Question about Toro Co M/R Blwr/Trmmr Rear Bag Kit
Wont blow the snow
Belt drive
    Problem Solver:
  • 14 Answers
Most of the time this is because of a worn belt or tensioner out of adjustment.
Posted on Feb 09, 2014
Not blowing snow
Sounds like the Belt is slipping. Take the plastic cover off, loosen the bolt that holds the idler pulley and move it toward the belt a bit.
Jan 30, 2016 | Garden
Snowblower problems
Possible problems
Belt slipping ( too loose or worn out )
Snow too wet and plugs up.
Motor not powerful enough could be running too slow
Could be the gas screw on the carb set too rich and floods or too lean.
Could be trying to blow too much snow at a time.
Depending on the machines age could be just wore out
In saying this I don't know what type or age of your machine
Feb 22, 2014 | Garden
Transmission Locked up on Poulan Pro 18 hp
Is this a riding lawn tractor with a snow blower attachment? If so, I would inspect drive belt underneath unit to see if it slipped off and is locked up. If belts look ok, try pulling hydro release to see if you can push unit. If not your problem sounds internal.
Feb 18, 2014 | Poulan Garden
Wont blow snow
The belt is worn and cont handle the load. Replace the belt. The tensioner may need to be adjusted.
Feb 09, 2014 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Troy built snow blower wont blow snow
check youre belts and control cables
Jan 21, 2014 | Troy-Bilt Garden
Snow shute keeps pluging up
If you are trying to blow wet snow that will do it and also if the drive belt is slipping that will bog it down and plug it up. Also keep the motor reved up to top speed when operating.
Jan 05, 2014 | Garden
Snowblower doesn't throw the snow very far, and every time I stop it, it takes a while for the auger to start turning fast enough to blow the snow. Feels like the torque isn't there. This is a Husqvarna...
The most common cause of this is the drive belt is worn.
If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
The belt closest to the blower assembly drives the auger/blower and the belt closest to the engine drives the transmission.
With the engine not running, have someone depress the drive lever and check the blower belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
You can get parts for you Craftsman and most Husqvarana, MTD made models through searspartsdirect.com. You can also get parts through jackssmallengines.com or your local dealer.
If you are unfamiliar with repairing machines take it to your local dealer. They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions to troubleshoot this problem farther. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Garden
My troy-bilt 8.5 horse 26 inch wide snowblower wont move anymore.
Take the belt cover off that covers the drive pulley on the engine. You should only have to loosen two bolts. Inspect the belt to see what it looks like. I am not sure if it drives a gear box or if it turns a friction wheel that drives the wheels. If the belt looks good check for shear bolts that might have sheared off and replace them.
Dec 19, 2009 | Garden
Toro Co M/R Blwr/Trmmr Rear Bag Kit Logo
24 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
