Question about Mitsubishi VS-60707 60" Rear Projection Television
Mitsubishi VS-60707 60 in. Rear Projection Television
When I turn the tv the picture is dim.  It seems to get better when the tv warms up.  Also, there is a horizontal wavy line at the top and bottom of the screen.  Can you please help?  My e-mail address is georgesnyder@north-woodlands.com
Thanks,
George
  • Anonymous Nov 25, 2007
    I'm having the exact problem. Have you tried to clean your lens on the gun? ... I can be contacted at vstankewsky@yahoo.com.. First name Vic.
    Problem Solver:
  • 18 Answers
When it gets better after warm up it can be a capacitor in the 160 Volt high voltage circuit or a cold solder joint. these 2 thinks would be my best guess on this set.
Posted on Dec 27, 2007
24af45 from top to bottom picture is wavy until set warms up
Check and replace all the electrolytic capacitors at its vertical scan output stage circuit. Replace all of the once.
Apr 04, 2013 | Toshiba 24AF45 24" TV
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
Horizontal wavy lines on picture
Sounds like the convergence has failed. This video gives more details
Apr 12, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Wavy horizontal lines running through the screen
Ur tv convergence is dead.U must know how to solders?The 2 STK convergence ICS.and some or all it resistors must change.Tries websites Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 17, 2010 | Mitsubishi WS-55613 55" Rear Projection...
Picture is wavy and has black vertical and horizontal band
The following are supposed to be checked on the horizontal and vertical,
the supply of the sawtooth oscillator
eletrolitic capacitors near a line transformer
zener diodes
and driver transistor a round that area.
Apr 08, 2009 | Toshiba 35A44 35" TV
Toshiba 50H82 with wavy lines at the top when in HD mode
Found this person on eBay who repairs the hyperboard for $75 quickly with very positive feedback.
http://myworld.ebay.com/kcarrigan/
I have the same problem and will probably send mine after the holidays.
Dec 03, 2008 | Toshiba 50H82 50" Rear Projection...
Sylvania 6427FF TV displays wavy verticle lines at top of the screen.
I would suspect defective filter capacitors in the sweep circuits as well as the power supply source voltages.
Aug 07, 2007 | Sylvania 6427FF TV
Wavy Screen on Startup
I gather from your post that wavy can mean two possible things as the TV comes on, you see the picture flow like ocean waves? In this case you may have 60Hz hum modulating with the picture, this is actually unlikely these days, but I have heard it happens sometimes. The other thing it could be is light horizontal tearing. This happens when the horizontal frequency is too high or too low. You are not going to like my solution because I feel that for problems like this the set must be analyzed not just subjected to "shotgun troubleshooting", so here I go, Take the TV to a repair shop.
Feb 28, 2007 | Toshiba 50H72 50" Rear Projection...
Wavy horizontal picture
the vertical IC outpt needs to be replace
Dec 29, 2006 | Panasonic PT-53WX42 53" Rear Projection...
Mitsubishi VS-60707 60" Rear Projection Television Logo
210 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
