Question about Gateway T-6836 Notebook
Gateway T-6836 not charging
The charger does not have any breaks or bends. When plugged in to wall and computer the computer does not say it is charging.
farhangM
  • 64 Answers
SOURCE: Gateway Laptop not charging
It sounds like defective power jack. Bring it to a reapir shop.
Posted on Dec 01, 2008
  • 670 Answers
SOURCE: Can I replace my gateway T-6836 laptop 250 gb hardrive
Yes, it can be upgraded for a larger drive. The important specs to know are the physical size and the interface. The size that this computer needs is the 2.5 inch and the interface is the SATA. These are the typical size and interface used today so finding a drive that fits should not be a problem.
Hope this helps.
Posted on Jun 30, 2010
SOURCE: My Gateway NV5386u battery died and the computer
Often when a battery is real flat, it hangs up the entire system. What you need to do, is remove the battery completely, as the laptop should be able to be powered by the AC adapter itself. You may find if that is the case that your battery has gone bad, and you will have to replace it. If your laptop, will NOT work from the AC adapter, then either the adapter is faulty, or there is an internal vault, in the Power conditioning circuitry inside the PC. Try another adapter, if still no go, then it is definitely an internal problem.
Posted on Jul 16, 2010
jarrett622
  • 74 Answers
SOURCE: Hello, My Gateway laptop will not charge. When
Have you tried removing the battery and putting it back in?
Does the laptop boot when the power cord is plugged in? With and without battery?
What does the battery charge icon in the task bar (down by the clock) show?
These are the first steps I use when troubleshooting a charge problem.
If none of these yield a solution than it's time to look deeper. And it *may* be a problem with the motherboard or more specifically with the charger port or board. The next question would be, is your laptop still under warranty? Laptops are not fun to take apart.
Posted on Feb 15, 2011
MSG-CPC
  • 1325 Answers
SOURCE: Charger light goes out when plug in computer
it could be that the connection jack on the mainboard has been dislodged from the solder joint, common among Gateway comuters and HP units too. is the DC jack loose from the notebook ? if so thats the issue it seems. You will have to bring it to a computer person to resolder. if not and youc an do it yourslef, save money -- but be careful not to damage anything on the mainboard.
Posted on Jan 03, 2012
Testimonial: "Good to know but when I first look at the Jack it look good and soild, I went and ordered a new one anyways and will relook at it just in case, someone said it might have somthing to do with windows 7 software in the device manager battery control method."
Is there a way to charge my 930 T on a wall socket AC adapter
The trouble with cheap chargers ' Mobile Fun Blog
www.mobilefun.com/blog/the-trouble-with-cheap-chargers/
Jul 10, 2012 - The abbreviation for amp is A. There are also milliamps which have the abbreviation mA. ... The other way around isn't as much of a problem. If you try tocharge an iPhone (1.1A) using an iPad charger (2.1A), ... micro USB cables can't tell the difference between a wall socket (AC power) and a USB port.
How USB charging works, or how to avoid blowing up your ...
www.extremetech.com > Computing
ExtremeTechAug 26, 2015 - If you take a smartphone which came with a 900mA wall charger, and plug it ... It turns out there's a method to all this madness - but first we have to ... A regular USB 1.0 or 2.0 socket has four pins, and a USB cable has four wires. ..... Last week I couldn't find my phone charger (wall plug), so I tried using ...
What wall plug chargers can be used to charge PS3 ...
gaming.stackexchange.com/.../what-wall-plug-chargers-can-be-used-to-c...
Jun 19, 2012 - I want to charge my PS3 controllers (SIXAXIS) without having the PS3... I have noticed there are (expensive) third party PS3 controller charger ... Why can'tthe normal wall plug chargers, that are able to charge way ... The PS3 controller won't charge when connected to any usb outlet (where only ...
Amazon.com: AC Adapter Wall Charger w/6'FT Power Cable ...
www.amazon.com/Adapter-ChargerCity-Manufacture...
Amazon.com, Inc.
Rating: 5 - ‎5 reviews
ChargerCity GPS AC Wall GPS USB Power Adapter Cable Accessories for ... XXL 550 540 535 530 GO 920 930 720 730 740 630 640 TOM TOM LIVE Traffic GPS ... I don't really have any need for the Micro SD Memory Card Writer so can't ... I now cancharge my TOMTOM from a wall socket instead of leaving it in my car.
Charging your Lumia 930 ' MyUCS
Jan 03, 2016 | Computers & Internet
My nabi can only go on with it being charger thru computer and not using its own charger.
The wall charger is faulty! Do you see any indication on the Nabi that it is charging when the wall charger is plugged in?
Jan 06, 2015 | FUHU 7" Tablet PC NABI2NV7A
Is the only way to charge this tablet by plugging it into a computer?
Depend what model "this tablet" is. Generally tablet chargers have a USB connector at the wall plug end , plugged into the wall charger and a mini usb or proprietary connector at the tablet end. The USB connector can also be plugged into a USB port on a computer or other device. Charging rate will depend on how much current the device can deliver to the USB port, they are not all the same.
Aug 24, 2014 | Tablets & eReaders
try to use another adaptor; with the same power
if the laptop steel not charge with the new adaptor; it can be battery or motherboard problem;
Feb 09, 2014 | Gateway T-6836 Notebook
Asus charger won't charge
Stop using that charger. I sounds like you have a break in the wire and when you hold it in the right position, the two pieces touch and current flows. Unfortunately the heat is probably being caused by arcing and is a potential fire hazard.
Apr 06, 2017 | ASUS Original 19v 3.42a Ac Adapter Charger...
I have a new charger cord when plug in back of computer my computer want charge up
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Mar 10, 2011 | Gateway M-7315U Notebook
My Gateway laptop NV54,shuts off when i either unplug the power chord or plug it in. Then it turns back on. The battery charges alright and works. Do you know what is the problem?
I would suspect a bad connection on the motherboard since you say your battery is OK--I take it to mean that your computer runs when plugged in or on battery.
Try this:
Leave the charger plugged into the computer and unplug it from the wall. Then plug it back in. Do you have the same problem? If not, then it's the physical act of plugging the plug into the machine that is causing the problem and that would be causing some kind of contact problem on the motherboard.
Apr 01, 2010 | Gateway Computers & Internet
Sometimes my Iphone will not charge when i connect it to the wall charger. I just bought my iphone a couple of months ago.
If your iPhone is not charging when you plug it into a wall charger or into you computer's usb port, this is a usb connectivity issue and the connection just needs to be reset. All that needs to be done is plug the iPhone's cable into the phone but don't plug into the computer yet. Hold the phone's select button (the round button with the square) down for about 30 seconds or until the apple appears on the screen. your phone will reload and reset the connection and the computer should recognize the device. Allow the phone to charge for at least 30 minutes before unplugging.
Oct 21, 2009 | Apple iPhone Smartphone
Nov 30, 2008 | Gateway MT3705 Notebook
Motorola razr
Close the flip screen. Unplug charger from the wall and the phone. First plug in phone jack into phone BUT make sure to push it in a bit sideways. Not too much it can break the pins but just with a little angle. When you hear good click than plug charger unit in the wall.
Apr 23, 2008 | Motorola Mobility RAZR V3
Gateway T-6836 Notebook Logo
13 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
