Question about Toro Co M/R Blwr/Trmmr Rear Bag Kit
Wont blow snow
Belt drive auger spin find until you get into the snoe
    Problem Solver:
  • 14 Answers
The belt is worn and cont handle the load. Replace the belt. The tensioner may need to be adjusted.
Posted on Feb 09, 2014
My ariens don't works most of the time when I start throwing g snow it always stale
first adjust carbureted to the sweat spot, turn mixture screw in till it sounds like funny, turn it out till it stumble, set it half way between. Grease auger shaft if applicable, check oil in auger gear case. Then try again. If this does not work do a compression test
Dec 18, 2016 | Cars & Trucks
Ariens st350 snow blower wont blow snow, augers wont spin
there is a bolt that goes thru auger and spinning shaft (look for a hole where it once was) holds the augers to the spinning shafts, it is called a shear pin, it is a safety feature, and made of softer metal, so if you pick up something too hard with the auger, it wont lock up the engine, or break engine crank shaft.find an ariens repair shop to purchase the shear pin so you get the right softness of metal.
Mar 05, 2013 | Garden
I have a snow blower which will start up but it won't move forward in the snow nor will it push the snow. Not sure what is wrong. I can manually move the blade around that pushes the snow.
If you start the machine and the axles spin but the augers do not it is because the shear pins are broke. If you look closely you will see the the augers have shear bolts and nuts or shear pins. If you jam a piece of ice or a stick in the augers while they are spinning the bolts will shear so you do not damage the expensive augers or the worm drive gears. If the axle spins with the augers you may have torn up the front worm gear in the front of the auger intake. If you spin the small auger and the large auger moves but when you start and engage the auger nothing happens you will have to remove the under cover and inspect the drive belt pulleys for jammed or broken parts or more commonly broken drive belts.
Jan 28, 2011 | Mtd 22" Yard Machine Push Mower
Snowblower doesn't throw the snow very far, and every time I stop it, it takes a while for the auger to start turning fast enough to blow the snow. Feels like the torque isn't there. This is a Husqvarna...
The most common cause of this is the drive belt is worn.
If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
The belt closest to the blower assembly drives the auger/blower and the belt closest to the engine drives the transmission.
With the engine not running, have someone depress the drive lever and check the blower belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
You can get parts for you Craftsman and most Husqvarana, MTD made models through searspartsdirect.com. You can also get parts through jackssmallengines.com or your local dealer.
If you are unfamiliar with repairing machines take it to your local dealer. They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions to troubleshoot this problem farther. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Garden
I have craftsman snow blower 5 hp 24inch model #
does the impeller spin and not the augers.if so check sheer bolts.if neither impeller or auger spins check auger belt.
Feb 22, 2009 | Craftsman 16" High Garden Tractor Snow and...
Snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Dec 13, 2008 | Toro Blowers Rake and Vac - Electric...
On my two stage snow blower--main auger stops turning .
Hi, I figured out the problem. The gear transfer case between the augers must be broke. The auger spins slowly until it hits snow and then stops-- The discharge fan continues to spin fast. I will try to get a local handyman to fix it or else but a new machine, this one must be at least 15-16 years old.
I thank you for your help, it is a great service. ojohn
Dec 10, 2008 | Garden
Toro Co M/R Blwr/Trmmr Rear Bag Kit Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
