Question about Grizzly Big Bear Atv Maintenance Free Battery
Runs for 100 meters and then quits
Sits for 5 mins and then starts again.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 4 Answers
Sounds like a relay getting hot
Posted on Apr 05, 2014
Why does it run for 10 mins, then stops?
Loosen Gas cap and see if that helps. Many times the Gas tank Vent gets clogged. When engine runs, it creates a suction and starves the engine of gas.
OR
If the engine was stored with gas in it, sometimes the Rubber seat in the carburetor deforms and wont let the gas flow into the Carb Bowl at a fast enough rate to keep up with the running engine. The bowl empties (after 9 minutes) and the engine quits. Takes a while for the bowl to refill (5 minutes).
Jan 16, 2016 | Toro Snow Blowers. Power Clear 621 QZR 21...
Frigidaire top load washer that keeps shutting off
i canty be 100 percent sure
without the model
but it sounds like you motor is trying to start but for whatever reason is cutting out on the overload. Meaning it gets hot,,,and shutsd it self off to save it self
ther ecould be alot of reasons for this,,, far to many to type here,,,
with frigidaire it could be a bad motor capacitor, or a bad start winding on the motor.......
or a simple as a sock between the tubs preventing the tub from truning
sorry i cant be more help
but figured you should have some sort of answer to at least5 investigate
Oct 28, 2009 | Washing Machines
Suburban stalls while driving after running for 15-30 minutes. After letting it sit for 5-10 min it runs fine for another 5-10 minutes, then starts doing it all over again.
a bad crank sensor can cause this. shuts off while going down road, and will start about 10 min, later with no problems runs fine until it quits again. hope this helps,
Oct 07, 2009 | Chevrolet Suburban 1500 Cars & Trucks
Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
May 22, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
My avenger cuts off after being driven for at least 5-30 minutes
a very common problem with these cars is the crankshaft position sensor. also camshaft position sensor. they will make the car do exactly what you described. let me know what you find
Jan 06, 2009 | 1995 Dodge Avenger
Snowblower runs then quits
check to see if gas cap vent is clear . its the little pin hole at the top of cap . if not clear it will cause a vacuum and stop the flow of gas ... good luck
Dec 19, 2008 | Mastercraft Garden
Stalling on a 22re engine
hi voltage sistem is overheting (vovina) chench it
Nov 03, 2008 | 1985 Toyota Celica
Grizzly Big Bear Atv Maintenance Free Battery Logo
47 people viewed this question
Top Yamaha Vehicle Parts & Accessories Experts
Andrew Taylor
Andrew Taylor
Coss
Jeff Youtsey
Jeff Youtsey
Are you a Yamaha Vehicle Part and Accessory Expert? Answer questions, earn points and help others
