Question about Westinghouse Microwave Ovens
Mod. number J Vm1340 WW002 broken door handle
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: How to replace the door handle on a mod. MH 1170XSY-0 mico wave
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Posted on Jul 09, 2009
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
My handle door is broken.
Hi and welcome to FixYa, I am Kelly. There are 4 different doors for this microwave see this link:
http://specsserver.com/CACHE/FRJVHRUTDMYQ.PDF
Item 58 is the door handle
Part numbers are:
5304440323 - - - - Handle, door, black
5304440325 - - - - Handle, door, bisque
5304440324 - - - - Handle, door, white
Stainless handle not listed.. I assume it is a black handle
This has to be one of the more expensive microwave door handles I have ever experienced.
The least expensive source I found was at sears parts direct.
5304440324 Handle door white Price $88.80
http://www.searspartsdirect.com/partsdirect/part-number/5304440324/0022/628?pathTaken=partSearch&filterPart=&pop=flush
5304440323 Handle door black Price $98.97
http://www.searspartsdirect.com/partsdirect/part-number/5304440323/0022/628?pathTaken=partSearch&filterPart=&pop=flush
5304440325 Handle door bisque Price $88.80
http://www.searspartsdirect.com/partsdirect/part-number/5304440325/0022/628?pathTaken=partSearch&filterPart=&pop=flush
Note that Item 51 of the first link (top one) is the complete door assy. Also Item 60 is the door HANDLE screws (2 ea)
Just from looking at the diagrams in the first link, it appears item 56
Frame, choke cover, inner door
must be removed to gain access to the handle screws.
I looked up many sources for the handle assembly because I had a hard time believeing the handle was so expensive. Sears was by far the cheapest source.
Thanks for choosing FixYa,
Kelly
Nov 13, 2010 | Frigidaire FMV156D Microwave Oven
The lower handle retainer is broke
If only the door handle is broken, it can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
If the model number is correct, this is a parts illustration of your oven door:
http://pcappliancerepair.com/model-display.php
The door handle on this model has two parts (items 3 and 8). Depending on what is broken, you may only need to order one or the other. Both parts, combined, is still only about $20. The part numbers are WB15X10119 and WB15X10120, respectively.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
If you have any questions, please post back with your and let me know. I hope this helps you
Jun 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I need a new door for this microwave. I have been looking online for hours and can't find just the door. Can anybody give me a website that sells just the door for this micro? Thanks....
The door is available at any of the following websites:
appliancepartspros.com
repairclinic.com
If the model number you listed this question under is correct, the part number for the ENTIRE door is WB56X10585.
Is there a reason for replacing the entire door? You can purchase individual replacement parts if only a single part on the door is broken. The first three sites on the list have helpful exploded view diagrams to assist you in locating and properly identifying the parts you may need.
The most common thing that fails on these doors is the door handle. If only the handle is broken, the door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The part numbers for the handle on this model are (2 pieces):
WB15X10119
WB15X10120
May 31, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
It's broken
The door handle can easily be replaced on most microwave ovens. You just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to access and/or replace the door handle:
The cost usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. However, price and configuration of your oven also depends upon the MODEL NUMBER. If the model number is correct, the part number for a replacement door handle is WB15X10023.
If you have any questions, please post back and let me know. I hope this helps you.
Jan 29, 2010 | GE JVM1631 Microwave Oven
I have broken handle on the GE Spacemaker Model JVM130H. Can this be replaced and how?
The door handle can easily be replaced on most microwave ovens. You just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
The cost usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. However, price and configuration of your oven also depends upon the MODEL NUMBER. If the model number is correct, the part number(s) for a replacement door handle is WB15X10119 and WB15X10120. The door handle on this model has two pieces.
If you have any questions, please post back with your model number and let me know. I hope this helps you
Jan 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Jul 09, 2009 | Whirlpool MH1170XS Microwave Oven
My door handle is broken. Is it posssible to
You should be able to buy only the door handle and avoid having to replace the entire door. Appliancepartspros.com carries the handle. Just type in the model number you provided and look for item #3 under the parts listing. The part number and price varies based on the color you need. Make sure you order the correct color. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
Jul 06, 2009 | GE JVM1640 Microwave Oven
Handle-door
Look up your model number in the Whirlpool web site, they should have an online manual.
Jun 01, 2009 | Whirlpool MH1150XMQ Microwave Oven
Microwave Ovens Logo
20 people viewed this question
Top Westinghouse Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Westinghouse Microwave Oven Expert? Answer questions, earn points and help others
