Tda 7388 ic
No odo
5 Suggested Answers
  • 579 Answers
SOURCE: TDA 8364
Look it up at nteinc.net
Posted on Jan 02, 2008
  • 2322 Answers
SOURCE: NEED TO GET 27 PIN
This IC is available from this link or from electronica but is a bit more expensive.
Posted on Oct 01, 2010
gopakumarg43
  • 74630 Answers
SOURCE: Tda 11105/AO1 IC service mode
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Type in the IC number in the search box at the top right of the display window, to get gathered some pages which has the details of practical experiences to the author of that site.
Posted on Aug 10, 2015
gopakumarg43
  • 74630 Answers
SOURCE: Samsung crt tv ic tda 9381 mute system not working &No audio . audio ic tda 7297sa
IC fault. Replace the TDA9381. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Posted on May 29, 2016
May 29, 2016 | Samsung Televison & Video
Tip
Replace the kkz-12 power amp ic on kenwood car stereos
replace the kkz-12 ic[difficult to find expensive!]with the tda 7560!first desolder the kkz .have 27 pins.take the tda and cut the pins 1 and 25.replace the kkz with the tda now.let the pcb positions 1-2 and 26-27 pin empty.solder the ic put htc in the heat sink tight screws and check the unit!
on Mar 08, 2010 | Car Audio & Video
Aug 10, 2015 | Televison & Video
Blinking red light
You did not give a model number. If this is an older model Sony, I would be concerned with the audio IC with standby. This IC will be of the TDA-XXXX series. I doubt if you have a problem with power supply. If you can locate the IC mentioned, and read the TDA number, cross reference this in an NTE semi conductor manual. If it does tell you it is an audio IC with standby...replace this IC with the cross reference. Be sure to check any grounds that need resoldered in the same area as the IC mentioned. Thanks for asking and show a few hands of support!
Mar 26, 2011 | Sony Televison & Video
Ic used in which section of philips TV kit
tv set no sound coming.i replce sound out put ic but not hasbeen coming .i think 9370/1665 ic in side a/f out put line is gone i have a this curcuit daigarm not avilable so pl help this point
Oct 10, 2008 | Televison & Video
TDA 8364
Jan 02, 2008 | Philips Magnavox 27MS343S 27" TV
Missing vertical deflection on philips TV
TDA 8362B IC which have vertical freq.output is at pin no.43. (vert.osc) caution for fixing this problem minimise brightness to avoid crt burn. proceed as follows 1 if you are getting sawtooth at output of ic tda 8362 pin 43 then check 1 supply at vertical output ic from eht. 2 yoke connector loose . 3 check vertical output ic parts. 4 finally vertical ic. please check for normal output from power supply even though fault gets rectified just for protection. good luck.
Sep 22, 2007 | RCA 13R400TD 13" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
