a stereo receiver then it can't produce surround sound. You must have a surround sound receiver to present true surround sound. If you already do have that then on the back of your Phillips set there are audio outputs. The left and right audio out will be decoded in your surround sound receiver and they will automatically play from your speakers. You should have seven speakers, center channel, left and right front speakers, left and right rear speakers and left and right mid or side speakers. A sub-woofer would be nice too. Best bet is to speak with the store you purchased the set from. They will have that information.
Zashiban
Jun 23, 2010 | Philips Televison & Video
No surround on LG HT904 when using iPod
Jan 22, 2010 | LG Audio Players & Recorders
Center speaker and wireless rear speakers have no sound
I had the same issue, but apparently...it's not an issue. What I discovered is that the system was fine, but the station I was watching didn't broadcast in 5.1 surround sound. Therefore, only the front speakers will have sound. Try putting a dvd in, or listening to a gameing system through it. If you don't have sound after listening to something that puts out full surround sound, then you know you have an issue.
Jul 07, 2009 | LG LHT854 Theater System
Center and rear speakers not working
In regard to the rear speakers, my system is an LG and the rear speakers will only work if the format that i'm watching (TV, DVD) is in Dolby surround sound 5.1. Normal tv will not give you surround sound unless it says otherwise, usually it will flash up on the screen at the start of the show. So test the unit with something that you know is in 5.1
Jun 26, 2009 | Audio Players & Recorders
Surround Sound
That's normal Carol. Television shows don't use the rear speakers very much.
Jan 25, 2009 | Audio Players & Recorders
19 people viewed this question
 Grubhead
Grubhead
